Author Topic: Poker 2 spacebar compatibility  (Read 3481 times)
Offline skuko
« on: Tue, 08 October 2013, 03:41:30 »
hey all,
i'm fairly sure someone has asked this already, but i didn't find it....
i'm curious about the 60% boards now and keen on getting a poker, but i need to know whether it has standard caps, especially the spacebar.
will i.e. filco caps fit it? i mean both length and stem-wise.
i'm mostly concerned about the SA profile calm depths GB, which i'm a part of :)
thanks
Offline Reomero
  • Manual breather
Re: Poker 2 spacebar compatibility
« Reply #1 on: Tue, 08 October 2013, 03:49:18 »
Yep, the Poker has a 'standard' 6.25x spacebar so those GB sets will fit.
Offline PointyFox
« Reply #2 on: Tue, 08 October 2013, 03:54:34 »
All standard MX keycaps fit on the Poker.
Offline skuko
« Reply #3 on: Tue, 08 October 2013, 03:58:56 »
YAY, me happy panda :)
thanks again
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Tue, 08 October 2013, 04:07:04 »
Not true
Cherry spacebars, caps locks, and right shifts might not work with the poker. The spacebar since the stem layout, the caps lock since it's not center stemmed and the shift if they are the G80-1800 sized shift
Offline skuko
« Reply #5 on: Tue, 08 October 2013, 04:18:29 »
Not true
well, i guess the question should be
"if the spacebar fits a filco, will it fit a poker 2?"
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Tue, 08 October 2013, 04:23:03 »
Not true
Yes it will.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #7 on: Tue, 08 October 2013, 04:45:35 »
^What's they said. It will fit as it has a standard layout. :D
Offline PointyFox
« Reply #8 on: Wed, 09 October 2013, 02:15:44 »
I don't consider those Cherry keycaps "standard" keycaps, since I think they only fit Cherrys.
Offline SNF
« Reply #9 on: Wed, 09 October 2013, 04:03:04 »
that's one of the beauty of poker boards, standard layout for custom caps  :thumb:
Offline skuko
« Reply #10 on: Thu, 10 October 2013, 03:30:43 »
hmm, now i have a different question. i'm kinda curious as to how it would be possible to simulate the arrow cluster on a poker apart from the obvious FN layer. i started playing some older DOS games (namely flashback, oh the nostalgia!), which don't offer the possibility to remap keys. could i program my arrow cluster to some other keys, i.e. PL;'  ?
to be exact, flashback uses the arrow keys, shift, tab and enter, afaik.
Offline saturnotaku
« Reply #11 on: Thu, 10 October 2013, 09:41:11 »
You can program the arrow keys to be elsewhere. Problem is you have to be holding the Pn key in order to do it. This is one of the reasons why I got rid of my Poker. I just could not get used to the layout. I moved to a QFR and am enjoying it much more.
Offline AuRinBei
« Reply #12 on: Thu, 10 October 2013, 10:30:12 »
You don't technically have to be holding the PN key. You can put it into program lock mode by pressing FN+Right Shift. You could program OKL; as arrow keys and then switch to the program layer when playing those kinds of games.
87u || Poker 2
Offline saturnotaku
« Reply #13 on: Thu, 10 October 2013, 10:41:22 »
Very true. It's useful as a temporary measure for those situations.
