Author Topic: Need 3D model of Cherry MX brown keyswitch  (Read 7681 times)
Offline cool-RR
« on: Sun, 22 September 2013, 07:22:17 »
Hi everybody!
I'd like to design my keyboard concept in 3DS Max. I want a 3d model of the Cherry MX brown keyswitch, so I could use it in my design (Mainly to see whether it'll fit.)
Does anyone happen to have a 3D model of that switch?
Thanks,
Ram.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
Re: Need 3D model of Cherry MX brown keyswitch
« Reply #1 on: Sun, 22 September 2013, 11:40:27 »
Is this what you're looking for? The file type in .skp but you can use this extension to import it.
HHKB Pro 2   SmallFry Keyboard
Offline cool-RR
« Reply #2 on: Sun, 22 September 2013, 11:56:05 »
Holy ******** yes!!!
Do you know whether I could count on its size to be faithful to the actual button?
Thanks,
Ram.
  • HHKB Pro
« Reply #3 on: Sun, 22 September 2013, 12:24:09 »
Thanks,
Ram.
Yes, I used it for my numberpad drawing here and the scale was correct. It is in mm.
Offline cool-RR
« Reply #4 on: Sun, 22 September 2013, 12:30:35 »
Awesome, thank you!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #5 on: Sun, 22 September 2013, 20:24:28 »
Added to CAD resources.
« Reply #6 on: Sun, 22 September 2013, 21:00:27 »
Interesting - great model.
What about a keycap?
It has been a good few months (maybe around 6) since someone last asked - has anyone seen a model of a keycap?
  • HHKB Pro
« Reply #7 on: Mon, 23 September 2013, 00:39:45 »
Last time someone asked I made a drawing of a DCS OEM R4 keycap. Download. I would be happy to draw a DSA keycap or maybe a full DCS set if you would like.
« Reply #8 on: Mon, 23 September 2013, 00:47:10 »
I get:
Invalid Link
This link wasn't well formed.
  • HHKB Pro
« Reply #9 on: Mon, 23 September 2013, 00:53:22 »
I get:
Invalid Link
I hate mobile phones sometimes. Here is the direct link
https://www.dropbox.com/s/qhzkin49eyggnap/MXkeycap.dwg
« Reply #10 on: Mon, 23 September 2013, 00:58:51 »
Got it, thanks.
Now I need to work out something to do with it ...
  • HHKB Pro
« Reply #11 on: Mon, 23 September 2013, 01:08:13 »
Got it, thanks.
I believe the last guy that requested a model of a keycap wanted to use it to 3D print. Just take a logo or symbol and subtract it from the top. Then you have have your own custom "engraved" keycap.
