Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224325 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
filled in the form and for a 60% with blue, hopefully the shipping to Aus does not kill me :o
Hi Mate?   Wher' About Aus?   ;)
im in Brisbane QLD
also do i just resubmit the from to change the order, i want to change the colors of the case plates.
No Worries!!  ;)   The Hot Queen's Land !!
« Last Edit: Fri, 22 November 2013, 05:38:48 by sprit »
Offline PepperPanda
Re: SPRIT Model 1 PCB : Poker 60% 75% 87% 110% : ANSI+ISO (Full LED + Macro)
« Reply #451 on: Fri, 22 November 2013, 03:25:24 »
Did you ever hear back about the stabilizers?
Offline sprit
« Reply #452 on: Fri, 22 November 2013, 04:26:26 »
60% Poker Compatible - Outline : ANSI Only = Very Old Version (40 days Old)
87% TKL  PCB - Outline  : ANSI Only = Very Old Version (50 days Old)
110%  ANSI+ISO  New Version (15 days Old)
« Last Edit: Fri, 22 November 2013, 05:31:56 by sprit »
Offline sprit
« Reply #453 on: Fri, 22 November 2013, 05:24:35 »
110% PCB  V0.2  (A 87 Ext.)  ANSI+ISO  (6 days old)
45401-0
Our GH Version will be 1.6mm Thick PCB,    White, Red, Blue, Black Colored.
« Last Edit: Fri, 22 November 2013, 16:28:33 by sprit »
Offline akikun
« Reply #454 on: Fri, 22 November 2013, 05:37:08 »
Whoa! You've extinguished the last bit of indecision I had over which color to get.
Anyway, I submitted the form about a day ago (1 white 60% PCB, 1 clear acrylic plate). Should I be expecting an email or confirmation of some sort? (Sorry if this is a silly question; this is my first GB!)
Offline Elias Camber
« Reply #455 on: Fri, 22 November 2013, 05:39:04 »
details on the PCB look really awesome.
Just read that you said you'll be sending confirmation emails... are you sending them imediately after receiving orders, or you just send them on the 23. when orders are closing? Because up till now I got no confirmation on the order... I do GB for the first time so please bare with me.  :)
Offline Biased opinion
« Reply #456 on: Fri, 22 November 2013, 05:41:00 »
do i just resubmit the form to change the group buy order.
Offline sprit
« Reply #457 on: Fri, 22 November 2013, 05:41:06 »
The stabilizers issue, I am talking to a Big dealer in Asia.  I will tell You Soon!   My Dear  PepperPanda !!
Offline sprit
« Reply #458 on: Fri, 22 November 2013, 05:42:31 »
No Problem at all !!   The Sprit-Bot
is here For YOU!
« Last Edit: Fri, 22 November 2013, 06:03:20 by sprit »
Offline sprit
« Reply #459 on: Fri, 22 November 2013, 05:46:28 »
Don't Worry,  Freunde!   Everything will be OK,  I will Take Care ALL the Details!
Bald wird Alles Gute!
« Last Edit: Fri, 22 November 2013, 06:01:59 by sprit »
Offline pasph
« Reply #460 on: Fri, 22 November 2013, 08:48:12 »
What led's colors can be ordered?
I'm waiting also the stabs to do the order.
« Reply #461 on: Fri, 22 November 2013, 10:14:06 »
That is what I was waiting for! Putting together an order now.
(For my hands, a thick PCB doesn't need a plate, especially with light springs.)
Offline HPE1000
  • Keycap Paparazzo
« Reply #462 on: Fri, 22 November 2013, 14:25:02 »
So I might order but I was wondering, do you have any estimate how much shipping would cost for a 60% pcb and 4mm thick aluminum plate? Thanks :)
Also, what color leds are available?
I am in the US.
Offline longweight
  • philanthropist
« Reply #463 on: Fri, 22 November 2013, 14:26:02 »
The LED colours are in the form.
Offline pasph
« Reply #464 on: Fri, 22 November 2013, 15:19:40 »
It don't mention what colors are available:
"LED High Brightness : 90pcs = 8 USD, 110pcs = 10 USD, MultiColor 20pcs = 10 USD  *"
Offline longweight
  • philanthropist
« Reply #465 on: Fri, 22 November 2013, 15:21:07 »
Ah... It did a few days ago.
Offline sprit
« Reply #466 on: Fri, 22 November 2013, 16:14:29 »
Sorry For That!!  OOPs  !  I Updated the Color Options for LED!
Offline ninjadoc
« Reply #467 on: Fri, 22 November 2013, 16:53:12 »
Is there a way to check our order? I ordered yesterday and added a PCB today by submitting a new order and I wanted to verify my order was correct.
Offline sprit
« Reply #468 on: Fri, 22 November 2013, 17:02:23 »
Hello NinjaDoc !
Your Order is : 1 Black 75%   1 Blue 87%   1 White 110% PCBs etc
I will check Every Order, and I will Send You  'THE Order Confirmation Email ' by ~24th Sunday.    ;)
« Last Edit: Fri, 22 November 2013, 17:46:58 by sprit »
Offline debt4lyfe
  • time puts a gun in every hand
« Reply #469 on: Fri, 22 November 2013, 17:36:21 »
When should I expect the confirmation email?
Offline sprit
« Reply #470 on: Fri, 22 November 2013, 17:47:29 »
Offline HPE1000
  • Keycap Paparazzo
« Reply #471 on: Fri, 22 November 2013, 17:53:27 »
Sorry for asking again but I am thinking of ordering tonight but I just wanted to know how much you think shipping for a 60% pcb and plate to the US would be?
Also, what is the difference between the 1.6mm aluminum plate and the 4mm aluminum plate?
Offline sprit
« Reply #472 on: Fri, 22 November 2013, 18:34:38 »
The Shipping Cost will be under 20 USD  for You.  and I am organizing a Proxy Shipping to US.
Offline AKmalamute
  • HHKB Scrub
« Reply #473 on: Fri, 22 November 2013, 18:43:55 »
What is the difference between the 1.6mm aluminum plate and the 4mm aluminum plate?
About 2.4mm by the look of it.
(I'll be here all week, folks!)
Spirit I'd be curious if you've weighed the two aluminum plates ... I'm thinking specifically for 60% but a comparison of any of them would be fine ... the thickness is 2-1/2x more, so is the weight pretty close to that much more, too? or does it work out that it's more, or less than that?
Thanks for your patience in putting up with all these endless questions from the forumites; I know it must get old but think of how famous the FaceW keyboard could be in twenty years  :cool:
HHKB-lite2, Dvorak user
Offline pasph
« Reply #474 on: Fri, 22 November 2013, 18:45:02 »
Wish for a Proxy Shipping to EU...
Offline stancato9
« Reply #475 on: Fri, 22 November 2013, 18:50:09 »
I'm so confused... what do I need to order if I just want a pcb and plate that supports 1.5x 1x 1.5x on the bottom row? I don't see a plate price anywhere? What's the difference between all the plates?
Poker 2 - MX Red
Offline sprit
« Reply #476 on: Fri, 22 November 2013, 19:19:56 »
45489-0  My PCBs Support 1.5x 1x 1.5x
If SW Spring is Under 65g,  I Recommend Acryl 5mm Plate,
If You enjoy the Strong, Power-Typing,  I 'd Recommend  Dura-Alu 4mm Plate !!
« Last Edit: Fri, 22 November 2013, 19:22:38 by sprit »
Offline stancato9
« Reply #477 on: Fri, 22 November 2013, 19:22:04 »
What are the prices? I can't find that anywhere.
Poker 2 - MX Red
Offline HPE1000
  • Keycap Paparazzo
« Reply #478 on: Fri, 22 November 2013, 19:23:42 »
Last question, for the 4mm thick one, since it is an aluminum and acrylic layer do I just tell what color I want each layer in the comments of the order form? I want the aluminum and acrylic layers to both be lime green, that is possible right?
Thanks for all the help, that is the last question I have :)
Offline sprit
« Reply #479 on: Fri, 22 November 2013, 19:23:44 »
No Problem At All !    Prices :  in The 1st page of this Topic.  The Color options have MOQ = minimum order qty for the factory.
« Last Edit: Fri, 22 November 2013, 19:27:56 by sprit »
Offline stancato9
« Reply #480 on: Fri, 22 November 2013, 19:26:29 »
I see now. I missed it somehow. What's the most well-rounded plate? Are there any color samples?
« Last Edit: Fri, 22 November 2013, 19:32:45 by stancato9 »
Poker 2 - MX Red
Offline sprit
« Reply #481 on: Fri, 22 November 2013, 19:42:10 »
We need to discuss this,  Mr. pasph!   Could you organize a collective = proxy shipping to EU continent?    :thumb:
Offline stancato9
« Reply #482 on: Fri, 22 November 2013, 19:46:49 »
Can someone run me through the pros and cons of each plate?
Wouldn't the thickest metal plate be the best?
Poker 2 - MX Red
Offline ithinkimkorean
« Reply #483 on: Fri, 22 November 2013, 19:56:50 »
Can't have translucent metal.
or can you?
Offline stancato9
« Reply #484 on: Fri, 22 November 2013, 20:07:40 »
or can you?
Well besides that. :p Wouldn't the thickest, toughest material be regarded the best, regardless of switch/spring type?
Won't acrylic still flex?
Poker 2 - MX Red
Offline HPE1000
  • Keycap Paparazzo
« Reply #485 on: Fri, 22 November 2013, 20:11:39 »
or can you?
4mm plates sounds really thick.  Is anyone getting those as well?  What's the difference between PolyAcry and PolyCarb?  I know they are different materials, but has anyone used both?
Edit: Ordered!
http://www1.kbdmania.net/xe/freeboard/7302594
The Maximum thickness for MX is 5mm.    In this GB,
1. Acryl Plate : 5mm (5T) thick :  In My Opinion :  Strong and Soft, Rigid enough ...
2. PolyCarbon : 1.6mm thick :  In My Opinion : quite Strong and flexible, ...
3. Alu Metal  :  1.6mm thick :  In My Opinion : Noisy, Not Strong enough, we know its pros and cons.
4. Alu Metal  :   4mm + 1mm PolyAcryl  : In My Opinion :   Armour itself.
Offline stancato9
« Reply #486 on: Fri, 22 November 2013, 20:20:36 »
Thanks ^ haha
Let me get this straight.
Is this 2 plates on top of each other? Can the acrylic layer be removed? Which one goes on top? Thanks!
Poker 2 - MX Red
Offline HPE1000
  • Keycap Paparazzo
« Reply #487 on: Fri, 22 November 2013, 20:21:38 »
Thanks ^ haha
Based on the pictures on that link it looks like the ALU sits on top while the acrylic layer is on the bottom between the aluminum and pcb.
Offline stancato9
« Reply #488 on: Fri, 22 November 2013, 20:25:03 »
Thanks ^ haha
Yeah, looks like that. I was hoping that it might have been the other way around. That would allow for some really interesting color combinations.
Poker 2 - MX Red
Offline HPE1000
  • Keycap Paparazzo
« Reply #489 on: Fri, 22 November 2013, 20:50:07 »
I ordered
1 black 60% pcb
1 Lime Green 4mm backplate
Green Leds
I hope I filled out the form correctly. What happens if the backplate doesn't hit the MOQ? I REALLY want a lime green 4mm backplate :)
« Reply #490 on: Fri, 22 November 2013, 20:50:59 »
Having typed on both, I will say that PCB mount keyboard flex is pretty nice on a lot of keyboards.
I think the thin flexible polymer plates help to preserve this.
Remember: keyboarding is very subjective: the thickest / strongest is not always the bestest.
Offline stancato9
« Reply #491 on: Fri, 22 November 2013, 20:51:48 »
The 60% pcb and plate support 1.5 1 1.5 right?
Poker 2 - MX Red
Offline JPG
  • Model F is my new passion!
« Reply #492 on: Fri, 22 November 2013, 20:53:17 »
I sent my order again to add leds. No stabilisers available?
Also, form force you to say yes to plate even if you don't need one  :p
Offline stancato9
« Reply #493 on: Fri, 22 November 2013, 21:05:53 »
Sprit, for the $40 plate option, how do we let you both colors we want for each part?
Poker 2 - MX Red
Offline Melanic
« Reply #494 on: Fri, 22 November 2013, 21:34:51 »
I should have problem asked this earlier.
If I use a metal plate and metal case, can I even see the LEDs? (sorry for the newbie question)
If not I'll have to change my order...
Offline stancato9
« Reply #495 on: Fri, 22 November 2013, 21:47:41 »
Yes, that will have no effect on the LED visibility.
Poker 2 - MX Red
Offline Melanic
« Reply #496 on: Fri, 22 November 2013, 22:14:37 »
Oh, that's good.
Thanks.
Offline sprit
« Reply #497 on: Fri, 22 November 2013, 23:38:38 »
I put the Horizontal LED Effects in My Design,  Not 100% satisfactory enough for me, but We can make it better, don't we?
« Last Edit: Sat, 23 November 2013, 07:08:48 by sprit »
Offline cookiesowns
« Reply #498 on: Sat, 23 November 2013, 07:17:55 »
Pretty new to the PCB / Plate scene.
But I'm assuming the most 87% and 110% layout cases would fit right? Such as a DK9008G2?
Sprit, do you have anymore pictures of the 110% and 87% PCB, with the various plate options?
EDIT: Sprit, what's ETA for batch 2? Would MOQ still apply for Batch 2?
EDIT 2: Sprit, cancel my order for now. Will wait for batch 2 so I can make up my mind on all your awesome options!
« Last Edit: Sat, 23 November 2013, 07:31:35 by cookiesowns »
Offline sprit
« Reply #499 on: Sat, 23 November 2013, 07:47:15 »
But I'm assuming the most 87% and 110% layout cases would fit right? Such as a DK9008G2?      Mostly
Sprit, do you have anymore pictures of the 110% and 87% PCB, with the various plate options?     You can find the Phantom Plate Topics http://geekhack.org/index.php?topic=39410.0
EDIT: Sprit, what's ETA for batch 2? Would MOQ still apply for Batch 2?   Factory MOQ Always applies
EDIT 2: Sprit, cancel my order for now. Will wait for batch 2 so I can make up my mind on all your awesome options!   I've cleared it.
