Author Topic: Post your buckling spring board  (Read 52718 times)
Offline Badwrench
  • ummmm.....I forgot
« on: Tue, 17 September 2013, 00:21:22 »
I have searched and searched for a post your buckling spring board, but found nothing (if you find one, I will close this one, just link it).  I see so many pics floating around a ton of different threads, so I thought it would be nice to have more in one place.   :thumb:
Post the model and date.
I will start.
I have been looking for a while for one after hearing so many good things about them and finally came across one at Church today.
My new (to me) 1391401 Model M.  Pretty dirty, but in very good shape overall.
35715-0
35717-1
Offline The_Beast
  • I like wood ಠ_๏
Re: Post your buckling spring board
« Reply #1 on: Tue, 17 September 2013, 00:27:11 »
Here's my SSK and M65
And here's my favorite board, my model F AT which I modded to have a ANSI enter and backspace
« Reply #2 on: Tue, 17 September 2013, 00:32:28 »
you have a dirty enter
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Tue, 17 September 2013, 01:15:32 »
I know, I replaced it with a blank anyways since the dirty enter didn't have a stabilizer leg that fits into the white inserts and the blank did.
Offline Emospence
« Reply #4 on: Tue, 17 September 2013, 03:54:21 »
I really want one for work but they are just so noisy :(
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Tue, 17 September 2013, 13:23:33 »
model 1397599
13 june 1994
found a junker and swapped out the cover (lid) from "blue label" to "black label"- blacked out area next to caps. drilled out LED area and stuck on a label i ordered from unicomp
also put a little insulation, duct tape, etc. behind the steel plate which reduced, space bar pinging, etc.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Tue, 17 September 2013, 13:25:33 »
nice and sexy........
« Reply #7 on: Tue, 17 September 2013, 13:30:54 »
Floss mod it!
Oh and my BS board? Dorkvader has had it for a while helping me to fix it up but I have a lovely SSK. Pictures are from here. It's on the bottom obviously.
She was born 09/26/1987 as you can see on the label.
Offline 0100010
  • Not Sure
« Reply #8 on: Thu, 19 September 2013, 10:27:25 »
Unicomp Model M
3/24/99
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 19 September 2013, 10:43:35 »
Model M in Industrial shell (up for sale now...) and Black M13. Still need to take a picture of my new SSK.
Online Findecanor
« Reply #10 on: Thu, 19 September 2013, 12:57:40 »
Insides from Dec '95: great shape, all plastic rivets intact. Case from a terminal keyboard from Jan '87. The keys are from both because the newer one lacked a few.
« Last Edit: Fri, 20 September 2013, 11:22:34 by Findecanor »
Offline Badwrench
« Reply #11 on: Thu, 19 September 2013, 13:26:34 »
Just went though mine and cleaned out the case (and the 6 broken rivet heads).  Board is in great shape.  Caps have no shine as the dirt was protecting them quite well.  There was quite a bit of chow on the board, and a bunch of sticky stuff, but it all came off and now the board feels new.
Ordered up a few caps from Unicomp to brighten it up a bit.
35984-0
35986-1
Offline Retrete
« Reply #12 on: Thu, 19 September 2013, 13:57:04 »
Model M 122 key, version with square label and some hat keys.
Offline ComradeSniper
  • HHKB Pro
« Reply #13 on: Thu, 19 September 2013, 23:26:45 »
Nice pics, that's one good looking Model M. I'd like to clean mine out but all my nut drivers are too big to fit into the tiny holes. Keycap cleaning will have to suffice for now.
« Last Edit: Thu, 19 September 2013, 23:45:23 by ComradeSniper »
Offline Badwrench
« Reply #14 on: Fri, 20 September 2013, 01:18:39 »
Thanks.  All of my sockets were too big as well.  I just took one to a grinder to allow it to fit.  You don't need a lot of strength in the socket, so you can get it pretty thin.
« Reply #15 on: Fri, 20 September 2013, 01:22:29 »
I bought a socket driver from eBay, from China.  A set of 4 was about $16.
  • HHKB Pro
« Reply #16 on: Fri, 20 September 2013, 01:53:05 »
I'll give that a try.
« Reply #17 on: Fri, 20 September 2013, 01:59:03 »
Or if you are not too impatient, get this from eBay - $5.41 with free shipping.
I got this one - a set of 4 for about $14.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #18 on: Fri, 20 September 2013, 07:47:39 »
Wanted to try something different with my ssk. Its a combination of blank black and blank pebble keys.
Only a crappy pic, looks way better in real. Now I need a black BS clickclack  ;D
36166-0
Offline esoomenona
  • Gnillort?
« Reply #19 on: Fri, 20 September 2013, 07:53:12 »
« Reply #20 on: Fri, 20 September 2013, 07:54:23 »
ITT: Lots and lots of vanilla Model Ms
Offline PadawanGeek
« Reply #21 on: Fri, 20 September 2013, 08:35:17 »
Mine differs in that it's a vanilla Lexmark Model M.....in almost mint condition, the three LED indicators aren't working, will look into that when I'm in the mood...
It's date of 'birth', so to say.... ;)
Offline Jokrik
« Reply #22 on: Fri, 20 September 2013, 09:24:11 »
My model M
IBM 42H1292
Date: 29-04-1997
I dyed the caps into (kinda) retro style with dylon dye
and painted the frame white
Offline 0100010
  • Not Sure
« Reply #23 on: Fri, 20 September 2013, 10:31:24 »
Get the blank pebble keys by sanding?  Looks very nice.
Offline snoopy
  • The Flying Ace
« Reply #24 on: Fri, 20 September 2013, 10:39:24 »
no, I ordered a blank set at unicomp in complete pebble. normally its a combination of pebble and pearl. And mixed this up with a blank black set. I tried to make a good picture, but failed. Pebble is the color that normally only the modifiers have. It now looks very military in real. :)
  • HHKB Pro
« Reply #25 on: Fri, 20 September 2013, 12:02:36 »
Thanks, if filing down the one I currently have doesn't work I'll get one of those.
Offline Badwrench
« Reply #26 on: Fri, 20 September 2013, 14:16:38 »
Here is how mine turned out.  I used and extension to hold it and took it to a floor mounted 6" grinding wheel.  Took about 30 seconds.
36241-0
Offline bazemk1979
« Reply #27 on: Fri, 20 September 2013, 19:21:56 »
got 20 IBM's, but here is a pic of few
Offline The_Beast
  • I like wood ಠ_๏
« Reply #28 on: Fri, 20 September 2013, 19:25:18 »
Very cool! I've never seen an industrial with the trackpoint before!
Offline Badwrench
« Reply #29 on: Fri, 20 September 2013, 19:33:29 »
Those are awesome.  I am a bit late to the game, but am enjoying mine immensely.  I actually quite like playing SC2 with it.
Just added some RGB and a couple custom caps from Unicomp.
36268-0
36270-1
Offline terran5992
  • One With The Cup Rubber
« Reply #30 on: Fri, 20 September 2013, 21:22:43 »
Im so jelly of all your IBM Spacesavers
Offline Justblair
    • Justblairs Audio and Electronics Pages
« Reply #31 on: Mon, 23 September 2013, 16:11:56 »
This is my 121 key model M.   Obviously it began life as a 122 key keyboard, but I modified the layout of the numpad to include a more modern double sized plus key.
It is a terminal keyboard model number 1394324.  Knicker shot...
I bolt modded it so that I could renew some slightly slack springs and change the layout.  Unfortunately the space bar is misbehaving after the bolt mod so I will have to undo the bolts and try again to get it all seated correctly.  Apart from the misbehaving spacebar it is a really cool keyboard to type on.  All the springs are as good as new.
The Keycaps are a mixture of the original set and a UK layout 101 key set from Unicomp.  The layout on the terminal keyboard was not what I was used to.  I chose to keep the simplest of the keycaps for as clean a look as possible.  The Lettered function keys open Windows Applications such as Exporer, Outlook and One Note.  The Geekhack functions as a windows key.  The Num Lock has been removed and instead now opens a calculator.
Conversion to USB is handled by Soarers mod.
http://s65.photobucket.com/user/justblair/slideshow/IBM%20122%20Key%20Terminal%20Keyboard
« Last Edit: Mon, 23 September 2013, 16:24:36 by Justblair »
Offline mr_schnrub
  • Click Click Doin the Click
« Reply #32 on: Fri, 27 September 2013, 04:33:31 »
Daily Drivers...
Buckling Spring @ Work
Buckling Spring @ Home
4 x IBM 1391401 | IBM 1390120 | IBM SSK 1397681 | Unicomp UB4041A
« Reply #33 on: Fri, 27 September 2013, 06:06:30 »
Daily Drivers...
Dr Pepper in QLD eh?  There are very few places that sill sell it in VIC.
Offline mr_schnrub
« Reply #34 on: Fri, 27 September 2013, 06:32:03 »
Coles and Woolies actually sell it. It's coming back!
For those of you outside of Australia, Dr Pepper came and went years ago...
« Reply #35 on: Sat, 28 September 2013, 03:06:26 »
Now if only Jolt would come back too ;)
Offline snoopy
  • The Flying Ace
« Reply #36 on: Sat, 28 September 2013, 08:14:22 »
Internals from an iso '86 M in a new industrial shell. Most of its time only in a box, cause I think its to big for my desk. And I prefer to buckle springs on my ssk.
37184-0
« Reply #37 on: Sat, 28 September 2013, 08:16:39 »
Could I have a link to the full res clickclack background? I used to have it but now I've lost it :(
Also, very nice M!
Offline sleepy916
« Reply #38 on: Fri, 18 October 2013, 14:22:40 »
How did I miss this thread?  ;)
I haven't used anything else since I got it working.
Offline snoopy
  • The Flying Ace
« Reply #39 on: Fri, 18 October 2013, 16:56:31 »
Nice! Maybe unprinted caps as modifiers would look better. Or do you have plans to get the modifiers also in metal?
Offline sleepy916
« Reply #40 on: Fri, 18 October 2013, 17:27:12 »
Yeah blanks on the modifiers would look better. I've just been lazy to do it. Sadly no the person who made the keys is not doing anymore anytime soon. I doubt it he will ever do the mods in metal either.
Offline snoopy
  • The Flying Ace
« Reply #41 on: Sat, 19 October 2013, 04:15:24 »
If you do the spacebar mod, you could also use a set of unprinted black keycaps. I think this would look also very good in combination with the metal keys and one of the rwb clacks :D
Offline 127001
« Reply #42 on: Mon, 28 October 2013, 19:40:32 »
Had to throw this in here too just because I'm so excited about it :P:
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #43 on: Sat, 01 November 2014, 11:03:27 »
Here is a little project I've been working on. A Unicomp 122 chopped down past an unsaver (chopped unsaver? =)). Big thanks to wcass, I pretty much copied his original idea and build. Also want to thank Dorkvader for his helpful troublehooting advice during my first bolt mod.
Not all the keys are working yet, I think I damaged some of the contacts on the membrane sheet so I'll be on the hunt for replacement membrane sheet. Once I swap it, it should be 100% functional. For now, it's just a shelf queen, lol.
Offline snoopy
  • The Flying Ace
« Reply #44 on: Sat, 01 November 2014, 11:08:36 »
Congrats on finding this old thread ;D
Also nice board and funny color :)
« Reply #45 on: Sat, 01 November 2014, 11:59:49 »
Damn, for a second I thought wcass sold you one of his custom boards. That's really awesome. Hope you post more pictures or a build log or a typing test video when it's finished :D.
Offline Badwrench
« Reply #46 on: Sat, 01 November 2014, 22:04:59 »
That is awesome.  As the CPT said, more pictures please.
« Reply #47 on: Sun, 02 November 2014, 01:13:10 »
Why did I **** up that Backspace?  And crappy phone photo.
Overall, it turned out better than I thought. The stabilized keys are all wonky and I'm trying to fix them, but otherwise it turned out well.  The case was hard to dye since I couldn't exactly fit it in the pot.  I had to pour the dye and hot water into another container and refresh it with hot water from time to time to keep it warm.  It took me about 6 hours to get it this color and it could have benefited from longer.  In either case, it didn't turn out poorly.
Oh, for reference, it's Black, Red, and Crimson iDye Poly.
Offline byker
  • Literally Canada
« Reply #48 on: Sun, 02 November 2014, 01:36:21 »
Looks like it turned out well! More pictures needed!  :p
« Reply #49 on: Sun, 02 November 2014, 18:13:05 »
