Author Topic: What keyboards use 6-unit spacebar?  (Read 8246 times)
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« on: Tue, 24 September 2013, 08:17:15 »
I've got a bunch of 6-unit spacebars that I stupidly purchased for my keycap flocking experiment? (see my signature for the link) -- does anyone know which keyboards make use of a 6-unit spacebar from SP? Here's a picture of the bottom of the spacebar:
Quote from: Samuel Adams
Re: What keyboards use 6-unit spacebar?
« Reply #1 on: Tue, 24 September 2013, 08:20:12 »
The G81-7000 does. I bought caps from that keyboard for my Epsilon and it has a 6x spacebar.
« Reply #2 on: Tue, 24 September 2013, 08:54:40 »
BUT, it's not the same.  They are 6x space bars (Some Cherry G80 also have them) but they don't have the same stem configuration as SP's space bars.  The Cherry has offcenter stem and SP are center stem.
Deskthority wiki is the best resource: http://deskthority.net/wiki/Space_bar
Offline Moosecraft
  • HHKB Pro
« Reply #3 on: Tue, 24 September 2013, 09:13:36 »
Razer blackwidow and similar OEM boards.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #4 on: Tue, 24 September 2013, 09:22:20 »
Yeah, I saw Deskthority's article on the 6-unit -- seems like very few 'boards use them.
« Reply #5 on: Tue, 24 September 2013, 09:28:36 »
I wish they were more common.  More buttons on the bottom row is a good thing.  I like the 87u's 1.5,1,1.5,6,1.5,1,1,1.5 row
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #6 on: Tue, 24 September 2013, 11:12:49 »
Me too!
Thanks everyone for the information.
I've got some extra 6-units that I'm hoping to flock. I figure if no one could ever use them, what would be the point?
« Reply #7 on: Tue, 24 September 2013, 11:14:12 »
Me too!
novelty key!!! put it on a keychain haha.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #8 on: Tue, 24 September 2013, 12:18:33 »
Me too!
LOL, yeah maybe -- that's not a bad idea.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Tue, 24 September 2013, 15:53:06 »
I'm not sure if the stem spacing on those will work with iOne stuff or not, but majority iOne OEM stuff (Razer, Max, Tessoro, CM Pro, Adesso, Monoprice, Qpad, Qtronix, etc.) has a 6. The only thing I know for sure that uses SP 6 unit with that stem spacing is the TG3/Deck BL82.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #10 on: Wed, 25 September 2013, 23:03:13 »
Just a touch off topic but can anyone confirm if the stabilizer spacing listed the the 9.75u space bar on that deskthority link matches the the ones from the 9.75u or the 10 space bar from sp?
Edit   I would assume that they are the same.  After a bit more digging it appears that so made the caps for the keyboard it came off of in the first place.
« Last Edit: Wed, 25 September 2013, 23:27:23 by Melvang »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #11 on: Fri, 27 September 2013, 13:35:13 »
Another question -- does anyone know if the SP universal spacebars (6.25) are any different from the spacebars sold at EliteKeyboards? Are they basically the same?
