Author Topic: Some oldie but goldies on Ebay  (Read 4789 times)
Offline do_Og@n
« Last Edit: Thu, 17 October 2013, 07:18:24 by do_Og@n »
Re: Some oldie but goldies on Ebay
« Reply #1 on: Tue, 15 October 2013, 11:03:54 »
Is that Fujitsu a RD?
Offline do_Og@n
« Reply #2 on: Tue, 15 October 2013, 11:13:05 »
Good question.....what's RD?
« Reply #3 on: Tue, 15 October 2013, 11:16:21 »
Offline do_Og@n
« Reply #4 on: Tue, 15 October 2013, 13:05:00 »
rubber dome
How have I been here for so long and didn't know that? Cursed acronyms!
Offline do_Og@n
« Reply #5 on: Thu, 17 October 2013, 07:14:32 »
I have confirmed that the Fujistu board is a spring over RD (the original Thorpe  :p ).
I have also added a couple of new gold oldies to the list.
Offline jacobolus
« Reply #6 on: Sat, 18 January 2014, 13:03:45 »
That “Yellow ALPS” board is pretty clearly a KPT/TEC switch. Does anyone know what those feel like? It’s a bit hard to tell from the descriptions I could find in searching.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sat, 18 January 2014, 19:54:56 »
sure looks like a kpt, but when i photoshop'd, zoomed in it does not indicate or say kpt like a normal kpt switch does?
looks like leo or something.......
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #8 on: Sat, 18 January 2014, 20:01:39 »
The yellow KPT seem to be a TEC variant according to the DT wiki. So that may be what it says on the switch.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #9 on: Sat, 18 January 2014, 20:17:12 »
Oh boy, the KPT vortex.
You have the big names (e.g. Alps, Himake, Tai-Hao), and then all the little names like Keypot (KPT), Podworld, Micronorth and so many other companies that made a few products and then vanished; many left only their initials (GA, TEC, ATW in particular). Those KPT-style switches (a combination derivative of SMK (contact mechanism) and Tai-Hao Aruz (shell)) were made in a load of different variants with a load of equally meaningless names and numbers written on them.
The KPT/TEC page referenced above should indicate the odds of ever figuring this out. Interestingly, though, that one above is indeed Podworld, which is curious. It may be that Podworld were the switch OEM, since they made a lot of these keyboards.
Two more versions of the Podworld 292, with the same switches, but marked differently:
http://geekhack.org/index.php?topic=11248.0
http://geekhack.org/index.php?topic=7073.0
I would have to find out who made the keyboards with the other non-KPT versions in.
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Sat, 18 January 2014, 20:26:55 »
good grief.............never seen so many knock-off's in my life :eek:
Offline Pac Caps
  • Its almost a pallindrome
« Reply #11 on: Sat, 18 January 2014, 20:36:35 »
What is the Compaq DeskPro 286?
Want to be a cap maker
  • RIP
    • Boring twaddle
« Reply #12 on: Sat, 18 January 2014, 20:43:29 »
It's a variant of the Key Tronic E03091007
Foam and foil.
Bore Awards
Offline jacobolus
« Reply #13 on: Sat, 18 January 2014, 20:43:44 »
Does anyone here have an opinion of the KPT switches?
Offline Pac Caps
« Reply #14 on: Sat, 18 January 2014, 20:46:03 »
Foam and foil.
So does it feel like a Model F or does it just look like one? Thanks for the help, there are so many different vintage keyboards.
  • RIP
    • Boring twaddle
« Reply #15 on: Sun, 19 January 2014, 07:20:32 »
If it's the tactile version with buckling rubber sleeves (which it appears to be, but I'm unclear on exactly what switches it has), then I imagine it will feel a lot like a rubber dome. I've never knowingly used a Key Tronic keyboard.
Bore Awards
  • RIP
    • Boring twaddle
« Reply #16 on: Sun, 19 January 2014, 07:39:47 »
From Reddit:
http://www.reddit.com/r/MechanicalKeyboards/comments/1uxnfz/unknown_at_keyboard_clone_with_unknown_mech/
http://imgur.com/a/t0RAJ#eBCjTci
That one clearly says "OC2", with an implication that we're reading the other one upside down, making it something like "037", "O37" or "C37".
You would need to pull a bunch of keycaps and check whether they all have the same writing on them, to determine whether what's written is a brand name or a mould number.
Bore Awards
  • RIP
    • Boring twaddle
« Reply #17 on: Sun, 19 January 2014, 09:58:52 »
KPT-102: http://kbtalking.cool3c.com/article/13939
Podword 292: http://www.ebay.com/itm/CLICKY-MECHANICAL-HEU-292-KEYBOARD-WITH-WHITE-ALPS-/171048654282
Identical case.
At least one HEU-292 has a model number of PT-605D: http://geekhack.org/index.php?topic=7073.0
That Podworld keyboard has the "AA-nn" switches, the same as InSanCen's.
Bore Awards
