Author Topic: poker 2 plate question  (Read 2191 times)
Offline debt4lyfe
  • time puts a gun in every hand
« on: Sun, 20 October 2013, 09:44:34 »
Can someone confirm if the poker 2 plate allows switch top removal without desoldering? I've looked around but couldn't find any firm answers.
Re: poker 2 plate question
« Reply #1 on: Sun, 20 October 2013, 09:49:41 »
No
« Reply #2 on: Sun, 20 October 2013, 09:57:24 »
Can't do any switch top removal on a plate mount board.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sun, 20 October 2013, 10:03:52 »
Except you can if it has a special plate that allows it. OEM plates never allow it
Offline debt4lyfe
« Reply #4 on: Sun, 20 October 2013, 11:14:27 »
Okay, thanks for the answers
Offline spiceBar
    • ChessTiger.com
« Reply #5 on: Sun, 20 October 2013, 14:16:45 »
That's interesting and I would like to see pics of the various plates. I'm pretty sure pics have already been posted but searching the forum is really difficult.
« Reply #6 on: Sun, 20 October 2013, 15:26:05 »
just look at any of the threads dealing with custom plates
« Reply #7 on: Sun, 20 October 2013, 16:32:04 »
Regular switch holes - 14x14mm squares : http://i.imgur.com/Y5BSx7L.png
Custom switch holes that allow switch top removal - 14x14mm squares with tabs on the side : http://i.imgur.com/GJme4MW.png
There are other variants too.. but that's a common one.
Offline spiceBar
    • ChessTiger.com
« Reply #8 on: Mon, 21 October 2013, 02:28:06 »
OK, great. That is what I was looking for. Thanks!
