Author Topic: Help with ITX Gaming Build  (Read 2075 times)
Offline mr. rampage
« on: Fri, 13 September 2013, 10:36:18 »
Hello,
So I bought an NCase and now need to plan an ITX Gaming build. Since the case won't start shipping until January, I don't expect to build until March. I'm not so up-to-date on what's going to be available in Q1 next year (i.e. will DDR4 be available?), but here's the build so far. I'd like advice on what to improve in terms of performance to budget. My budget so far is about $2k, but I'd like to get it to around $1.5k.
Here's the parts list. Any advice is greatly appreciated.
FYI, I won't need any sound support as I use an external USB DAC.
« Last Edit: Fri, 13 September 2013, 10:40:04 by mr. rampage »
Offline jalaj
Re: Help with ITX Gaming Build
« Reply #1 on: Fri, 20 September 2013, 11:19:54 »
Your configuration looks very solid. If you're looking to eek out noticeably better performance, then plunk down for a higher class GPU (make sure it fits inside your case).
Offline dgreekstallion
  • B.S. Fiend
« Reply #2 on: Sun, 22 September 2013, 23:24:17 »
Looks pretty good; those new 7-Series GPU's seem really nice.
My brother in law just installed two 770's in his insanely powerful computer (32 gigs of ram & Intel Core i7-3930K, lol) and now it's even more efficient and runs even cooler.
Recent keyboard fanatic.
Model F-122 convert.
Offline Leslieann
« Reply #3 on: Mon, 23 September 2013, 04:05:22 »
Wait until you are ready to build to start buying or even planning.
What you have listed looks good, but the best deals change from week to week, new parts come out monthly. Telling you what to get months from now, just won't be accurate.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline concept73
« Reply #4 on: Mon, 23 September 2013, 04:19:36 »
Personally i would not go with Haswel,
i run 2 systems,
i7 2600k, sahhpire 7970 3GB, asrock b75 itx all in my custom watercooled loop.
i5 3570k, 3GB 580, maximus v gene MATX,
So personally i do love my Sandybridge, nice temps, good clocking,
Haswell does not overclock as well and also gets VERY hot, even when watercooled!
Poker 2 with reds
Soon to be a JD40 with reds
Offline Linkbane
« Reply #5 on: Mon, 23 September 2013, 15:26:49 »
Same with above, the 770M and 780M are very far past the league of the 760M, so I would recommend one of those. Having the 675M and being unable to play Mirror's Edge at top settings, I shall regret it later. Didn't really have the money for a better one, though.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
