Author Topic: Cherry mx browns feeling different on different boards?  (Read 3026 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sat, 12 October 2013, 11:17:22 »
I went to bestbuy to buy a mouse mat and station cash for planet side 2. I happen to pass by Logitech "gaming" peripherals. I took advantage and started typing, it almost felt like my reds... Is that normal? Or just the quality of construction on the boards.
Offline C5Allroad
Re: Cherry mx browns feeling different on different boards?
« Reply #2 on: Sat, 12 October 2013, 11:22:39 »
Oh ok thanks.  :D
I'm glad then that my ducky feels a lot better!
Offline Tony
« Reply #3 on: Sat, 12 October 2013, 12:21:41 »
Heavier keycaps -> Need less force to actuate, i.e. to go pass the bump -> Feel like Red.
Offline Photoelectric
« Reply #4 on: Sat, 12 October 2013, 12:23:57 »
Yes, absolutely.  And Ducky Shine caps have very special feel to them (well, those translucent coated ABS caps of OEM profile).  I think they work better with some switches.  I have stock Clears with thin PBTs and stock Clears on a Ducky with Shine caps, and I prefer them on the Ducky.
Offline ZeodoHokill
« Reply #5 on: Sat, 12 October 2013, 12:28:42 »
The feeling is different even between Filco Majestouch and Ducky, both of them are red switch, but Filco switch feel more solid and heavy.
Offline Thimplum
  • Master of all Ponies
« Reply #6 on: Sat, 12 October 2013, 16:55:52 »
Switches always feel different on different boards. KMAC 2 with browns feel different than a qfr
TP4 FOR ADMIN 2013
Offline babyface
« Reply #7 on: Sun, 13 October 2013, 22:47:05 »
Does this mean I now have to obtain a board from every manufacture with the same switch in addition to having a board with every switch? :p
Where do you get the idea that an LZ-GH is basically a filco??
« Reply #8 on: Sun, 13 October 2013, 22:57:47 »
Generally not.
A switch might feel different due to different plate thickness, case material, case thickness, plate vs. PCB mount and so on.
If you extract one switch from each keyboard (switches of the same type) you would probably find that they were pretty much identical.
Offline babyface
« Reply #9 on: Sun, 13 October 2013, 23:05:59 »
Haha, yeah. I was being sarcastic.
« Reply #10 on: Sun, 13 October 2013, 23:08:14 »
I could kinda tell, although you are on the right track to true Geekhackness.
Offline babyface
« Reply #11 on: Sun, 13 October 2013, 23:09:34 »
Thank you Master Rowdy
« Reply #12 on: Sun, 13 October 2013, 23:32:57 »
I am merely the Church of Halverson Pope, Australian Chapter.
Your Holiness is a conventional term of reference, but Your Sharkiness would seem to be more appropriate.
:cool: :)) :p
Offline Oobly
« Reply #13 on: Mon, 14 October 2013, 02:19:56 »
I agree on the keycaps thing. If it was the G710+, they have o-rings pre-installed. That could make a difference, too.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline C5Allroad
« Reply #14 on: Mon, 14 October 2013, 06:24:33 »
Right but I went slowly to feel the bump, it was barely there... What kind of o-rings does it use?
