Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224534 times)
0 Members and 7 Guests are viewing this topic.
I guess I need to order something :P
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Orange,  Lime Green        >>  http://www1.kbdmania.net/xe/photo/7677397
45111-0
« Last Edit: Wed, 20 November 2013, 10:56:04 by sprit »
Offline cruk
  • :> keys
Re: SPRIT Model 1 PCB : Poker 60% 75% 87% 110% : ANSI+ISO (Full LED + Macro)
« Reply #402 on: Wed, 20 November 2013, 17:52:02 »
This is so confusing, there are too many choices, put indecisive people like me in a difficult position.
If im ordering 1x60, 1x75, i believe i need to specify which plates for which?
If SW Spring is Under 65g,  I Recommend Acryl 5mm Plate,
If You enjoy the Power-Typing,  I 'd Recommend  Dura-Alu 4mm Plate !!
I meant to say that if i have two different size boards, i need two different size plates and have to specify those on the form right? Thanks
Offline sprit
« Reply #403 on: Wed, 20 November 2013, 18:45:02 »
You can Change, or Resend  Your Order Form at Anytime Before the Payment. !!    ;)      No Trouble For me at all !
Offline ithinkimkorean
« Reply #404 on: Wed, 20 November 2013, 18:54:55 »
Can you make sure I picked clear switches and not reds? I was deciding between the two and forgot what I picked.
+ 55g springs
« Last Edit: Wed, 20 November 2013, 18:56:40 by ithinkimkorean »
Offline sprit
« Reply #405 on: Wed, 20 November 2013, 20:24:27 »
+ 55g springs
Hello!   IthinkimKorean !    Would You Plz, Send me a New Order Form ?    Previous Order seems a little bit Not clear.    Thx   ;)
Offline JPG
  • Model F is my new passion!
« Reply #406 on: Wed, 20 November 2013, 20:30:07 »
Hey are the custom springs gold?
Offline bladegesnow
« Reply #407 on: Wed, 20 November 2013, 20:43:20 »
A new order form sent XD
More and more and more...
Offline sprit
« Reply #408 on: Wed, 20 November 2013, 20:51:22 »
The Custom Springs are Very Cherry Original Like,  Not a Pointless Korean gold!
« Last Edit: Wed, 20 November 2013, 20:53:10 by sprit »
« Reply #409 on: Wed, 20 November 2013, 20:56:35 »
+ 55g springs
Ok finished new form  ;D
Offline sprit
« Reply #410 on: Wed, 20 November 2013, 21:00:00 »
+ 55g springs
Your Order Well  Transmitted !!  Bon Voyage !   Captain 116 !
Offline alixinhzai
« Reply #411 on: Wed, 20 November 2013, 21:27:29 »
ordered :D thx u
Offline sprit
« Reply #412 on: Wed, 20 November 2013, 23:51:57 »
 Kaffe  Break
45227-0    45229-1
Offline nuclearsandwich
« Reply #413 on: Wed, 20 November 2013, 23:54:27 »
Do any of the PCB options support the two columns of function keys on the left?
Offline sprit
« Reply #414 on: Thu, 21 November 2013, 00:02:31 »
SPRIT  Model 2 will show the End Of December,  They have PCBs Like That.  Sir!
http://www1.kbdmania.net/xe/photo/7652156
45231-0
Offline Permeability
« Reply #415 on: Thu, 21 November 2013, 00:09:55 »
Hi sprit, is the multicolor LED an LED that can change colors? Or a mix of different LEDs that have only 1 color?
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #416 on: Thu, 21 November 2013, 00:22:34 »
Awesome. That thing is so long you could surf on it.
Offline Loligagger
« Reply #417 on: Thu, 21 November 2013, 00:53:59 »
Would it be possible to order 70g springs alone?
Offline sprit
« Reply #418 on: Thu, 21 November 2013, 00:55:09 »
Sure !!  Loligagger !
Offline Melanic
« Reply #419 on: Thu, 21 November 2013, 02:22:13 »
Hello, just a few questions.
Do the PCBs have LEDs on them as default, or will I need to get some High Brights/MultiColors? Do they come with resistors?
Will you have pictures of the metal cases before the order deadline for the PCBs?
Would it be alright to mix and match switches for the 90/110 pieces? eg: 20 black + 70 red
Thanks.
Offline sprit
« Reply #420 on: Thu, 21 November 2013, 07:06:32 »
Thanks.
THX   ;)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #421 on: Thu, 21 November 2013, 08:03:38 »
Filled out the order form for 1 white PCB with clear acrylic plate.
Offline sprit
« Reply #422 on: Thu, 21 November 2013, 08:55:28 »
Your Order Transmission Completed.  No Data deletion Detected.  Sir!
« Last Edit: Thu, 21 November 2013, 09:27:03 by sprit »
Offline Melanic
« Reply #423 on: Thu, 21 November 2013, 09:53:37 »
Thanks.
THX   ;)
Sorry? I don't think you answered any of the questions.
 Kaffe  Break
(Attachment Link)     (Attachment Link)
But, I did notice one of your latest pictures. Are those the aluminum cases?
Offline sprit
« Reply #424 on: Thu, 21 November 2013, 10:17:37 »
Sorry for Quick answer, I had to talk with my Family.
LED : You need to solder to your taste
Alu case :  will show soon in a week
When You read the first page of this Topic,  I hope You will get the answers!
Offline keymaster
  • Topre Revolution Theorist
« Reply #425 on: Thu, 21 November 2013, 10:28:46 »
Is it possible to purchase just a few LEDs of various colors? I don't need a mix of 20 pieces. I would just like to get like 2 piece orange/amber LEDs in addition to my 110 White LEDs.
Offline sprit
« Reply #426 on: Thu, 21 November 2013, 10:43:05 »
I will Send 2 piece orange/amber LEDs into Your 110 pcs White LED's .  I will make a comment on your Orders!  My Friend!
Offline keymaster
« Reply #427 on: Thu, 21 November 2013, 10:44:25 »
Thank you so much! I'm very excited to build this keyboard and I'm sure our Korean overlords will not disappoint.  :thumb:
Offline pasph
« Reply #428 on: Thu, 21 November 2013, 10:48:21 »
Orders will close on Nov.23?
Offline sprit
« Reply #429 on: Thu, 21 November 2013, 10:52:20 »
Yes!  Pasph !  ;)      The 1st Wave of Order is near MOQ  and needs go to into Production in the Factories.
The 2nd Wave of Order Will open on 25th.
« Last Edit: Thu, 21 November 2013, 10:57:49 by sprit »
Offline hermith
« Reply #430 on: Thu, 21 November 2013, 11:37:07 »
I have a couple of things I was a bit curious about if you don't mind answering Sprit (or anyone else for that matter!).
1. How important is it to have a plate? So far I haven't ordered any plate to save money - but reading this thread makes me uncertain.
2. Is it possible to change the key bindings by flashing the controller directly?
Offline ninjadoc
« Reply #431 on: Thu, 21 November 2013, 11:54:26 »
2. PolyCarbon : 1.6mm thick :  In My Opinion : quite Strong and flexible,
What happened to this plate?
It cannot be ordered.
Offline yicaoyimu
« Reply #432 on: Thu, 21 November 2013, 12:00:58 »
After reading the first 9 pages of this thread, I realised that the plate is not for 60% PCB  :eek:
Guess I will have to find a plate somewhere else then...
Sprit, could you help me change my order to PCB only? Or I can put in another order, whichever works best for you.
« Reply #433 on: Thu, 21 November 2013, 12:04:27 »
Why do you say that the plate is not for 60%? As far as I can tell there is corresponding plate and case for every PCB offered.
Offline Elias Camber
« Reply #434 on: Thu, 21 November 2013, 12:08:50 »
alright... hmm... alright, damn it... you got me.
It's too good to be missed,
ordered.
Would it be right to say that the custom springs 65g are about halfway in between reds and blacks?
Offline yicaoyimu
« Reply #435 on: Thu, 21 November 2013, 12:26:30 »
OP says "Phantom Style Plates" and the pictures of PCB are 110% and 87%. And there was another form nuclearsandwich created on page 9, trying to make the order form more clear, which does not have an option for 60% plate. Plus, the order form in OP only says plate but no option for plate size. I could be totally wrong. I am so confused.
« Reply #436 on: Thu, 21 November 2013, 12:30:12 »
I would disregard any forms made by anyone other than the OP.
Also if you order a 60% PCB and a plate then you will get a 60% plate, or so I would assume.
« Reply #437 on: Thu, 21 November 2013, 12:36:20 »
Didn't realize I let the suggested form be open for responses. It was just meant to be a suggestion for Sprit on how to clean up the original form and the current one does incorporate my suggestions.
I'm PMing the individuals who put themselves on my form and I've (theoretically) closed it for responses. Apologies for generating confusion in the pursuit of simplicity.
Offline elllit
« Reply #438 on: Thu, 21 November 2013, 12:45:34 »
Updated my order... change my name! No, just kidding! ;)
But I changed a thing or two.
Offline sprit
« Reply #439 on: Thu, 21 November 2013, 17:27:38 »
1. Plates are Good For Stability, if it is  too hard, bad for Your Fingers especially When You Prefer under 70g springs, IMO.
2. That's 100% Right !  Hermith !  :)
Offline sprit
« Reply #440 on: Thu, 21 November 2013, 17:31:37 »
Nice  catch!  Mr. ninjadoc!!  :thumb:      Just For the MOQ.  But What the hell,   I updated for 1.6mm PC PolyCarbon Option!
Offline sprit
« Reply #441 on: Thu, 21 November 2013, 17:54:57 »
ordered.
In my Opinion,  the Cherry MX Springs are Roughly,   MX Red < Brown < Blue < Black < Clear  etc..     I love 65g  too.
Offline sprit
« Reply #442 on: Thu, 21 November 2013, 17:57:19 »
I really love Your Suggestion Mr.!    :thumb:   You helped Me a LOT !!
Offline sprit
« Reply #443 on: Thu, 21 November 2013, 18:00:23 »
Guten Morgen ! Mein Freund  elllit!   Danke Schoen !!   Ich habe Deine Order Forma in meine Hand !
Wie Geht es?  Wo wohnst du?
« Last Edit: Thu, 21 November 2013, 18:02:45 by sprit »
Offline sprit
« Reply #444 on: Thu, 21 November 2013, 18:05:27 »
After reading the first 9 pages of this thread, I realised that the plate is not for 60% PCB  :o
OK!  yicaoyimu!  The Plates are abundant everywhere, I love GH Phantom Plates.  60% 75%  87%  110% Plates are inclued in This GB.
« Last Edit: Thu, 21 November 2013, 18:38:57 by sprit »
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #445 on: Thu, 21 November 2013, 18:10:05 »
dude, ugpm. o_o
Offline sprit
« Reply #446 on: Thu, 21 November 2013, 18:10:34 »
A Form can not include Every contents clearly,   So Here is  a  SPRIT-BOT  for You !
I will check Every Order, and I will Send You  'THE Order Confirmation Email '    ;)
If you want  60% PCB and 75% PCBs,  and when you write 1 Red Acryl Plate,  1 White Alu Plate,  =  I will ask Which plate is for Which PCB.
« Last Edit: Fri, 22 November 2013, 05:37:37 by sprit »
Offline kektr0city
« Reply #447 on: Thu, 21 November 2013, 18:29:23 »
Sprit, can I add 55g springs, 90pcs to my order please?
Offline sprit
« Reply #448 on: Thu, 21 November 2013, 18:40:29 »
OK!  thx.  You can Send a 2nd Order form, this is easier!!   :thumb:
« Last Edit: Fri, 22 November 2013, 05:38:20 by sprit »
Offline Biased opinion
filled in the form and for a 60% with blue, hopefully the shipping to Aus does not kill me :o
Hi Mate?   Wher' About Aus?   ;)
im in Brisbane QLD
also do i just resubmit the from to change the order, i want to change the colors of the case plates.
« Last Edit: Thu, 21 November 2013, 22:01:42 by Biased opinion »
