Author Topic: Friend wants a new keyboard.  (Read 2105 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Fri, 13 September 2013, 21:18:16 »
Hi guys my friend is considering a shine 3 and K70 he wants to know which is better as I have never used any of them I resorted to google and finally here hehe.
Re: Friend wants a new keyboard.
« Reply #1 on: Fri, 13 September 2013, 21:21:22 »
They're both fine boards. There's nothing particularly special about either. They're both similar, but with completely different designs. Just pick whichever your friend likes the look of best..
Offline Tarzan
  • formerly known as Greystoke
« Reply #2 on: Fri, 13 September 2013, 21:24:50 »
I'd suggest either a Ducky Shine 3 or a CM QFR, depending on which format appeals to your friend.  That way, if they just hate the mechanical keyboard, these both retain their value quite well.
I don't know much about the K70, but I don't see many people buying them or selling them here.
Good luck!
Offline C5Allroad
« Reply #3 on: Fri, 13 September 2013, 21:34:05 »
Ok guys he likes the shine 3 better but doesn't have play/pause where can he buy a media controller of some sort?
Offline Tarzan
« Reply #4 on: Fri, 13 September 2013, 21:37:12 »
Sorry, I'm not following?  The Shine 3 comes with media keys, but you can use them as regular keys too.  Or were you asking about a media utility that would work with the keyboard?
Offline C5Allroad
« Reply #5 on: Fri, 13 September 2013, 21:47:24 »
The shine 3 comes with mute volume down volume up. He wants something that connects by USB that can do all of that including play/pause. I don't know of that sorta thing exists.
Offline yjfknt
« Reply #6 on: Fri, 13 September 2013, 21:50:59 »
can't this be done with software? something like autohotkey?
I'm getting a kbt pure pro soon. and my friend told me that it is possible to map fn + "whatever" key into media play/pause, last song, next song. etc
Offline C5Allroad
« Reply #7 on: Fri, 13 September 2013, 22:03:15 »
That's the thing he's used that before but the games auto hack detect banned him for that before... So he sorta wants something external.
Offline Tarzan
« Reply #8 on: Fri, 13 September 2013, 22:06:27 »
I'm pretty sure there a ton of products out there that act as dedicated media controllers for PCs.  I found an actual remote control at Amazon, one of my first search results, so I'd bet there are lots of options to fit your friend's needs.
http://www.amazon.com/SANOXY-Wireless-Remote-Control-Mouse/dp/B001M56DI0
Offline C5Allroad
« Reply #9 on: Fri, 13 September 2013, 22:17:58 »
Ok thanks I'll go tell him now! Thanks guys!
[Edit] http://www.amazon.com/gp/aw/d/B003VWU2WA/ref=mp_s_a_1_5?qid=1379128689&sr=8-5&pi=AC_SX110_SY165
Look what I found!
Would this work in game?
