Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224503 times)
0 Members and 7 Guests are viewing this topic.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: SPRIT Model 1 : Poker, 60% 75% 87% 110% : ANSI + ISO (Full LED + HW Macro)
« Reply #700 on: Sat, 30 November 2013, 21:32:54 »
Hey Sprit, does your 75% PCB support a center stem caps lock?  I just looked at your pictures and it doesn't look like it does.  I would be really disappointed if it doesn't support a center stem caps lock...
Deer!  Swill   ;)     Enough Snows there ?
Our GH Version Latest PCBs Support All the Cherry + Filco  Standards!!
i prefer the Center Caps  and Center Space in person
« Last Edit: Sun, 01 December 2013, 00:53:52 by sprit »
Offline sprit
« Reply #701 on: Sat, 30 November 2013, 21:42:01 »
I don't mean any offense, but is that really a dealbreaker for you? It really doesn't seem like a big deal.
Hello~   Dear Keymaster !
Thanks!    ;)
Offline sprit
« Reply #702 on: Sat, 30 November 2013, 21:45:10 »
About  Our  PCB !
For Example,  Korean U vesion PCBs have No Center Space, NO ISO supports.   http://winkeyless.kr
46419-0
But Now You See some Latest Korean U version has Center Space and ISO supports.
46417-1
Our GH Version will have All and More !  (ANSI+ISO, Support Holes for PCB, Better LED Effects... ) No show on http://winkeyless.kr  Thanks to The GH Team, Mr. JDcarpe and Mr. Dorkvader.
46421-2
« Last Edit: Sun, 01 December 2013, 09:30:09 by sprit »
Offline sprit
« Reply #703 on: Sat, 30 November 2013, 22:13:05 »
News For Us  :
The Latest Firmware  :  Everyone Invited!
The Max. Electric Current set to 500mA ... Test Done!         on  Nov.30th .....
http://winkeyless.kr/95     http://winkeyless.kr/17     https://github.com/showjean/ps2avrU
Thanks to The GH Team,  Mr. JDcarpe, Mr.mashby and Mr. Dorkvader.
« Last Edit: Sun, 01 December 2013, 09:43:49 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #704 on: Sat, 30 November 2013, 22:27:30 »
Found this.  So yes, it does support a center stem caps lock.  Thanks Sprit...
Offline sprit
« Reply #705 on: Sat, 30 November 2013, 22:57:55 »
 Thanks Deer, Swill !   Yes! 60% 75%  87%  hit the MOQ!   ;)
« Last Edit: Sat, 30 November 2013, 23:06:34 by sprit »
Offline sprit
« Reply #706 on: Sat, 30 November 2013, 23:11:48 »
Metal :  Pre-Check for MOQ  and Design ( = Reservation)
-  GB will start after this Check
-  No Check, No Sale !
https://docs.google.com/forms/d/1aMk5aG9l8dlwLBTAS9D-VMRm-xWmi69cpkRDgy_k1lI/viewform
« Last Edit: Sat, 30 November 2013, 23:17:54 by sprit »
Offline bazh
« Reply #707 on: Sat, 30 November 2013, 23:15:40 »
were the 2nd batch's invoices send out today ?
HHKB Pro2 white
Newbie again
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #708 on: Sat, 30 November 2013, 23:16:25 »
Ugpm.
Offline sprit
« Reply #709 on: Sat, 30 November 2013, 23:20:15 »
Nob!  I am busy Now..Plz, Dont ask me the same Question Too Much !.  Sorry!   ;)       I will Notice it on OP When It is OK!
Offline Permeability
« Reply #710 on: Sat, 30 November 2013, 23:30:15 »
Hi sprit,
Can you respond to my PM when you  have time?  :) I need to make an order change, sorry!
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline bazh
« Reply #711 on: Sat, 30 November 2013, 23:53:41 »
ok, just want to make sure, sorry guy  :D
HHKB Pro2 white
Newbie again
« Reply #712 on: Sun, 01 December 2013, 00:39:41 »
News For Us  :
Excellent! This is good to hear that proper testing is being done.
Offline cookiesowns
« Reply #713 on: Sun, 01 December 2013, 02:16:03 »
Still waiting for more pictures of PCB & Top cover.
Pictures wanted for Plate too!
Are the cherry MX plate or pcb mounted?
Offline sprit
« Reply #714 on: Sun, 01 December 2013, 02:38:48 »
Plz Write Down Yor Order Form now, Or It will be Too late!
« Last Edit: Sun, 01 December 2013, 02:51:56 by sprit »
Offline justnits
« Reply #715 on: Sun, 01 December 2013, 02:42:09 »
sprit, i have sent in order form for acrylic plate...see if u have received it?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline sprit
« Reply #716 on: Sun, 01 December 2013, 02:53:35 »
Yes!  My friend,  justnits!
All Yours saved to the GoogleDoc, and My BackUp Storages.   :thumb:
Offline justnits
« Reply #717 on: Sun, 01 December 2013, 02:56:05 »
thanks sprit!
i'll wait for your invoice after your paypal got sorted out :)
Offline cookiesowns
« Reply #718 on: Sun, 01 December 2013, 06:20:13 »
Sent in order Form! If you can please confirm the ordered stuff ( should be 3 separate ones ) via PM that would be great!
Can you answer my question however for Cherry MX Switch. Are they plate or PCB mounted?
Any pictures/suggestion of Plate & top cover? Will there be a top cover for 87% and 110% case?
Offline YongJK
« Reply #719 on: Sun, 01 December 2013, 06:38:32 »
For A Reformation of The Case Structure
http://www1.kbdmania.net/xe/photo/7577370
http://www1.kbdmania.net/xe/market_info/7692061
  "   새로운 기판에서는, 기존에 대다수를 차지했던,  보강판에 장착해 공중부양으로 고정하는 방식을 포함해
다음의 5가지 이상의 장착방식이 가능합니다  (억지 분류지만, 그외 다른 방법도 우리 동호인들이 개발할 수 있을 겁니다)
갑자기 나온 것이 아니라  이미 묻고답하기 등의 게시판에서 자주 토론되던 내용입니다
1.  보강판 + 기판을  하우징 중앙/상부에 걸치고, 보강판만 고정하는 기존 방식  = 공진울림이 다소 강하다는 지적이 많음.
2.  보강판 + 기판을  하판에 고정하는 방식 1  = 기성품에 흔한 방식, 미니에선 포커 2 등이 대표적.
    타이핑시 타격 에너지가 기판전체와 보강판에 골고루 분산흡수되어 케이스의 울림과 공진에너지량이 감소하는 효과가 있음.
3.  보강판 + 기판을  하판에 고정하는 방식 2  =   기성품에 흔한 방식. 위 방식과 유사.
4.  기판만 하판에 고정하는 방식 (무보강판 방식)  = 체리 순정 키보드에 흔한 방식. 1800, 3000 등이 대표적.
5.  기판을 상판에 고정하는 방식 (무보강판 방식) = Dolch 1800 키보드의 경우처럼 기판을 상판에 고정하고 하판이 받쳐주는 경우.
Trans (Simple)
" This New Method enables at least  5 ways of PCB mount connections,  due to a New Structure....
1.  Plate + PCB  : Connected to the Top of the case  :  No support from the Bottom,  Hanging in the air. Stronger Sound Resonance.
2.  Plate + PCB  : Connected to the Bottom of the case  :  Very Common in Keyboard industry. IBM, Apple, HP, ..
3.  Plate + PCB  : Connected to the Bottom of the case (2)  :  Very Common in Keyboard industry, leopold, Filco, Ducky ...
4.  No Plate, Only PCB  : Connected to the Bottom of the case  :  Very Common in Keyboard industry, Cherry 1800, 3000 ....
5.  No Plate, Only PCB  : Connected to Top cover of the case : Reversed connection to the Top cover.  Dolch 1800, HHKB  ... a lot..
http://www.youtube.com/watch?v=fCsiHj26REo     http://www.youtube.com/watch?v=_AAOeNjOK6U     http://www.youtube.com/watch?v=AR32YMBvFsI      http://www.youtube.com/watch?v=lOzhfI3MN1c      ...  Long United will be divied,  long divided will be United...
That means I can have plate+pcb mount on acrylic case ?  :p
Keyboard: PLU ML87 Mx Blue
Offline sprit
« Reply #720 on: Sun, 01 December 2013, 07:42:34 »
90% possible  In my opinion!
Offline justnits
« Reply #721 on: Sun, 01 December 2013, 07:53:39 »
sprit, the stabs that you are looking from suppliers, are they pcb mount or plate mount type?
Offline sprit
« Reply #722 on: Sun, 01 December 2013, 08:06:49 »
Both! Sir !  :)
Offline sprit
« Reply #723 on: Sun, 01 December 2013, 09:18:30 »
Hi sprit,
No Problemo!   I got your PM !   I will put all the new Orders in Your New Invoice !
Good  Day!   oh!   Sunday!
« Last Edit: Sun, 01 December 2013, 11:14:49 by sprit »
Offline sprit
« Reply #724 on: Sun, 01 December 2013, 10:33:00 »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #725 on: Sun, 01 December 2013, 10:36:34 »
Not sure if this is the best place to ask this, but what size spacebar is used on a 75% board?  Is it a 6.25?
Offline sprit
« Reply #726 on: Sun, 01 December 2013, 10:40:49 »
Offline sprit
« Reply #727 on: Sun, 01 December 2013, 10:41:41 »
My Better Board...  Much More Comfy than The Metal Frame ...
" Hey! ... Bunch of Immetal Lovers Out There ... "  ... muss es sein?
« Last Edit: Sun, 01 December 2013, 19:46:41 by sprit »
Offline sprit
« Reply #728 on: Sun, 01 December 2013, 10:47:45 »
6.25x  and  7x   :)   all my PCBs support  6.25x  and  7x
« Last Edit: Sun, 01 December 2013, 11:02:25 by sprit »
Offline ninjadoc
« Reply #729 on: Sun, 01 December 2013, 14:06:34 »
Trans (Simple)
Before I commit to a case want to see a full picture - top, bottom, sides - preferably with a plate and PCB in it.
http://www.otd.kr/bbs/board.php?bo_table=album&wr_id=177350
Is a link I found in one of sprit's post on kbdmania but I'm not clear if it is one of his cases - it is an album but his name is not attached to it.
Offline cookiesowns
« Reply #730 on: Sun, 01 December 2013, 18:12:42 »
Hi Sprit, I know you're busy, but can you take a look above? I'll be getting quite a bit of PCB & Cases, ( 3-4 PCB, and 4-5 plates ) as well as cases. So it would be awesome if you can answer these questions prior to the invoice sent out. So I can just give you a final decision!!!
Also will the stabilizers be included, or would that be a separate group buy. What about round 3 for cases?
Offline justnits
« Reply #731 on: Sun, 01 December 2013, 18:58:28 »
Trans (Simple)
that case isn't sprit's. it's Lewi or LinLin's case and wrist rest.
Offline sprit
« Reply #732 on: Sun, 01 December 2013, 19:07:35 »
Hello!  Good Morning !  1 min plz!
Your Order is :
PCB  87%   3
PCB  110 %  1
Case  110%  1
and some others     All  Identified and well saved  to Google and My Storages.    :)
« Last Edit: Sun, 01 December 2013, 19:19:26 by sprit »
Offline justnits
« Reply #733 on: Sun, 01 December 2013, 21:09:40 »
sprit, since i just ordered the acrylic case few days ago and your paypal isn't working yet, will the case be in first production or join round 2 batch?
Offline sprit
« Reply #734 on: Sun, 01 December 2013, 21:14:21 »
1st or 2nd Batch, Does It Really matter to You?  My friend justnits ?    :)
On Weekend, everyone and bank supposed to have a break, I guess, doesnt It?    :)        I am a Very Slow Korean, Please Remember that! ;)
« Last Edit: Sun, 01 December 2013, 21:43:01 by sprit »
Offline justnits
« Reply #735 on: Sun, 01 December 2013, 21:39:08 »
sorry, it's already monday morning (going to be afternoon) in my area, forgot that almost half of the world is still in Sunday :(
was just wondering about it since what i understand is that 2nd batch will start when it reaches it's MOQ? so it will be slower compared to first batch.
Offline nuclearsandwich
« Reply #736 on: Sun, 01 December 2013, 21:45:43 »
Either production has already started for the first round or the entire first round will be delayed so sprit can process payments. If you met MOQ in round 1 you're probably fine.
Offline sprit
« Reply #737 on: Sun, 01 December 2013, 21:46:24 »
I Put it down On the First Page, like this :
All the Invoices will send Slowly in this week!
Pay Slow, No Rush!  please
« Last Edit: Mon, 02 December 2013, 02:47:17 by sprit »
Offline sprit
« Reply #738 on: Sun, 01 December 2013, 21:51:00 »
For the 1st Batch (Order),  I did put my own extra orders to meet each MOQ.
The 2nd week Orders give more for the Total MOQ.
All MOQ for PCBs are OK!    No Problem at All!       Thanks to KeyBoard Goddess !
Please, Give some Time to process all !
Who buggs me Extreamly too much, will be excluded from the Next Order.
I am not a saint at all.   Sorry!
« Last Edit: Sun, 01 December 2013, 22:07:08 by sprit »
Offline cookiesowns
« Reply #739 on: Sun, 01 December 2013, 21:52:20 »
Your Order is :
PCB  87%   3
PCB  110 %  1
Case  110%  1
Sent you PM =)
Thank you for the hard work Sprit, awesome stuff. I really wish there was just more picture or examples of the cases, so I can solidify my decision. WAYY TOO MANY CHOICES~!
Offline HPE1000
  • Keycap Paparazzo
« Reply #740 on: Mon, 02 December 2013, 00:36:25 »
Do you think round 1 will be shipped before Christmas or the end of the year?  :)
Offline cookiesowns
« Reply #741 on: Mon, 02 December 2013, 01:57:41 »
I hope I'm not one of those people!!! Really want to make sure I make the right decisions, I'm the type of person that prefers to shop right, and at one shop, instead of sourcing with a variety of different shops, so I hope you understand SPRiT!!
Again, thank you for all the help! Can't wait!
Offline sprit
« Reply #742 on: Mon, 02 December 2013, 01:58:13 »
Which Christmas,  Orthodox or Catholic?, Which Calendar Sir?   ;)
I Hope So,  to Any Kalendar!
« Last Edit: Mon, 02 December 2013, 06:56:53 by sprit »
Offline stoic-lemon
« Reply #743 on: Mon, 02 December 2013, 04:50:26 »
Haha! Best answer ever!
Offline HPE1000
  • Keycap Paparazzo
« Reply #744 on: Mon, 02 December 2013, 07:41:38 »
By the 25th of December :)
Offline sprit
« Reply #745 on: Mon, 02 December 2013, 09:20:33 »
" Ok! What's NeXT? "
46552-0   " A Proper Case, Buddy "
« Last Edit: Mon, 02 December 2013, 09:22:36 by sprit »
Offline sprit
« Reply #746 on: Mon, 02 December 2013, 09:29:36 »
" My Better Board...  Much More Comfy than The Metal Frame ..."
46554-0
" Hey! ... Bunch of MetaLLL Lovers Out There ... "  ....  They Are Kraziiiiiii
« Last Edit: Mon, 02 December 2013, 11:07:49 by sprit »
  • Live long and prosper
« Reply #747 on: Mon, 02 December 2013, 09:30:42 »
Still haven't gotten an invoice or confirmation email. Not complaining, I can't pay the invoice right now anyways, just wondering if I fell between the cracks or something and my order was lost...
tp thread is tp thread
Offline sprit
« Reply #748 on: Mon, 02 December 2013, 09:35:55 »
Paypal Initial Setup Procedures! Captain!   :)   Your Confirmation & Invoice Email will come!    I've sealed the Cracks with my own sealants.
We can wait till Wednesday this Week, They Say.
« Last Edit: Mon, 02 December 2013, 10:30:13 by sprit »
Offline Latin00032
« Reply #749 on: Mon, 02 December 2013, 10:53:32 »
Hey Sprit,
Did I sign up for the metal case moq check?
I don't remember. I don't want to put a duplicate.
Thanks.
