Author Topic: Upgrading QFR  (Read 3762 times)
Offline IonutZ
  • Stay awhile and listen
    • SC
Upgrading QFR
« on: Sun, 06 October 2013, 12:54:25 »
Does the QFR use a PCB or Plate? I'm looking to get some replacement Cherry switches for it but I don't know whether I need the Plate Mount (without pins) or the PCB Mount (with pins) for it?
Thanks
Offline dragonxx21
Re: Upgrading QFR
« Reply #1 on: Sun, 06 October 2013, 12:57:01 »
Thanks
Both. It has both a PCB as well as a Plate.
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
Re: Upgrading QFR
« Reply #2 on: Sun, 06 October 2013, 13:09:15 »
You can't only have a plate :P
But what I think the OP meant was are the switches plate mounted or PCB mounted, then answer is, they are plate mounted.
Offline dragonxx21
Re: Upgrading QFR
« Reply #3 on: Sun, 06 October 2013, 13:11:44 »
Direct wiring.
Keyboards Owned:
Offline MOZ
  • Busy making stuff
Re: Upgrading QFR
« Reply #4 on: Sun, 06 October 2013, 13:18:08 »
I doubt CM would sell a direct wired keyboard, I really do.
Re: Upgrading QFR
« Reply #5 on: Sun, 06 October 2013, 13:55:01 »
I think the only keyboards with no PCB are DIY.
@IonutZ, If you get PCB-mount switches for the QFR, you will have to trim the pins off, or swap the bases with the PCB mount that come with the QFR.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Upgrading QFR
« Reply #6 on: Sun, 06 October 2013, 15:43:43 »
a direct wired production keyboard would be hilarious, but would also cost a million dollars. all production keyboards have electrical wiring a proper FR-4 PCB. the major thing that varies between the pcbs vended by the different keyboard manufacturers is the amount of copper (very little is needed to carry signal, but a more copper and more fiberglass means that the pcb is more rigid and provides more support to the switches. additionally, PCB circuits can have anywhere from 1 to 8 layers. inter-layer communication is carried over something called a via (which is what the company VIA is actually named after -- fun fact!) which is just a metallized hole in a layer that connects to a trace on another layer. the maximum number of layers you would ever need on a cherry PCB is basically 2. if you're using more than that you're basically doing it wrong. topre PCBs are almost all 4-layer pcbs, but then again, they are capacitive, which is very very tricky to work out electrically, and they have no metal plates.
almost all production cherry or cherry-like boards these days use metal plates and the corresponding plate-mount cherry switches (although note that pcb-mount switches are fully plate-compatible, they just have extra studs to further attach themselves mechanically to the PCB. the plate thickness of a cherry switch is fixed at 0.06", or about 16 gauge in imperial sheet measurement terms. however, the material is completely open, and some keyboards have aluminum plates (NOT rigid, extremely flexible until you get to aerospace grade aluminum alloys), mild annealed steel (the least rigid of all steels, and what ducky tends to use), high carbon steels (which i'm not aware of anyone using) or stainless steel (i can confirm that most if not all of the CM Storm quickfire series uses a stainless steel alloy for their plates). i've written briefly about how solid i feel the CM storm stainless plates are. i also think the red powdercoated one looks BOSS. that said, like levar burton would say, "you don't have take my word on it.. take a look, it's in a book reading rainbow!"
ok it's a keyboard not a book, but you get the idea.
Re: Upgrading QFR
« Reply #7 on: Sun, 06 October 2013, 16:20:51 »
What would be cool is a socket-mount switch, where you can just unplug a switch from the PCB rather than unsoldering it.
Offline bpiphany
Re: Upgrading QFR
« Reply #8 on: Sat, 12 October 2013, 11:35:38 »
I would think most Realforce keyboards use a metal mounting plate. But then, of course, I have only seen the Swedish layout ones. The happy hacking has the sliders/slider mounts fitted directly into the plastic case. Other than that I have nothing to add.
Re: Upgrading QFR
« Reply #9 on: Sat, 12 October 2013, 11:43:55 »
Someone in China prototyped this, I can't find the thread right now.
Offline HotKillerZzz
  • Ammesia
Re: Upgrading QFR
« Reply #10 on: Tue, 12 November 2013, 09:39:04 »
its actually quite an experience to desolder and solder new switches. most problems can be solved easily. Might be quite a tedious process but its quite fun actually!
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
Re: Upgrading QFR
« Reply #11 on: Tue, 12 November 2013, 09:42:12 »
I did this to my QFR, as long as you are okay with a solder iron you should be fine.
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
