Author Topic: Hydrographic patterns  (Read 4048 times)
Offline jiggityjane
« on: Tue, 15 October 2013, 14:00:52 »
Has anyone ever thought of using the hydrographic method to coat keycaps?
Might be a bit pricey but if it's possible you could get all kinds of patterns on there, plus you might be able to put some of your crappier looking key caps to good use  :))
Re: Hydrographic patterns
« Reply #1 on: Tue, 15 October 2013, 14:02:33 »
It has been mentioned in a few threads but I'm not sure if anyone has done it.
Offline Lu_e
« Reply #2 on: Wed, 16 October 2013, 00:00:04 »
I was about to do it to a QFR case. The guy quoted me $40-50 which included prepping/sanding/base-coating etc. but not shipping. I can give anyone his contact info just PM me if you want to get some graphics done! Not sure how durable caps would be. I forgot to ask him if any finishing coat is used.
Here are some of the patterns I almost did on a case;
https://www.liquidconcepts.com/shop/animal/san-001-50cm/
https://www.liquidconcepts.com/shop/animal/san-042-1m/
https://www.liquidconcepts.com/shop/films/swg-232-1m/
xD
www.liquidconcepts.com/shop/abstract/sad-496-1m/
Imagine a plate and case both done... could be really cool; wood plate anyone?. The graphics look really life like.
some of his work;
thats a motorcycle disk brake caliper incase anyone didnt know.
« Last Edit: Wed, 16 October 2013, 00:14:41 by Lu_e »
Just say NO to ABS keycaps
Offline Oobly
« Reply #3 on: Wed, 16 October 2013, 05:23:31 »
Wow! Those bike parts look awesome!
I guess it could work if you make a mount for the keys or dip the whole keyboard. Can do a whole set of keys at once... Will have to line it up really well and do it super carefully so they don't misalign, though.
I was also thinking about doing thermal transfers using laser printed images on baking paper, but it's not easy and prone to partial transfers. This looks to be a better option.
There is a clear finishing coat applied, according to their site: "Finally, a clear coat is applied to enhance and protect the finish. This coat can be matte, glossy, or satin, and helps to protect the finish from all sorts of damage. It’s about as durable as the clear coating used in automotive finishes."
The first thing I thought of when I saw the thread title was swirl painting: http://theswirling.com/Tutorials/BoraxMethod/SwirlingYourGuitar.aspx
That could work, too, if you just want a nice retro pattern on the caps.
« Last Edit: Wed, 16 October 2013, 05:26:27 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Wed, 16 October 2013, 06:11:00 »
0.o looks like car parts
Offline jiggityjane
« Reply #5 on: Wed, 16 October 2013, 07:36:19 »
That's amazing, I would love to see the pics of your case when it's done!
I wonder if a GB could be arranged for multiple cases...  ;D
Offline terran5992
« Reply #6 on: Wed, 16 October 2013, 07:43:16 »
I dont see enough intrest  in this for a group buy
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #7 on: Wed, 16 October 2013, 09:48:28 »
I've thought about it -- whenever I see keyboards like this in stores:
39441-0
I figured that's got to be done via hydrographics OR maybe a printing method that holds the entire keyboard and keys together as a set. Most of these keyboards look to have a chicklet sort of key, so that the graphics aren't thrown off by the topography of a keyboard with, I dunno, more "vertical" profiles? But I think it could work so long as the image you're transferring isn't too complex. Maybe a repeating pattern, dollar signs, skulls, etc.
Also, the above keyboard's imagery is pretty distracting, no?
I don't know of anyone who has done it yet, but they sell kits for people who want to camo up their guns, so give it a shot.
« Last Edit: Wed, 16 October 2013, 09:50:55 by Krogenar »
Quote from: Samuel Adams
Offline Lu_e
« Reply #8 on: Wed, 16 October 2013, 18:52:04 »
Also, the surface needs to have a certain color (based on the graphic chosen) base-coat applied. & if that requires sanding.... holy labor batman.
