Author Topic: [GB] Custom/Switch Stickers [Shipping]  (Read 138426 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« on: Tue, 17 September 2013, 17:09:30 »
What we are getting
Switch Stickers - They make your board look pretty! The sticker is used to eliminate the small movement (left-to-right) in the plastic part of the switch, so it is not something major as oiling & greasing, but the sensitive keyboard enthusiasts could not stand that tiny flaw and made stickers that fit perfectly in that small crack of the switch.
Also helps with PCB switches, think about it, the plate already helps significantly in stabilizing the switch since it holds the bottom of the switch and the legs that hold the top half in place.  On PCB mounted switches you only have the contacts, legs, and potentially a diode or LED to stabilize it, but the top half of the housing has more room to wiggle and play.  So if the top is loose on PCB mounted, it will wobble more.  The sticker is supposed to make the top less wobbly and stabilize it more.
These stickers would go really well with this GB as it would show of your stickers!
The Design
Vinyl used will be 3mil or 4mil depending on the vinyl. Below are the three designs that will be available:
Original:
Moose (Better coverage IMO):
The sheets will be 6"x12" and have 8x16 stickers.
My review of these stickers: http://geekhack.org/index.php?topic=46665.msg992036#msg992036
The size problem has been corrected and now they fit perfectly.
Colors available
Switch stickers will be offered in two categories:
1. Fixed price. The price of each sheet has been fixed based on popularity of colors via a poll. The colors and their price are mentioned below:
2. Tiered pricing. All the available colors except eh ones above will also be available, however due to smaller order quantity and sorting, the price of these would be decided based on total quantities ordered. These price tiers are not for an individual order but for the whole GB and irrespective of the shape of the sticker. We hit price tiers as following:
Price Tier 1: Initial price tier
Price Tier 2: 50 sheets ordered for given color
Price Tier 3: 100 sheets ordered for given color
Plain Vinyl
You can also order plain vinyl if you want, you may want this for some projects of your own or get some plotting done by yourself, and since we are getting vinyls in bulk, you would be able to save money. The prices for a 1'x1' sheet are $1 for solid colors and $2 for all the other fancy stuff. Vinyl code and sample are in the below table. If you want to order in bulk or want other dimensions (In multiples of feet), PM me.
Custom Stickers
If you have some design you want made into a sticker this can be arranged at the give prices below. Any design can be plotted as long as it is in black and white.
Eg:
The black part will be made into a sticker
Complex designs can be printed on transparent sheet, thus having an opaque look or printed on white vinyl. They will then be cut along a borderline  based of your design.. Just like printing a sticker at home and cutting it out, except instead of being on paper it would be on clear or white vinyl.
Eg.
The Pikachu would be printed and cut along the white part, it can be cut without a border but there is a limitation on the detail for small sized stickers.
Costing would be $ 0.02 per sq. inch printed or plotted.
Release stickers (Area around sticker not needed removed and a clear tape added on top to peel the sticker to stick it somewhere and then remove the tape) would cost $0.09 per sq. inch.
Shipping weight for 1sq inch of vinyl is 0.175g.
All custom stickers requested so far: http://goo.gl/UdiTWe
Size (net) is the actual size of the sticker
Size(gross) is the size of the vinyl used for cutting the sticker as there are extras (around 2-3mm on each side) to accommodate releasing and cutting the stickers.
Weight and price is calculated based on the gross size of the sticker.
Minimum Order Quantity
There is no MOQ on any sticker sheet however there will be a 10 sticker MOQ on custom stickers. There is also no MOQ for plain vinyls.
Costs + Shipping
Each sheet will contain 8x16 stickers = 128 stickers folded in half and be mailed in a CD/DVD bubble mailer by Registered Indian Post.
The price for any sheet will be as it is mentioned for each color in the table above
Weight of bubble mailer + some extras (Surprise!) = 25g
Weight of one sticker sheet = 12g
Shipping will cost (Same worldwide):
$4 for first 100g
$1 for every additional 100g
So you can get upto 6 sheets in the base shipping cost ($4), and upto 7 more for each extra 100g ($1).
Weight of 1'x1' for plain vinyls is 25g.
Weight of custom stickers is mentioned in the spreadsheet above.
Maximum weight is 2000g. If you want to order more, I will have to use bulk mailer, contact me via PM as shipping varies depending on location for bulk orders.
PayPal will be the only mode for payment.
These costs have been mentioned factoring all costs such as productions, costs for getting these to me, bubble mailer package, etc as well as PayPal fees. So what you see is what you pay.
Ordering
You can place your orders here: http://goo.gl/1yZMD1
Last date to submit orders is 15th-October.
Most of the invoicing would be done in two days after that followed by payments by the end of October.
I will then order the materials and get them shipped by Novemeber end.
Please note that the order form has a second for embedded for the tiered price switch stickers.
Acknowledgements
I would like to thank the following members:
mkawa - inspiring me to go ahead and do this
infiniti - for cutting and tetsing the true first batch of the stickers
BlueBar - Providing scans of the Korean Sticker Sheet
jdcarpe - Volunteering to inspect quality of the sticker sheet
pillon - For original design files at KBDMania
Bulk Orders
I would like to invite vendors to contact me for bulk orders if they would like to stock these in their online stores, I will opt for bulk ordering options in those cases and see if prices can be reduced further by eliminating extras that ship out to other members.
« Last Edit: Wed, 16 April 2014, 03:49:49 by MOZ »
Offline MOZ
  • Busy making stuff
Re: [GB] Custom/Switch Stickers - ONLY $1 for 128 stickers - Ordering till 15-Oct
« Reply #2 on: Tue, 17 September 2013, 17:11:48 »
I know the OP is slightly longish and so is the form, especially the fact that there is a second form inside the first one. Sorry for the inconveniences, but there are just that many options.
Also remember, to keep your edit link at the end of the form copied somewhere as I will be adding more custom stickers as we move along, and you may want to order those.
« Last Edit: Tue, 17 September 2013, 17:17:02 by MOZ »
Offline MOZ
  • Busy making stuff
« Reply #3 on: Tue, 17 September 2013, 22:41:05 »
Finally approved, let the flood gates open!
Offline JPG
  • Model F is my new passion!
« Reply #4 on: Tue, 17 September 2013, 22:43:01 »
Here we go!
Offline ComradeSniper
  • HHKB Pro
« Reply #5 on: Tue, 17 September 2013, 23:03:01 »
Awesome, ordered a couple of sheets. Hopefully I filled out the form correctly.
Offline JPG
« Reply #6 on: Tue, 17 September 2013, 23:08:43 »
Ordered. By the way, there's an error in the color choice. You show flake light blue twice, but not flake green. It's still available in the list.
Offline MKULTRA
  • telling it how it is
« Reply #7 on: Tue, 17 September 2013, 23:29:55 »
Will look through all the options and make my order later.  Good deal man.
Offline MOZ
  • Busy making stuff
« Reply #8 on: Tue, 17 September 2013, 23:32:20 »
I'll correct that.
Offline Xenderwind
« Reply #9 on: Tue, 17 September 2013, 23:40:51 »
Wow I did not realize how cheap custom stickers would be....expect an order from me once I figure out what I want :D.  Though I may need some help with converting into a stickerable vector :S.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline Defying
  • (suffer on)
« Reply #10 on: Tue, 17 September 2013, 23:44:00 »
Ordered. :thumb:
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #11 on: Tue, 17 September 2013, 23:44:42 »
Order placed MOZ  :thumb:
Offline MOZ
  • Busy making stuff
« Reply #12 on: Tue, 17 September 2013, 23:46:31 »
I'll help anyone that needs help with converting to vector, given I have time.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #13 on: Wed, 18 September 2013, 01:11:50 »
Going to order all the crazy colors!!!!!1111one
Offline LechnerDE
« Reply #14 on: Wed, 18 September 2013, 01:49:44 »
Same here. I will probably order one of every base color and then add some random stuff to stay at 200g :)
Offline ImaMoFoThief
  • I play DotA!
« Reply #15 on: Wed, 18 September 2013, 02:21:31 »
going to order later
(Xender) and size probably matters
(Xender) but dont quote me on that
(Xender) and i just realized what i said
Offline oaklandishh
« Reply #16 on: Wed, 18 September 2013, 02:40:26 »
Ordered. Thanks!
« Reply #17 on: Wed, 18 September 2013, 07:00:59 »
Ordered  :thumb:
« Last Edit: Wed, 18 September 2013, 10:36:55 by SpAmRaY »
Offline do_Og@n
« Reply #18 on: Wed, 18 September 2013, 10:15:53 »
Order has been placed....that's a whole lotta stickers.
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #19 on: Wed, 18 September 2013, 10:42:26 »
Ordered :thumb:
Offline MOZ
  • Busy making stuff
« Reply #20 on: Wed, 18 September 2013, 11:07:15 »
I'm already getting scared, how I would invoice you all  :-[
Offline YongJK
« Reply #21 on: Wed, 18 September 2013, 18:40:14 »
could you check your Inbox ?
I've pm you about custom stickers yesterday
Keyboard: PLU ML87 Mx Blue
Offline MOZ
  • Busy making stuff
« Reply #22 on: Thu, 19 September 2013, 01:17:08 »
I did get the PM, just a little busy with the other projects to convert them to vector. I will do them later today.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #23 on: Thu, 19 September 2013, 04:22:39 »
Ordered! :cool:
Are there any ways to automate invoicing through paypal?
Offline piberry
« Reply #24 on: Thu, 19 September 2013, 04:43:20 »
ordered!
Offline j2c8w6f8
« Reply #25 on: Thu, 19 September 2013, 05:54:40 »
Amazing!
« Reply #26 on: Thu, 19 September 2013, 13:54:37 »
My avatar is a less than 300 px square, but it should be easily recognizable nontheless. If not, I can reupload one in a larger size.
Offline MOZ
  • Busy making stuff
« Reply #27 on: Thu, 19 September 2013, 13:56:36 »
A larger size would be appreciated
« Reply #28 on: Thu, 19 September 2013, 14:05:44 »
Doh , I downsized my image to 300 x 300 ish because I thought that was max.
Offline fydo
  • Meow!
« Reply #29 on: Thu, 19 September 2013, 14:20:36 »
Ah, I'll have to re-upload a bigger one too!
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline MOZ
  • Busy making stuff
« Reply #30 on: Thu, 19 September 2013, 14:35:45 »
300x300 is the preferred size, if you uploaded anything bigger I would gave to downsize, so don't do it.
Offline naokira
  • The King in the North
« Reply #31 on: Thu, 19 September 2013, 18:06:49 »
How big will be the vinyl sticker?
FaceW in LZ-CE
Offline MOZ
  • Busy making stuff
« Reply #32 on: Thu, 19 September 2013, 18:12:59 »
Which sticker sir?
Offline naokira
« Reply #33 on: Fri, 20 September 2013, 04:53:18 »
Which sticker sir?
The Plain Vinyl ones :)
FaceW in LZ-CE
Offline MOZ
  • Busy making stuff
« Reply #34 on: Fri, 20 September 2013, 05:24:46 »
Which sticker sir?
Whatever size you want, but in multiples of feet, so 1'x1' is minimum.
Offline naokira
« Reply #35 on: Fri, 20 September 2013, 05:27:28 »
Which sticker sir?
Oh okay. Is there any limit on the size? it would be a pain for the shipping if I go 7x7 ya? hueuhe
FaceW in LZ-CE
Offline MOZ
  • Busy making stuff
« Reply #36 on: Fri, 20 September 2013, 06:06:44 »
Which sticker sir?
Maximum I an do in width is 2'. Sorry :(
Offline naokira
« Reply #37 on: Fri, 20 September 2013, 06:10:01 »
Which sticker sir?
And that will still be 1$? assuming i picked the not so fancy ones. sorry for all these questions! haha
FaceW in LZ-CE
Offline Tym
« Reply #38 on: Fri, 20 September 2013, 06:11:09 »
Maximum of 2 and minimum of 1 lol?
So either 1 or 2 ft?
Offline MOZ
  • Busy making stuff
« Reply #39 on: Fri, 20 September 2013, 06:22:15 »
PMed you. I'm totally confused.
Offline MOZ
  • Busy making stuff
« Reply #40 on: Fri, 20 September 2013, 06:22:44 »
As far as width goes, length you can go a mile, for all I care :P
Offline ssdt
« Reply #41 on: Sat, 21 September 2013, 04:17:40 »
already ordered :)
thanks for the groupbuy, MOZ!
#donated, too :D
Poker II         HHKB Pro 2
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” - Aristotle
Offline MOZ
  • Busy making stuff
« Reply #42 on: Sat, 21 September 2013, 07:01:38 »
already ordered :)
#donated, too :D
Thank you kind sir.
Offline YongJK
« Reply #43 on: Sat, 21 September 2013, 07:09:00 »
Still waiting for my custom sticker up to google doc.
Offline MOZ
  • Busy making stuff
« Reply #44 on: Sat, 21 September 2013, 07:15:34 »
I'll add it later tonight, sorry for the delay.
Offline YongJK
« Reply #45 on: Sat, 21 September 2013, 07:19:14 »
No worries. Don't sorry for that.  :thumb:
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #46 on: Sun, 22 September 2013, 13:10:43 »
Ordered. :D
Offline thoere
« Reply #47 on: Sun, 22 September 2013, 22:04:27 »
Ordered. Best deal for stickers anywhere.
Offline MOZ
  • Busy making stuff
« Reply #48 on: Mon, 23 September 2013, 13:03:35 »
Over 600 stickers ordered! Keep em flowing!
Offline do_Og@n
« Reply #49 on: Mon, 23 September 2013, 15:26:50 »
Awesome, glad to see this GB moving along. Keep it up everybody!!!!
Thanks again for this GB MOZ!!!
