Author Topic: Mechanical Keyboard in UK for Mac?  (Read 3646 times)
Offline JapaneseKnotweed
« on: Mon, 14 October 2013, 05:22:54 »
Hi,
I'm new to this forum and the world of mechanical keyboards. I recently bought a Cherry G80 for one of my work's computers and I'm happy with it. I'm now looking to get a mechanical keyboard for use with my Macbook Pro 13inch that I have in a docking station at home. I'm looking for some advice on products that will meet the following requirements:
- UK layout of keys
- Mac keys (cmd, function for brightness, audio controls etc)
Any help will be much appreciated.
Thanks
GR
Re: Mechanical Keyboard in UK for Mac?
« Reply #1 on: Mon, 14 October 2013, 05:28:43 »
sorry. Just realised that I posted this in the wrong part of the forum...
Offline viowastaken
« Reply #2 on: Mon, 14 October 2013, 13:36:08 »
In my exprience most modern USB mechanical keyboards will work fine with a mac.
The functionality of the modifier keys (Windows etc) are simply converted to the CMD function. If are asking specifically about the keycaps that say CMD etc, I have seen sets with them in it. Otherwise there are complete keyboards that are "specifically made for mac" like the das:
http://www.amazon.com/Das-Keyboard-Professional-Model-DASK3PROMS1MACCLI/dp/B003ZG9T62
Then there's this one, aka the modern extended apple keyboard: http://matias.ca/tactilepro3/
I don't think the daskeyboard has a UK iso layout, but the matias one does.
Good luck.
Filco Majestouch Tenkeyless Cherry MX Brown with Ducky thick PBT white/grey
« Reply #3 on: Tue, 15 October 2013, 10:55:51 »
Thanks for your advice. Both keyboards look good but they are pretty pricey.
Does anyone know where I can get some key caps for the Cherry G80 in the UK so that I can have some of the Mac's function keys on show?
Thanks
Offline viowastaken
« Reply #4 on: Tue, 15 October 2013, 12:25:52 »
Are you dependent on buying them within the UK? if so I think that may be a bit hard.
Otherwise just google mac cherry mx keycaps and you'll find what you need. Most are in ABS/POM though, so be aware of that. Personally I loathe ABS. POM is fine and PBT is pure sex.
