Author Topic: Looking to get Custom Keycap made  (Read 4099 times)
Offline acidtrip69
« on: Fri, 11 October 2013, 15:28:43 »
Ok, I'm looking to get a custume keycap made. Were would i go to get that don. i Want a white PTB cap with a image on it in blue or it can be made i would like it in color like in pic. I would like it to be double shot or dye-sublimation
i would like that 38703-0
« Last Edit: Fri, 11 October 2013, 15:31:42 by acidtrip69 »
Offline JPG
  • Model F is my new passion!
Re: Looking to get Custom Keycap made
« Reply #1 on: Fri, 11 October 2013, 15:34:54 »
Forget double shot unless you budget is BIG. And for dye-sub, you will still need to buy a whole lot of them. Maybe ask IMSTO or look with Ivan or someone else used to organize group buys.
Offline Tym
« Reply #2 on: Fri, 11 October 2013, 15:42:25 »
I'd have a guess that image is too detailed to Dye-sub i think.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3 on: Fri, 11 October 2013, 15:49:38 »
What would it look like in blue? Can you give us an idea?
|||My other keyboards :
x
Offline acidtrip69
« Reply #4 on: Fri, 11 October 2013, 15:53:52 »
i guess it doesn't have to be that detailed. just look nice and really close enough to the image. To get this made Would anyone want to get in to a group buy to make this happen ? Maybe will have different color options.
« Last Edit: Fri, 11 October 2013, 15:57:58 by acidtrip69 »
Offline phetto
  • HHKB JP
« Reply #5 on: Fri, 11 October 2013, 15:55:02 »
Are you tripping right now?
Offline esoomenona
  • Gnillort?
« Reply #6 on: Fri, 11 October 2013, 15:58:45 »
I don't think it's too detailed for a dyesub. Remove the colored background, make it centered on a 600x600, and post it in lysol's IC for dyesub caps.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Fri, 11 October 2013, 16:16:07 »
It's certainly technically possible to do, imsto have done photographs before...
Offline acidtrip69
« Reply #8 on: Fri, 11 October 2013, 17:53:33 »
i don't really want the white background just the pic of matilda.
« Reply #9 on: Fri, 11 October 2013, 17:55:24 »
imsto can do it. He can do 1 offs too. It's just that shipping will be ridiculous ^_^
Offline acidtrip69
« Reply #10 on: Fri, 11 October 2013, 18:00:20 »
like i asked. Would anyone want to make and join in a group buy so we lower the cost ? ^_^ Will make different color options and or maybe the one that looks close to the pic.
Offline Tym
« Reply #11 on: Fri, 11 October 2013, 18:01:15 »
Not my thing, but what is it/where is it from?
« Reply #12 on: Fri, 11 October 2013, 20:19:25 »
It's a young Natalie Portman from the film Léon.
Using white key is going to be your only option if you want it to come out half way decent looking.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #13 on: Sat, 12 October 2013, 04:23:19 »
uh that's nice. I want keycaps with boobs
Offline acidtrip69
« Reply #14 on: Sun, 13 October 2013, 15:02:44 »
what the program people use to make them mockups of key caps ? of does anyone here make mockups ? cuz i would like your help.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #15 on: Sun, 13 October 2013, 15:14:06 »
I can help. PM me.
