Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2224369 times)
Offline ithinkimkorean
I'm such a noob when it comes to this.
What plates do I order to replicate this? I want to have black top, clear middle, and black bottom.
And  You will get a Black H-Beam separating the Function Row,  Num Pad, and Arrows. This inclued in Your Case Price  80 USD.
THe Plate...  IF I Should recommend a Plate for Your Black match,
1.   Black PCB + Clear Plate
2.   White PCB + Clear Plate   /    White PCB + White Plate
3.   Red PCB + Clear Plate  ?  Your favorite?
4.  Blue PCB + Clear Plate
5.   Black PCB + Clear Plate  /Black PCB + Black Plate
What is 'Black H-Beam'?
I'm guessing it's the H looking thing that would be put on top of the plate/pcb to seperate the arrows and cluster from the left side of the board. Black because it would be same material is the outer edges.
edit: wo I put the text into the wrong area. How to forum
« Last Edit: Mon, 18 November 2013, 17:57:17 by ithinkimkorean »
Offline Elias Camber
howdy,
one quick question: since it's a phantom style plate... i suppose I can put this into a filco TKL case, or a Cm quickfire rapid? ( the 87% that is)
Very sorry if this is a stupid question...
I might be new here but I already came to apreciate the insane amount of work behind this.
So... thank you.
Offline keymaster
  • Topre Revolution Theorist
Do you have a picture of this? I'm so confused.
With another bar between the function and cluster.
Don't quote me on this though. It's just what I imagined when he described it.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
With another bar between the function and cluster.Don't quote me on this though. It's just what I imagined when he described it.
Your explanation is 100% Right!  Thank You!! :-*
« Last Edit: Mon, 18 November 2013, 22:41:30 by sprit »
Offline naokira
  • The King in the North
Spirit, did you understand my order? Sorry about it! I don't understand Korean address :(
FaceW in LZ-CE
Offline sprit
I am very Sure of Your Order Address to a Korean in Seoul.   :)
Offline sprit
howdy,
So... thank you.
Basically the Details for bolting to the Case is different.
Offline xandr
Okay, maybe I'm missing it somewhere, but are the plates universal to support ANSI and ISO at the same time, or do we have to specify the layout in the order somewhere, Sprit?
Sprit? Any answer to this question?
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline sprit
Ordered  60% and 110% PCB + Al plates, 110 red LEDs, 110 white LEDs.
OK!  I got Your Order!
Offline keymaster
Okay, now I understand completely. However, what I want is to have a clear middle acryllic layer.
So it would be something like this:
1st layer (top): Black
2nd layer (middle) : Clear
3rd layer (bottom: Black
Is this possible with this GB? If so, which parts do I order in the form?
Edit: Basically, I want something like this with clear instead of red
« Last Edit: Mon, 18 November 2013, 22:18:24 by keymaster »
Yeah the order form lets you pick a color for each layer.
Offline sprit
No Worries at All !   I will specify that and I will ask You some days later !! before the factory productions!
Offline keymaster
Are these "plates" the layers?
Edit: I've found the Case GB form /facepalm
//finally ordered both PCB & Case
I, for one, welcome our mechanical Korean overlords  :llama:
« Last Edit: Mon, 18 November 2013, 22:35:01 by keymaster »
Offline IMHB
ordered yesterday, 1 x 60% white PCB with 1.6mm silver alu plate, and all clear acrylic case.
When am I getting the invoice? eager to pay and GET THEM!!!!!
Offline sprit
Oops, after reading your post, I've changed my mind in which plate to order...
And I'm thinking about ordering a few more switches.
How do I change my order please?
You can change your Order form  any time!   We are Not That Hurry!   I will Notice the Order Dead line, in this week!
Offline sprit
I LOVE YOU MY IMHB!!  :)
I am Very Relaxed Korean,  Come Down,  Let's Enjoy the Waiting-ness for this GB !!
Offline sprit
Are there different plates for 87 key, 86 key, 84 key layouts?
Basically One plate supports the  84  86 and 87 % !!
Offline sprit
With another bar between the function and cluster. = H beam for 87 and 110%
You Got Me ! = You are 100% Right!
Please Order as You Know!  My Friend!    :    1st layer (top): Black,    2nd layer (middle) : Clear,    3rd layer (bottom): Black
« Last Edit: Mon, 18 November 2013, 22:40:50 by sprit »
Offline sprit
You Understood MY Design 100% !  I HATE YOU !   ;)
« Last Edit: Tue, 19 November 2013, 01:27:06 by sprit »
Offline sprit
Sample Order Form
44896-0
« Last Edit: Tue, 19 November 2013, 07:28:10 by sprit »
Offline pasph
No stabilizers purchase option?
Offline sprit
I am talking to a Company  for Stabilizers  !   Mr. pasph    :)
« Last Edit: Tue, 19 November 2013, 07:29:07 by sprit »
Offline tjweir
Order resubmitted.
Offline sprit
Order resubmitted.
Order identified!    Hello tjweir  !
Order can be modified at any time!   before the payment
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
I'm curious about the plates. Do you have any photos of those?
Also, it appears that each plate has a different thickness. I'm not an expert when it comes to this, so I'm asking out of ignorance, but having a variance of 1.6mm - 5mm seems pretty wide. Am I wrong?
Offline tjweir
@mashby - http://www1.kbdmania.net/xe/freeboard/7302594
I think that's the 4mm acrylic and further down the 5mm aluminum+acrylic.
Offline sprit
Yes! Sir!     http://www1.kbdmania.net/xe/freeboard/7302594
4mm aluminum+ 1mm acrylic
You are 100% Right!
« Last Edit: Tue, 19 November 2013, 13:10:10 by sprit »
Offline bladegesnow
Order placed couple days ago:
1 white 60% pcb, 1 frosty 5mm Acryl plate, 330 pcs white LEDs
Just wondering, can I get clear plate instead if frosty one cannot meet MOQ in the end?
More and more and more...
Offline sprit
Dont Worry!  MR.  I will do my best !!
Offline keymaster
  • 1x black 87% PCB
  • 1x clear acryllic plate
  • 110x White LED
  • black top layer, clear middle, black bottom
Offline xauser
You are 100% Right!
The acrylic layer below the 4mm metal is used to avoid shortings I assume. How can I order that combo? Order form just lists 4mm metal. Thanks!
Offline sprit
You are 100% Right!
It's Free !  Actually included in 4mm Alu plate order.   I need to Put it on.  Sorry for that !
Offline tjweir
I ordered 2 x "Alu 4mm CNC 40USD" and that includes both a 4mm Aluminum plate and a 1mm acrylic plate?
Offline sprit
Yes!  Exactly!  tiweir !!
Offline tjweir
Nice, thanks!
Offline bladegesnow
Go to sleep sprit! It's late in Seoul!  :D
Offline mashby
    • Mashby
Thanks for clearing that up for me gang. Makes sense that the acrylic would be thicker because there is no space between the plate and the PCB. Duh.  :confused:
Offline sprit
Thanks for clearing that up for me gang. Makes sense that the acrylic would be thicker because there is no space between the plate and the PCB. Duh.  ???
Good Morning Sir!   ;)      The Very Details will show  as I proceed the Production.
The 4mm thick Plate Usually Good for me,   Sometimes  5mm Thick Plate  Good, depends on the MX Switch's Spring, Kind of SW. Keycaps,  Etc...
4mm + 1mm Silicon(or, PolyProphylene) is another Good Combo, as We see in our Shoes.
I will Supply for Free,  and Show You Guys Soon.  Promise!    :)    :)
« Last Edit: Tue, 19 November 2013, 19:47:55 by sprit »
Offline phatdood9
You know I had some to drink when I ordered, I almost checked that box!  :))
Offline sprit
 :thumb:   Hello, Phatdood9 !  I was Drunken When I wrote the Order Form...   Vodka shots, and TeQuilas  for Farewell to My Friends back to Europe.
I wish the new Order Form is more simple, less confusing...   :)
« Last Edit: Tue, 19 November 2013, 23:05:20 by sprit »
Offline gh_pp
awesomeness
Hi sprit or anyone who is kind enough to help a noob (I have never build a custom keyboard before).  Sorry I have a lot of questions.
I want to get a TKL ansi 1.25 regular QFR layout with ergo clear switches.
MX  Custom Springs     55g /  60g / 65g / 68g / 70g   :    110pcs = 8 USD
* What spring should I get for ergo-clear feel? Or do I have to get red/brown springs separately?
* Where can I get the tool to open up the cherry switches to mod the spring and lube?
Dupont    KryTox  104 Oil        20g bottle =  18 USD
* This 20g oil will be enough for building 1~2 TKL keyboards?
PolyAcrylic  5mm 15 USD
PolyCarbon 4mm CNC 35USD
Alu Metal 1.6mm CNC 35 USD
 Alu 4mm CNC 40USD.
* This is the most confusing part, as I only have QFR cherry and I have never opened it up.
Besides the feel (hard plate vs flex), will the different thickness make the keycap lower or higher than normal?
What would be an ideal plate to get for people who always bottom out. (and what would feel similar to filco or QFR?)
* To build this keyboard myself,  besides ordering everything from the form, I still need stabilizer, inserts, keycaps. That's it right?
Since the resistors and controller are soldered on, I just need to get a soldering iron to solder the clear switches onto the PCB/plate?
* Someone asked earlier in this thread but no one answers his question, if one were to get the LED as well, would it make it impossible to change the switches later on without desoldering?
* Also the aluminum case will be available after this group-by and ship separately?
I'd go all out and get the aluminum case instead of getting the plastic case if possible.
Thanks.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline sprit
awesomeness
* What spring should I get for ergo-clear feel? Or do I have to get red/brown springs separately?    65~70g
* Where can I get the tool to open up the cherry switches to mod the spring and lube?   a Clip!  check Topics
1g is OK for 1 TKL keyboard
 Alu 4mm CNC 40USD.
Besides the feel (hard plate vs flex), will the different thickness make the keycap lower or higher than normal? Not at all,
What would be an ideal plate to get for people who always bottom out. (and what would feel similar to filco or QFR?)  Alu Matal 4mm
* To build this keyboard myself,  besides ordering everything from the form, I still need stabilizer, inserts, keycaps. That's it right? stabilizer, inserts will Offered
Since the resistors and controller are soldered on, I just need to get a soldering iron to solder the clear switches onto the PCB/plate? 100% Yes
* Someone asked earlier in this thread but no one answers his question, if one were to get the LED as well, would it make it impossible to change the switches later on without desoldering?  I will Show a TIP for LED Soldering
* Also the aluminum case will be available after this group-by and ship separately?   Alu Case will come soon  in this GB, or ship Separately for it's Heavy.
Why Metal?  to Get Physical?
Thanks.
Thank You !!     :thumb:    This is  Just My Very Personal Opinion,  very clumsy.
« Last Edit: Wed, 20 November 2013, 02:09:26 by sprit »
Offline Biased opinion
filled in the form and for a 60% with blue, hopefully the shipping to Aus does not kill me :eek:
Offline sprit
filled in the form and for a 60% with blue, hopefully the shipping to Aus does not kill me :o
Hi Mate?   Wher' About Aus?   ;)
« Last Edit: Wed, 20 November 2013, 04:19:34 by sprit »
Offline rDuck
How does one change ones order form?, wanted to review what i actually ordered, but couldent figure it out >.>
Offline sprit
Allo!  rDuck !
You can write the Order Again!  No Problem!  Sir !
« Last Edit: Wed, 20 November 2013, 04:56:13 by sprit »
Offline fatchoi
Allo!  rDuck !
Appreciate your efforts in replying our questions quickly. ;D
I will write a final order later on, when there are stabilizers for sale too.
Can't wait building a keyboard for myself. It's gonna be my first DIY board.
Offline cruk
  • :> keys
This is so confusing, there are too many choices, put indecisive people like me in a difficult position.
If im ordering 1x60, 1x75, i believe i need to specify which plates for which?
Offline sprit
If SW Spring is Under 65g,  I Recommend Acryl 5mm Plate,
If You enjoy the Power-Typing,  I 'd Recommend  Dura-Alu 4mm Plate !!
