Author Topic: [IC] 60% Poker compatible : PCB+Plate+Case : Full LED &Macro < GB Today !>  (Read 82346 times)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: [IC] 60% mini PCB : Full LED & HW Macro ... (Designed by BeastMask)
« Reply #50 on: Sun, 20 October 2013, 08:03:34 »
Yes Sir!  From Monday or Tuesday will be OK for You?
The shipping will start  in 14 days from the Group Order.
Sounds good to me!
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #51 on: Sun, 20 October 2013, 08:07:44 »
How long will it run for?
actually depends on the Qty of ISO....   :)
Offline longweight
  • philanthropist
« Reply #52 on: Sun, 20 October 2013, 08:11:36 »
How many ISO boards do we need? 50?
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #53 on: Sun, 20 October 2013, 08:16:11 »
Isn't the same PCB used for ISO and ANSI?
Offline pmh1410
« Reply #54 on: Sun, 20 October 2013, 08:23:23 »
Wow, Spirit. It's likely as Thumb PCB ?
Offline longweight
  • philanthropist
Re: [IC] 60% mini PCB : Full LED & HW Macro ready (Designed by BeastMask)
« Reply #55 on: Sun, 20 October 2013, 08:26:19 »
ISO / black / 1pcb
Now:
ISO / black / 1pcb
ISO / white / 2 pcb
Offline sprit
« Reply #56 on: Sun, 20 October 2013, 08:36:23 »
thumb has smaller profile it's own,  too much room to fit into Poker.
Offline sprit
« Reply #57 on: Sun, 20 October 2013, 08:37:27 »
Yes right ! Mr. longweight!
Offline longweight
  • philanthropist
« Reply #58 on: Sun, 20 October 2013, 08:38:29 »
The OP is misleading, you state the ANSI/ISO are on one PCB, if that is the case then why do we need 50 ISO PCBs?
Offline sprit
« Reply #59 on: Sun, 20 October 2013, 08:39:58 »
Just in case, for ISO plates and production rev. bugs, retouch patterns etc. So we need a certain level of qty'  But I deadly love to produce ANSI + ISO !  for my taste! sorry for me!  :)
« Last Edit: Sun, 20 October 2013, 12:05:00 by sprit »
Offline MOZ
  • Busy making stuff
Re: [IC] FACE W : 60% PCB : Full LED & HW Macro ... (Designed by BeastMask)
« Reply #60 on: Sun, 20 October 2013, 09:20:07 »
Do we get the textured PCB?  They look really good.
Re: [IC] FACE W : 60% PCB : Full LED & HW Macro ... [ Design by BeastMask ]
« Reply #61 on: Sun, 20 October 2013, 10:26:08 »
ANSI / White color / 1 PCB
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #62 on: Sun, 20 October 2013, 10:41:30 »
ANSI White 2
« Reply #63 on: Sun, 20 October 2013, 11:18:12 »
ANSI / Black Color / 1 PCB
Offline longweight
  • philanthropist
« Reply #64 on: Sun, 20 October 2013, 11:27:47 »
Everyone vote for ISO! That way we get a PCB that can do both ISO and ANSI.
Offline naokira
  • The King in the North
« Reply #65 on: Sun, 20 October 2013, 12:18:38 »
Question: what led modes are available right now?
I'm planning to make my capslock a shiftlock with a cherry mx lock key, so the led on it must be
only activated when on hold since its on hold. If that its not available please suggest so. Thanks! :)
-  Full LED control, latest LED modes, regularly updated.  Open Source based.
-  LED modes at present : 1. Off   2. On   3. fading, breathing   4. getting brighter   5. getting darker  6. push on  : new modes being developed.
-  LED preview :  http://www1.kbdmania.net/xe/photo/7439979    need to be updated.
[/size]
Thanks for answering! So no-go on my plan on the shift lock led?
FaceW in LZ-CE
Offline nissarup
Re: [IC] FACE W : 60% PCB : Full LED &amp; HW Macro ... [ Design by BeastMask ]
« Reply #66 on: Sun, 20 October 2013, 12:26:09 »
1 ISO. Color not important.
Offline sprit
« Reply #67 on: Sun, 20 October 2013, 12:32:38 »
I will check it!!     :)
Offline yicaoyimu
« Reply #68 on: Sun, 20 October 2013, 12:34:07 »
Just want to make sure, will this PCB fit GON's GH60 case?
Offline TLSC.wipeOut
  • "Who dares, wins"
« Reply #69 on: Sun, 20 October 2013, 12:43:25 »
ANSI | Blue/White |1-2 pcs
Depending on the price
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline naokira
« Reply #70 on: Sun, 20 October 2013, 12:53:35 »
I believe it is. Since they are both compatible with poker cases.
FaceW in LZ-CE
Offline Dubsgalore
« Reply #71 on: Sun, 20 October 2013, 13:17:08 »
for official count
ANSI / WHITE / 2 PCB
and it does look like it will fit every 60% case..which is good  :thumb:
« Reply #72 on: Sun, 20 October 2013, 13:32:32 »
I just noticed this:
"-  the essential SMD parts pre-soldered and tested."
Are there some SMD components for other facets of the keyboard that won't come soldered in place?
Hello! Nice Shot! ^^  Chip resistors! for LEDs depends on Qty,  Machined, or Hand-Arbeit  :thumb:
I'm not sure what you're saying.  Are you saying that the LED resistors aren't soldered on?
Offline yicaoyimu
« Reply #73 on: Sun, 20 October 2013, 13:33:58 »
That's what I think too  :cool:
ANSI / Black / 1 PCB
Offline keymaster
  • Topre Revolution Theorist
« Reply #74 on: Sun, 20 October 2013, 13:34:47 »
...and I just sold my Cherry MX stuff. WHEN WILL IT END
Offline longweight
  • philanthropist
« Reply #75 on: Sun, 20 October 2013, 13:35:32 »
Is it not possible to just include the ISO changes? I am sure that most would like the option to use the PCB as ISO but I don't think that we will get 50 ISO votes.
Maybe make the situation clearer in the OP? What would the price implication be for ISO inclusion?
Offline GeorgeK
« Reply #76 on: Sun, 20 October 2013, 13:55:19 »
I'm really confused by this - is it a combination PCB like the GH60 where you can have both ANSI and ISO on the same PCB or are they separate?  Are we voting for whether we'd want one or the other? Are we voting for the colour of the PCB too?
Offline Dubsgalore
« Reply #77 on: Sun, 20 October 2013, 14:00:28 »
I believe it has the ability to use both ISO & ANSI all in one pcb..but i'm not sure
it has a lot of bottom row layout options, similar to the GH60
There are 4 color options too, Red, Blue, Black, White
Offline MOZ
  • Busy making stuff
« Reply #78 on: Sun, 20 October 2013, 14:03:25 »
This is what I have inferred. The PCB would support ISO and ANSI, however at the moment it only supports ANSI, and OP needs 50 people or so, so that he can get the design changed to support ISO.
Offline naokira
« Reply #79 on: Sun, 20 October 2013, 14:09:42 »
Must get more ISO!!! If no ISO then I'll probably would not order. :(
FaceW in LZ-CE
Offline longweight
  • philanthropist
« Reply #80 on: Sun, 20 October 2013, 14:12:09 »
Yes 50 people will need to ask for ISO for it to happen.
Offline xandr
« Reply #81 on: Sun, 20 October 2013, 14:28:21 »
I already asked for ISO, so nobody look at me!
Also, I'm in the "no iso = no buy" camp.
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline GeorgeK
« Reply #82 on: Sun, 20 October 2013, 14:35:03 »
Ah right - if I were to buy this I'd definitely want support for ISO and ANSI...
Offline Dubsgalore
« Reply #83 on: Sun, 20 October 2013, 14:36:19 »
Let's all just express our support for ISO, and make it happen
Offline longweight
  • philanthropist
« Reply #84 on: Sun, 20 October 2013, 14:36:27 »
Then register your interest :)
Offline naokira
« Reply #85 on: Sun, 20 October 2013, 14:45:45 »
You guys are great :)
FaceW in LZ-CE
« Reply #86 on: Sun, 20 October 2013, 14:48:41 »
sprit is working with BeastMask to get ISO/ANSI support on the same PCB. The design isn't final yet, but I believe we will know something more soon.
  • "Who dares, wins"
« Reply #87 on: Sun, 20 October 2013, 16:45:26 »
Is it possible for this to be used in conjunction with a plate? or is it only designed to be used for PCB mounted switches?
WTB: KMAC2 kit
Offline MOZ
  • Busy making stuff
« Reply #88 on: Sun, 20 October 2013, 16:50:03 »
Any PCB can be used with a plate, atleast as far as Cherry MX switches are concerned.
Offline frogamic
« Reply #89 on: Sun, 20 October 2013, 17:04:33 »
Can each LED be addressed individually in the firmware?
Filco TKL | Filco ISO105 | Acer 6311-K71
  • "Who dares, wins"
« Reply #90 on: Sun, 20 October 2013, 17:05:56 »
sweet =D
WTB: KMAC2 kit
Offline debt4lyfe
  • time puts a gun in every hand
« Reply #91 on: Sun, 20 October 2013, 17:27:54 »
ANSI / White / 1 PCB
  • "Who dares, wins"
« Reply #92 on: Sun, 20 October 2013, 17:42:37 »
I guess I'll plan out my 60% build based on this upcoming new PCB xD
WTB: KMAC2 kit
Offline bueller
  • MX baller
« Reply #93 on: Sun, 20 October 2013, 20:56:25 »
Haha I just ordered 2 plates and some more clears from GON because of this. Was going to get some cut up locally but for $40 including anodising GON is damn hard to beat.
« Last Edit: Sun, 20 October 2013, 21:05:11 by bueller »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #94 on: Sun, 20 October 2013, 21:32:50 »
I'm in for three: Blue, White and Black
  • "Who dares, wins"
« Reply #95 on: Sun, 20 October 2013, 21:43:51 »
are his plates on his website or did you just PM him for plates? o.0 can't seem to find it on his site...
WTB: KMAC2 kit
Offline phatdood9
« Reply #97 on: Sun, 20 October 2013, 22:05:05 »
Count me in!
Two ANSI, 1 red, 1 white
  • "Who dares, wins"
WTB: KMAC2 kit
Offline sprit
« Reply #99 on: Sun, 20 October 2013, 22:24:48 »
      As we know, Basically ISO enter and 1.25x shift support on the PCB is absolutely required.   And the Firmware for sure.
We are working on ANSI+ISO, and now doing finalizing the Release Candidate..
I do Love ISO for myself, just because I have learned some of your languages and got friends there, my fellow Europeans...
« Last Edit: Sun, 20 October 2013, 22:35:14 by sprit »
