Author Topic: Open Source Lube Station  (Read 75391 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« on: Sat, 19 October 2013, 14:38:50 »
I don't lube my switches since I use Blues, and you don't want to lube them (IMO, you might want to do it, your choice), so it never crossed my mins to make an acrylic lube plate, until I read this thread: http://geekhack.org/index.php?topic=49883.0.
So I went ahead and made these designs in various sizes (Behemoth, Standard, Mini, Gnome):
39917-0
This can be made in two ways:
1. Single layer with the side tool/spring holders, in 4 extra layers
2. 5 layers, top and bottom layers like a keyboard (Top with proper cutouts and solid base), square style cutouts in the middle layers)
You can also mix layers if you want something in between.
39919-1
ToDo:
- I'm thinking, I'll do one more 18x6 Done
- Some GH branding Done
- Special slots, one on either side to stick one switch tool in each like pitch forks :P Done
« Last Edit: Sat, 19 October 2013, 17:52:22 by MOZ »
Offline MOZ
  • Busy making stuff
Re: Open Source Lube Station
« Reply #1 on: Sat, 19 October 2013, 14:39:26 »
Reserved
Offline MOZ
  • Busy making stuff
« Reply #2 on: Sat, 19 October 2013, 14:41:17 »
I should give reference, thanks to the work of the_beast, jdcarpe, WFD on the old thread, and the Korean geniuses on KBD.
The cutouts are similar to the korean ones, however are slightly different, based on my observations and understandings.
Offline keymaster
  • Topre Revolution Theorist
« Reply #3 on: Sat, 19 October 2013, 14:46:28 »
I, for one, welcome our Korean/Indian overlords.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #4 on: Sat, 19 October 2013, 15:32:49 »
it was only a matter of time
Offline MOZ
  • Busy making stuff
« Reply #5 on: Sat, 19 October 2013, 15:57:53 »
What's next on the list to acrylicize
Offline JPG
  • Model F is my new passion!
« Reply #6 on: Sat, 19 October 2013, 16:00:39 »
A carrying case, a cable, etc.!
Offline MOZ
  • Busy making stuff
« Reply #7 on: Sat, 19 October 2013, 16:02:45 »
I can make a briefcase? How about a case that has a cover too and you can close it and carry it, but like the Pencil Case I designed for the SmallFry Keyboard
Offline Glod
    • YouTube Channel
« Reply #8 on: Sat, 19 October 2013, 16:03:57 »
well i brought this up in our previous PM but i would say a replacement enclosure for the kensington slingblade trackball. :O
Offline regack
« Reply #9 on: Sat, 19 October 2013, 16:32:57 »
Keycaps :D
Offline MOZ
  • Busy making stuff
« Reply #10 on: Sat, 19 October 2013, 16:45:15 »
Keycaps :D
Already done to mixed results :P
Offline MOZ
  • Busy making stuff
« Reply #11 on: Sat, 19 October 2013, 17:53:22 »
Uploaded the 18x6 behemoth as well.
Add GH logo (In blue, will be etched) and also slots on either sides for the switch tools
Offline keymaster
« Reply #12 on: Sat, 19 October 2013, 17:55:58 »
Amazing work. It's too bad I won't have any use for one after selling off my MX gear. :P
Offline MOZ
  • Busy making stuff
« Reply #13 on: Sat, 19 October 2013, 18:01:13 »
Haha, I don't have a use for it too, since I like my switches noisy. But I still made it, so it is your duty to buy one, need or not!
Offline regack
« Reply #14 on: Sat, 19 October 2013, 18:25:54 »
I think it's great, even if I also have no use for it... I like my model Ms, and everything else is MX blues... even the not-yet-fully-assembled ErgoDox
Offline MOZ
  • Busy making stuff
« Reply #15 on: Sat, 19 October 2013, 18:35:41 »
Yay, another blue lover! Although mine have 80g springs.
Offline Photoelectric
« Reply #16 on: Sat, 19 October 2013, 18:59:14 »
A keyboard dust roof with engraving ;) I even have a mock up for it.  Just don't know if shipping from India would make it too expensive.
Offline regack
« Reply #17 on: Sat, 19 October 2013, 19:08:09 »
Ooh 80g, I want that.  Not to get off topic, but I swapped out most of my blue springs for black springs, though I have more blues that still haven't been modified.  I'd do it all over again to put in 80g springs.
Offline MOZ
  • Busy making stuff
« Reply #18 on: Sat, 19 October 2013, 19:11:40 »
Originative bro!
And enough OT. Just praise my lube stations.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #19 on: Thu, 24 October 2013, 08:25:52 »
All hail the MOZ-tastic lube stations!  :thumb:
Seriously though, are you going to do a group buy for these, because I really, really want one.
Offline MOZ
  • Busy making stuff
« Reply #20 on: Thu, 24 October 2013, 08:29:10 »
Which one would you like?
Offline whiskytango
  • Don't touch the trim
« Reply #21 on: Thu, 24 October 2013, 08:42:53 »
I want one too. I cannot believe I haven't seen this before. I think I would want to get the big one, but it depends on how expensive. I also like the version that only has the extra layers on the sides.
mashby, if you're getting one let's split shipping.
Offline mashby
    • Mashby
« Reply #22 on: Thu, 24 October 2013, 08:43:55 »
Depending on price, the standard and the mini.  :p
« Reply #23 on: Thu, 24 October 2013, 08:45:56 »
I believe it is the mini the next to smallest. 116x340
I like that one!
« Last Edit: Thu, 24 October 2013, 08:51:13 by SpAmRaY »
« Reply #24 on: Thu, 24 October 2013, 08:46:24 »
Depending on the price I'd take a standard as well
Offline whiskytango
« Reply #25 on: Thu, 24 October 2013, 08:48:43 »
actually, I think standard would work for me as well.
Offline MOZ
  • Busy making stuff
« Reply #26 on: Thu, 24 October 2013, 09:10:04 »
Oh god, this is not an IC :P
I will get a test cut done sometime end of this week or early next week depending on how I squeeze out time. I will then post the DWG files for anyone to play with.
Offline exitfire401
  • The Force is Re/\l
« Reply #27 on: Wed, 09 April 2014, 18:32:06 »
I would love one. Definitely the behemoth, purely because I would prefer to do everything at once (especially after the hell of a time I had last weekend spring swapping, stickering, and lubing my clears.
Offline Smasher816
  • HHKB Master
« Reply #28 on: Wed, 09 April 2014, 19:52:58 »
MOZ, the King of Acrylic.
Offline Pacifist
  • on hiatus
« Reply #29 on: Wed, 09 April 2014, 20:06:11 »
I suggested that before
alas Moz wants to stay king of the newbies
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #30 on: Wed, 09 April 2014, 20:48:03 »
Hi MOZ, I am wonder if you can upload the cad file? Thank you
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline meIIow
« Reply #31 on: Tue, 19 November 2019, 15:46:13 »
Hey MOZ, stumbled on this thread just now. Do you still have the DWG files somewhere?
Offline ifohancroft
  • root
    • IFo Hancroft
« Reply #32 on: Wed, 18 March 2020, 08:33:57 »
I would also like to get the SVG files.
I like to make, break & modify stuff via a soldering iron, code or both.
Offline shine
  • IBM obsessed
« Reply #33 on: Sat, 21 March 2020, 13:43:10 »
+1!
Looking for: IBM 4978(XD!)
Current collection:
B: 3101, 3276, 3277, 3278, 3279, 5251, 5285, 6580
F: F50, F62 OG "kishaver", F104 "Unsaver", F107, F122, XT, AT, 3178 "bluebutton", 5291 "Bigfoot", 5155
M: Mopar, silver badge
Topre: Nissho KB106DE
Alps: blues, whites, green
Offline TryKeebs
« Reply #34 on: Wed, 04 November 2020, 23:59:45 »
+1
Offline RandomSheepZA
« Reply #35 on: Wed, 07 July 2021, 07:21:06 »
Nerco of on this thread. OP any chance for the cad files?
Offline wonderp
« Reply #36 on: Wed, 01 December 2021, 00:06:58 »
I, too would love to make one of these. Can't find any files anywhere. It's a shame this post is long dead.
I bought a Razer keyboard and I regret my purchase with every word I type. That’s twenty three regrets just for this signature.
Offline Leslieann
« Reply #37 on: Wed, 01 December 2021, 11:08:47 »
Try here, while primarily 3d printed, there's cad files for laser as well.
https://www.thingiverse.com/search?type=things&q=lube+station&sort=popular&posted_after=now-30d
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
