Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224035 times)
Offline SlithyDash
Re: (Order) SPRIT Model 1 : PCB for 60% 75% 87% 110% : ANSI+ISO (Full LED + Macro)
« Reply #250 on: Sat, 16 November 2013, 23:34:13 »
Does anybody else have the problem when ordering where you had to select all the PCB, plate, ect.. options in order to submit it? I wrote what I wanted in the comments but it seems inefficient and is probably just a kink.
« Reply #251 on: Sat, 16 November 2013, 23:59:27 »
Yup.  There are too many required fields.
Offline IMHB
« Reply #252 on: Sun, 17 November 2013, 00:11:15 »
yea this form is not really working out...all the fields are required to enter...
I'm only buying one plate but it requires me to put the color of all kind of plates in...and so are the comment sections. Then when I hit enter it doesn't let me enter because since I chose 4 different plate colors, it requires me to enter to buy 4 PCBs....
Well, I only want to buy 1 PCB and 1 plate...but I cannot fill my form right now....yea that's a problem I guess...
Offline nuclearsandwich
« Reply #253 on: Sun, 17 November 2013, 00:56:27 »
I PM'd Sprit an alternate form suggestion I created but they either missed it or haven't had a chance to look yet.
The form is here: https://docs.google.com/forms/d/1F30QWBuQNi9O7u1j3eG3RYtOlmIq-LuxLB1kp8PoT0s/viewform?usp=sharing
I did my best to replicate the shopping cart style experience Ctrl Alt Store has put together without having to write a custom Rails app (hat tip codyeatworld)
If there's any feedback I'll do my best to incorporate it. It's till long but hopefully more straightforward.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #254 on: Sun, 17 November 2013, 01:14:00 »
Please use this form, I know it might be long, but there is no way to make it smaller, when you have so many customization options (Speaking from experience)
Offline IMHB
« Reply #255 on: Sun, 17 November 2013, 01:15:04 »
yes this form is much better than the last one...I will wait for Sprit's response for this and will probably use this one.
Offline bianco
« Reply #256 on: Sun, 17 November 2013, 01:58:06 »
the choices for the 110% plates are for 87% plates instead.
« Reply #257 on: Sun, 17 November 2013, 02:17:10 »
Thanks. Fixed!
Offline bianco
Offline akikun
« Reply #259 on: Sun, 17 November 2013, 02:28:32 »
Thanks. Fixed!
This form seems much easier to grasp than the original... is it possible to not order one of each plate in the original?
Should there be a field for GH username?
Offline AKmalamute
  • HHKB Scrub
« Reply #260 on: Sun, 17 November 2013, 02:41:48 »
still holding off until official mention of the ALPs PCB. I'm thinking I probably want a 75% too but I'm holding off on that for other reasons. Also, I only want to order once.
HHKB-lite2, Dvorak user
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #261 on: Sun, 17 November 2013, 04:00:41 »
Hello!   AKmalamute!
ALPS PCBs Are going well,   I will get the Final Candidate PCBs in 10 days!
Offline sprit
« Reply #262 on: Sun, 17 November 2013, 04:02:55 »
Thanks !!   Looks Better!
I was Busy to have some meetups on this weekends.
I will Update the forms Right Now,   I am at home ,  Got into GH now!   Happy!   :)
« Last Edit: Sun, 17 November 2013, 04:06:10 by sprit »
Offline sprit
« Reply #263 on: Sun, 17 November 2013, 04:07:31 »
Thanks !! Mr. MOZ!  It  Looks Better!
Offline tjweir
« Reply #264 on: Sun, 17 November 2013, 04:09:59 »
I can't submit, since I have to answer questions that are not applicable.
See attached.
Offline sprit
« Reply #265 on: Sun, 17 November 2013, 04:17:38 »
OK I will fix It right Now
You can Put A dot  in it!     .
Offline tjweir
« Reply #266 on: Sun, 17 November 2013, 04:20:06 »
Thanks, I did not want to fill the form with garbage characters. :S
Offline longweight
  • philanthropist
« Reply #267 on: Sun, 17 November 2013, 04:39:39 »
Can you make the address box bigger so that I can put my address in line by line please?
Offline sprit
« Reply #268 on: Sun, 17 November 2013, 04:47:06 »
This Order Form is well considered for the OP,  for myself.
I'd like to go on with this, if there is no fatal problem.
Offline tjweir
« Reply #269 on: Sun, 17 November 2013, 05:07:47 »
I cannot seem to submit, regardless of the options I pick.
See attached.
Offline christkind
« Reply #270 on: Sun, 17 November 2013, 05:08:40 »
See attached.
Have the same problem :(
Offline sprit
« Reply #271 on: Sun, 17 November 2013, 05:09:12 »
OK!  wait a min!   You May Try again?   :)
« Last Edit: Sun, 17 November 2013, 06:03:40 by sprit »
Offline tjweir
« Reply #272 on: Sun, 17 November 2013, 05:32:35 »
Still no luck.
I am attempting to order the following:
3 x 75% PCB - all 3 white
2 x 75% 1.6 mm plate - 1 red and 1 gun metal
Sprit, will you attempt to fill in an order like mine, you'll hit the same problems I am.
Offline sprit
« Reply #273 on: Sun, 17 November 2013, 05:59:06 »
I' ve Fixed the Problems!   Sorry for That !  :)
The Order Form is now OK?
« Last Edit: Sun, 17 November 2013, 06:10:48 by sprit »
Offline Jmneuv
« Reply #274 on: Sun, 17 November 2013, 06:05:37 »
Can you comment on shipping costs yet?
Offline sprit
« Reply #275 on: Sun, 17 November 2013, 06:09:16 »
Hello~ Jmneuv !  I will put the shipping costs in the Payment Page !  Thx   :)
Offline longweight
  • philanthropist
« Reply #276 on: Sun, 17 November 2013, 06:10:42 »
Ordered.
Offline sprit
« Reply #277 on: Sun, 17 November 2013, 06:13:48 »
Ordered.
Hello!  longweight~   One  60% PCB / Black  is it OK?
  • Live long and prosper
« Reply #278 on: Sun, 17 November 2013, 06:19:34 »
I loled at this:
Are You Sure with PCB Orders ?
[  ] Yes!  I am very Sober!
[  ] No, Sorry! I might be drunken!
Ordered.
tp thread is tp thread
Offline christkind
« Reply #280 on: Sun, 17 November 2013, 06:25:50 »
Thanks! Everything OK :)
Offline sprit
« Reply #282 on: Sun, 17 November 2013, 06:28:42 »
ok. now i'm confused. which form?
Thx!  I have only one Form!    The Form on the first  OP Page!
(Don't make any other Form for me plz !  :)     I can read and think in a Human way! )
Order Form : OPEN  Now ! >>>   https://docs.google.com/forms/d/1YmnYaks71dM2vMp5dFDxgIPdPQGWHKYwLCmf3GfSVTM/viewform
« Last Edit: Sun, 17 November 2013, 07:21:42 by sprit »
« Reply #283 on: Sun, 17 November 2013, 06:30:35 »
Whew, good. Thought I might have filled out the wrong one for a second there...
Offline longweight
  • philanthropist
« Reply #284 on: Sun, 17 November 2013, 06:30:37 »
Ordered.
That is correct for the time being :)
« Reply #285 on: Sun, 17 November 2013, 06:32:04 »
I loled at this:
Ordered.
Seems very legit!
Offline bianco
« Reply #286 on: Sun, 17 November 2013, 06:34:30 »
Thx!  I have only one Form!    The Form on the first  OP Page!   (Don't make any form for me !  :)   plz,  I can read and think in a Human way! )
ok. thanks sprit
Offline longweight
  • philanthropist
« Reply #287 on: Sun, 17 November 2013, 06:35:47 »
Sorry I have a quick question, are the resistors for the full LED layout pre-soldered?
Offline sprit
« Reply #288 on: Sun, 17 November 2013, 06:36:58 »
I loled at this:
Ordered.
Seems very legit!
I am Not Sober now at All ! :)    On Friday and Saturday, I got several Meet-Ups with Friends, from Perth, Adelaide, Plymouth, Sussex, Frankfurt, MosKow, Missouri, Michigan,  Madrid, Singapore, Toronto, ....
Too many Shots... Killed me last night...  Still sick.  :(     I need a Noodle Soup with tomatoes !
:D
« Last Edit: Sun, 17 November 2013, 07:12:27 by sprit »
Offline catbuster
  • Fusion is Future
« Reply #289 on: Sun, 17 November 2013, 06:38:11 »
This will have second round right? I would be in for 60%, plate and case if i like the design  >:D
Poker 2 (black) 60% mx red
« Reply #290 on: Sun, 17 November 2013, 06:38:26 »
I loled at this:
Ordered.
Seems very legit!
I am Not Sober now at All ! :)    On Friday and Saturday, I got several Meet-Ups with Friends, from Perth, Adelaide, Plymouth, Sussex, Frankfurt, Madrid, Singarpore, Toronto, ....
^this, is legit as ****. :thumb:
Just don't get drunk when you're processing all these orders! :))
Offline sprit
« Reply #291 on: Sun, 17 November 2013, 06:41:56 »
OK!  Capitant!!   :thumb:     When You come to Seoul,  or Hongkong,   You will be My Guest !
« Last Edit: Sun, 17 November 2013, 06:46:52 by sprit »
Offline JPG
  • Model F is my new passion!
Re: [Order] SPRIT Model 1 : PCB for 60% 75% 87% 110% : ANSI+ISO (Full LED + Macro)
« Reply #292 on: Sun, 17 November 2013, 08:06:20 »
Order placed for 60% pcb!
Offline elllit
« Reply #293 on: Sun, 17 November 2013, 09:18:03 »
I filled in zeros in the fields that don't apply to me, is that ok?
For example I don't even have another phone besides my mobile. Also, do you really need my phone number? *scratches head*
Offline naokira
  • The King in the North
Hi Spirit, I do not know which is the street number in the address of my korean friend so I just put his name with me.
and his address in THE END section.
Sorry! <3
FaceW in LZ-CE
Offline osxoep
I don't have a 2nd address, don't use MSN or Skype (or any other messaging) and don't have another phone number other than a mobile.
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline fatchoi
Oh, cheaper shipping to Hongkong then? :P
I've just ordered 1x 87 pcb and a case.
Offline sprit
« Reply #297 on: Sun, 17 November 2013, 10:04:11 »
Of Cause 100%  OK!
Offline witchinghour
I would like to order but i'm not sure that I can get new switches without blowing my budget
Offline goobus
  • HHKB Elite
4mm plates sounds really thick.  Is anyone getting those as well?  What's the difference between PolyAcry and PolyCarb?  I know they are different materials, but has anyone used both?
Edit: Ordered!
« Last Edit: Sun, 17 November 2013, 11:13:33 by goobus »
