Author Topic: Topre spring mod  (Read 2333 times)
Offline DrinkTea
Topre spring mod
« on: Wed, 30 October 2013, 22:57:47 »
So I like the way the spacebar sounds, especially, and I see it has a spring around the plunger to make it heavier. Has anyone ever tried putting similar springs under the other keys? If so, how does it affect the feel and sound? I would imagine you'd use something very light, say, 5-10g.
Offline spiceBar
    • ChessTiger.com
Re: Topre spring mod
« Reply #1 on: Wed, 30 October 2013, 23:17:41 »
That would be nice and I think it has already been discussed.
I would like to have a number of these springs to be able to experiment with them. I would start by putting one under the Enter key so I don't press it too easily.
« Last Edit: Wed, 30 October 2013, 23:20:25 by spiceBar »
Offline thoere
« Reply #2 on: Wed, 30 October 2013, 23:21:05 »
I expect problems if you try to replace this spring.
-snip-
He's referring to the spring on top of the space bar plunger, not the ones inside the board.
Offline spiceBar
    • ChessTiger.com
« Reply #3 on: Wed, 30 October 2013, 23:24:13 »
-snip-
Yes you are right. I have edited my post a few seconds after posting it, when I realized my mistake.
« Reply #4 on: Wed, 30 October 2013, 23:29:08 »
When I had an FC660C I put the space bar spring under the backspace key.
Offline spiceBar
    • ChessTiger.com
« Reply #5 on: Wed, 30 October 2013, 23:40:00 »
You mean that you don't have it anymore? I thought you liked it?
« Reply #6 on: Wed, 30 October 2013, 23:42:45 »
The problem might be getting hold of a quantity of those springs without sacrificing another Topre board.
« Reply #7 on: Wed, 30 October 2013, 23:47:20 »
It was my first topre board but I just couldn't get used to the small layout (same reason I got rid of my pokers), I only had it for like a week if that, since then I've tried 3 other topre boards including the HHKB which somehow has me mesmerized with its layout.
Offline DrinkTea
« Reply #8 on: Thu, 31 October 2013, 09:05:49 »
I would assume springs are not the hardest thing to get custom made. They don't have to be identical, just the right size.
