Author Topic: Blank Black 87 Key POM set  (Read 4308 times)
Offline do_Og@n
« on: Sun, 06 October 2013, 14:17:27 »
I wouldn't say this is the greatest deal out there but I wanted to bring it to everybody's attention.
They are under $17 with free shipping. I've ordered a pair myself and will update this thread once I get them.
http://www.banggood.com/POM-87-Set-Blank-Key-Caps-Black-Keycaps-For-Cherry-MX-Keyboard-p-84081.html
Offline dante
Re: Blank Black 87 Key POM set
« Reply #1 on: Sun, 06 October 2013, 14:26:30 »
I knew about those before starting my group buy but wanted something a little thicker and Cherry profile.
Offline Linkbane
« Reply #2 on: Mon, 07 October 2013, 22:04:56 »
Wow, they have a White also. I think that I'm going to order these.
EDIT: Wait no, those are PBT. There are an 84-set of POM caps that are still in stock.
« Last Edit: Mon, 07 October 2013, 22:09:29 by Linkbane »
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
« Reply #3 on: Tue, 08 October 2013, 01:43:33 »
Agreed! Sign up for dante's group buy instead. :) We need more people!
http://geekhack.org/index.php?topic=49081.0
Offline dotancohen
    • Dotan Cohen
« Reply #4 on: Tue, 08 October 2013, 02:01:51 »
What is the difference? I think that GH once had a wiki that explains it, but the page is now blank: http://wiki.geekhack.org/index.php?title=Keycap_Basics
Offline dotancohen
    • Dotan Cohen
« Reply #5 on: Tue, 08 October 2013, 02:03:36 »
Is the Cherry profile different from any other keyboard? My two mechanical keyboards have Cherry keys (PBT Race and Ducky), will these keycaps be a different profile? Again, this information was once on the wiki but it seems gone now.
Offline dotancohen
    • Dotan Cohen
« Reply #6 on: Tue, 08 October 2013, 07:08:33 »
Those are 50% more expensive _without_ shipping than this deal is _with_ shipping. What is better about dante's keycaps group buy?
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #7 on: Tue, 08 October 2013, 08:28:13 »
http://deskthority.net/wiki/Keyboard_profile
They are thicker...
More material -> Higher costs!
A Ghost From The Past
Offline goobus
  • HHKB Elite
« Reply #8 on: Tue, 08 October 2013, 08:28:37 »
Uh I think if you read Dante's post a little closer you will realize the answer is there.
Offline do_Og@n
« Reply #9 on: Tue, 08 October 2013, 09:16:30 »
Banggood's POM caps:
- 87 Keys
- OEM Profile (higher than Cherry)
- Can rip out switch stems
Dante's Post POM caps:
- 104 Keys
- Cherry Profile
- Thicker (some say they feel better)
For the price they are a good deal but I only need 87 keycaps because I don't own a fullsize keyboard with MX Switches.
« Reply #10 on: Tue, 08 October 2013, 10:42:26 »
Cherry profile is differnet than the "oem profile" those other keys you have are. Many people (including myself) prefer cherry profile. Another noticeable difference is that the ends of cherry keycaps are pointed, whereas oem and especially SP profile keycaps are rounded.
I have two OEM profile keys on this keyboard right now: capslock and spacebar. I don't use one of those much, but you can easily see and feel the difference in height. it doesn't bother me.
What I want to see is extra POM spacebars be available. You can never have too many POM (or PBT) spacebars.
PBT and POM are different palstics with different properties.
For example, POM is much less hard, much more tough, and has a lower friction coefficient than PBT
- 87 Keys
Wow, really? I've not had POM do that to me before, as the friction is so low.
Offline do_Og@n
« Reply #11 on: Tue, 08 October 2013, 11:24:31 »
@dorkvader - it didn't happen to me but someone else out there had bad luck with them pulling out the switch stem. I'm guessing it's due to poor manufacturing or bad plastic molds that don't fit the MX Switch quite right.
Offline whiteduck
« Reply #12 on: Sat, 12 October 2013, 18:29:24 »
Just put these on my WASD v2 with clears and tried removing them.  First few came off with considerable wiggling.  Then sure enough POP ,  stem pulled out of the fukin switch.
FML t.t
-wd
Offline do_Og@n
« Reply #13 on: Sat, 12 October 2013, 20:26:08 »
I'm glad I knew about this before I tried putting them on a board. I'll be tweaking them a bit before I put them on. I'm hoping I can just heat them up a bit and put them on a stand alone switch.
To bad it's to late to cancel the order. But, if you look on the bright side maybe that's a good way to replace some stems without desoldering.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #14 on: Sat, 12 October 2013, 21:40:42 »
Other people have suggested potentially putting a bit of lube in the cap before you put them on to help with the super tight fit...
Will try that when my pbt caps come from them to see if it helps...
