Author Topic: Do mx browns feel different on cherry stabilizers compared to mx blues?  (Read 4683 times)
Offline mitchellstu
Hey guys I have a Ducky Shine 2 with mx blues and don't like the feel of cherry stablisers (especially the left shift). I'm planning on buying another keyboard with mx browns (either Filco or Ducky (again)) and would like to know if cherry stabilizers feel "better" when using brown switches? Thanks (if not then Filco is my best bet as costar seems like it is the way to go)
Offline The_Beast
  • I like wood ಠ_๏
Re: Do mx browns feel different on cherry stabilizers compared to mx blues?
« Reply #1 on: Tue, 15 October 2013, 03:55:06 »
Different people like different stabilizers
You may like cherry stabilized browns, others may like costar stabilized browns....
Offline mitchellstu
« Reply #2 on: Tue, 15 October 2013, 04:01:16 »
Ok thanks.
« Reply #3 on: Tue, 15 October 2013, 04:37:07 »
Some people feel that Cherry stabilisers are mushy regardless of the switch they are using.
I would guess that if you have stiffer switches e.g. MX blacks, then the stabilisers might not feel quite so mush as you would be habitually using more force to press the keys and thus bypass the point of mushiness.
Or something.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Tue, 15 October 2013, 04:38:24 »
Cherry stabilizers are mushy, they will generally feel the same throughout
Offline mitchellstu
« Reply #5 on: Tue, 15 October 2013, 04:55:26 »
Thank you both. I guess I'm gonna buy a Filco. Can't stand to game with the left shift key, doesn't feel right.
Offline terran5992
« Reply #6 on: Tue, 15 October 2013, 04:56:48 »
Good choice, Filco is a great board, and uses costar stabalizers
Offline BlueBär
« Reply #7 on: Tue, 15 October 2013, 05:00:11 »
You can also lube and clip your Cherry stabilizers which will improve their feel, for more info follow the link in my sig.
Offline mitchellstu
« Reply #8 on: Tue, 15 October 2013, 05:12:07 »
Thanks for your help. Since the Cherry stabilisers on my Ducky are plate mounted, I cbf desoldering :D
Offline Hyde
  • White Tofu Extraordinaire
« Reply #9 on: Tue, 15 October 2013, 08:52:08 »
It's pretty much what's stopping me from buying a Ducky.  Even though people tell me I can do the clip mod but I don't feel like de-soldering every single switches.
Offline BlueBär
« Reply #10 on: Tue, 15 October 2013, 10:18:02 »
Hmm, I never had my hands on a plate mounted Cherry stabilizer, isn't it possible to get some lube in there with a syringe or something similar? It's hard to tell for me from just looking at images.
Offline laffindude
« Reply #11 on: Tue, 15 October 2013, 10:20:41 »
You only need to desolder 1 switch to remove the particular stabilizer. That and you don't need to clip mod this year's Ducky. They've already been clipped.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Tue, 15 October 2013, 11:11:22 »
You can pop the wire out to lube the points it makes contact with the plastic even on plate mount without taking the switch out. Just pop one side up at a time, and pull it out. There is just enough play when you torque it to manage it. Be patient when putting it back in place, it can be somewhat irritating. If it's PCB mount with a plate on top, you should have much clearer access to the points where the wire clips into the plastic. Just do one side at a time as well to keep it from coming totally apart and falling inside.
Also plate mount don't (or shouldn't at least) make any contact with the PCB underneath so they really shouldn't have any 'mushy' feeling anyway. It's the little 'shocks' on the bottom of the PCB mount variety that give it the 'mushy' feeling.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Tue, 15 October 2013, 11:26:09 »
Clipped Cherry is the best Cherry
and it's a million times better than Costar which is my second favorite stabilizer.
Offline SNF
« Reply #14 on: Tue, 15 October 2013, 12:03:53 »
Cherry was ok for me but costar felt slightly better for me.
I never got a chance to try clipped cherrys
Offline Hyde
« Reply #15 on: Tue, 15 October 2013, 12:26:09 »
Really?  So just the switch the stabilizer corresponds to?  Because I'm thinking to get a Poker and if that's the case it's only 6 switches to de-solder.
And sweet it's a good thing that the manufactures start to catching on to the clip mod, all future keyboards should come default like that.  :D
Offline dante
« Reply #16 on: Tue, 15 October 2013, 13:11:20 »
Can any of you explain why Clipped Cherry's don't go into mass produced boards?  They offer strengths from both stabilizer types - just not sure if they are more fragile that could spook OEM's.
« Reply #17 on: Tue, 15 October 2013, 13:13:18 »
Did you see this reply?
Offline dante
« Reply #18 on: Tue, 15 October 2013, 13:14:34 »
Oh so sorry I didn't read :(...
Oh wow...  Do any of you know which Ducky's get the new mod?   I'm assuming it's only the Zero's and S3's?
