Author Topic: PBT 104/105 set ROUND 3 (COMPLETED)  (Read 710640 times)
Offline 1pq
  • Hipster Doofus
Re: PBT 104/105 set ROUND 3 [The Pitch BLACK edition] NEW choices
« Reply #600 on: Wed, 29 January 2014, 11:33:33 »
No the GMK adapter kits will be separate items and additional cost. I haven't added them to the form yet because I still don't have pricing. I guess they are having a tough time trying to locate the vertical 1.5 keys for the EDOX pack.
Can I place my order now (to reserve a set or two) and then add the add-on pack when it becomes available?
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #601 on: Wed, 29 January 2014, 11:37:27 »
Yes, feel free to place the full set order. Save the form link for your order at the end, you can go back and add adapter packs when they are available.
Offline taylordcraig
« Reply #602 on: Wed, 29 January 2014, 16:55:38 »
I filled a form forever ago, just making sure there isn't a new one. How can I check my order? Thanks.
« Reply #603 on: Wed, 29 January 2014, 17:04:11 »
2 blank, 1 US
Offline Nubbles
« Reply #604 on: Thu, 30 January 2014, 16:55:32 »
Unfortunately I'm going to withdraw my order.
Apologies, but hopefully just one set shouldn't hurt too much trying to reach MOQ.
Offline KaLam1ty
« Reply #605 on: Thu, 30 January 2014, 17:25:54 »
Sorry in advanced, as I'm sure this question has been asked before, but is there going to be any modifier packs
to go along with this? (i.e.  Capslock <-> Ctrl/Backspace, etc.)?
Offline Al3xG
« Reply #606 on: Fri, 31 January 2014, 08:52:01 »
Hi IvanIvanovich, I placed an order for one blank set some days ago... Do you have received it?
Thanks  ;)
Offline AndrePews
« Reply #607 on: Fri, 31 January 2014, 09:08:12 »
Thanks for the GB Ivan!  :D
Just to make sure did you get my order? :)
Offline 1pq
  • Hipster Doofus
« Reply #608 on: Fri, 31 January 2014, 09:42:54 »
You guys know you can PM him, right?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #609 on: Fri, 31 January 2014, 09:44:02 »
Why are people always so concerned that the organizer got their orders? Did the form go through? Were there no errors? If yes to both, they got your order!
Re: PBT 104/105 set ROUND 3 + GMK ABS add ons
« Reply #610 on: Fri, 31 January 2014, 11:40:35 »
GMK standard and EDOX add on packs are live. Please refer to the OP for contents, I will get a visual representation of it up at a later time.
  • Cherry Peasant
  • keycult.com
« Reply #611 on: Fri, 31 January 2014, 12:21:45 »
Resubmitted my order (lost the original link) to include a GMK pack  :thumb:
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #612 on: Fri, 31 January 2014, 14:54:36 »
I forgot if I ordered a blank or black on black set.. Could you please check for me?
« Reply #613 on: Fri, 31 January 2014, 16:23:53 »
I have too many request for check/order change. Please resubmit form. THANKS!
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #614 on: Fri, 31 January 2014, 16:25:50 »
We are *never* making 400 orders on the edox pack :(
Offline CK Briefs
  • formerly calvins1
« Reply #615 on: Fri, 31 January 2014, 16:27:34 »
Just when I thought we almost had reached MOQ :(
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
« Reply #616 on: Fri, 31 January 2014, 16:34:04 »
The GMK bits are separate, and they have their own MOQ. Once the PBT makes MOQ it will be made regardless if the add ons have or not. I actually need to receive the PBT first anyway so we can get it color matched as best as possible with GMK keys.
Offline Rayne
  • For Science!
« Reply #617 on: Fri, 31 January 2014, 18:23:48 »
so glad there there is extra pack for winkless! you are soooo awesome for doing this!!!!!!
order placed, 1 blank set and standard pack :)
Offline epzy
  • HHKB Fiend
  • ded
« Reply #618 on: Fri, 31 January 2014, 18:42:50 »
ORDER THE GMK PACKS BOYS AND GIRLS!
Offline avtar
« Reply #619 on: Fri, 31 January 2014, 19:31:41 »
I will know for sure sometime after the Lunar New Year holiday period about the sideprint.
I'll sign up for this if side print becomes an option.
Offline cgbuen
    • cgbuen.io
« Reply #620 on: Fri, 31 January 2014, 22:57:54 »
You mentioned that the imsto sets are supposed to be matched with the RF black, but I'm curious about the GMK matching - is it going to be like the normal black from white-on-black keys on G80s/G81s, or again close to RF black?
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #621 on: Sat, 01 February 2014, 10:48:15 »
Order placed, including one of the GMK packs, windowed keys are awesome.
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #622 on: Sat, 01 February 2014, 10:55:15 »
I think a mockup pic of the adapter kit might help moq. It's not easy finding black windowed stepped cherry caps lock!
« Reply #623 on: Sat, 01 February 2014, 11:18:29 »
The idea is for the GMK add on to match as closely as possible the PBT set for a uniform look.
Offline tbc
« Reply #624 on: Sat, 01 February 2014, 14:07:29 »
what was the situation on windowed caps? specifically capslock.
i'm a fan of no windows.
« Reply #625 on: Sat, 01 February 2014, 14:32:35 »
The full PBT set will not have windowed key. Windowed key only in the GMK add on.
While PLUM do have windowed key, it's the tiny dot kind of window like this
and I don't really care for it. Also it's likely to be on the wrong side for most keyboard in switch lock lights as well anyway.
« Last Edit: Sat, 01 February 2014, 14:38:12 by IvanIvanovich »
Offline 1pq
  • Hipster Doofus
« Reply #626 on: Sat, 01 February 2014, 15:44:26 »
Yeah those "dot" windows look awful
Offline 1pq
  • Hipster Doofus
« Reply #627 on: Mon, 03 February 2014, 21:09:19 »
Come on guys...we're so close!
Offline PolaBurrr
« Reply #628 on: Mon, 03 February 2014, 23:05:25 »
I believe this has been asked already, but I cannot find it anymore. Is the color realforce black or ducky pbt black?
Offline tbc
« Reply #629 on: Tue, 04 February 2014, 00:15:59 »
realforce
Offline mattics
« Reply #630 on: Tue, 04 February 2014, 03:15:15 »
Sorry if that has already been asked - I did flick through about half the pages to look...
What is a rough estimate for tracked shipping to the UK for 1 (or possbily 2) sets?
And PayPal fees are 3.4% right?
« Reply #631 on: Tue, 04 February 2014, 18:20:16 »
USPS rates have gone up recently... so a set would now cost approx $14 international shipping. 2 sets should be fairly close or the same cost. Paypal fee is 4%.
We are getting close... only ~40 PBT sets away from MOQ.
« Last Edit: Tue, 04 February 2014, 18:22:17 by IvanIvanovich »
Offline LechnerDE
« Reply #632 on: Wed, 05 February 2014, 01:17:36 »
I guess if you announce a sideprinted option we will get these 40 orders the same day ;)
I know I would add one to my existing order  :thumb:
Offline tbc
« Reply #633 on: Wed, 05 February 2014, 01:42:25 »
^this
« Reply #634 on: Wed, 05 February 2014, 09:25:03 »
Still waiting to hear on confirmation for that option. I guess they wanted to do some more test run to make sure the process is up to good QC standard.
Offline 1pq
  • Hipster Doofus
« Reply #635 on: Wed, 05 February 2014, 10:07:12 »
That MOQ on the GMK add on sets though...:(
« Reply #636 on: Wed, 05 February 2014, 10:27:23 »
Yeah it's too bad they are sticking to the higher MOQ on blank and windowed keys. But they are not too expensive so hopefully we can do it.
Offline fuus
  • All Year Christmas!
« Reply #637 on: Fri, 07 February 2014, 03:26:59 »
How're the MOQs looking Ivan? :)
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline LechnerDE
« Reply #638 on: Fri, 07 February 2014, 03:46:37 »
From the OP (numbers are 5 days old)
Order count (2.2.14):
PBT full sets: 258/300
GMK standard: 9/400
GMK EDOX: 2/400
« Reply #639 on: Fri, 07 February 2014, 08:01:04 »
Updated order count. We are getting pretty close on the full sets. I think we should meet goal by end of month.
Kind of surprised there is not more going on the GMK add ons... it is things many asked for.
Offline sean4star
« Reply #640 on: Fri, 07 February 2014, 14:52:26 »
I want to modify my order.  I just need to resubmit the order form, right?
One problem...I can't remember if I used my geekhack or my deskthority account.  I would hate to order twice!  Can you let me know?
Offline jonathanyu
« Reply #641 on: Fri, 07 February 2014, 17:01:13 »
The gmk addon will also be black?
  • Cherry Peasant
  • keycult.com
« Reply #642 on: Fri, 07 February 2014, 17:02:45 »
Yes, it will be color matched.
Offline jonathanyu
« Reply #643 on: Fri, 07 February 2014, 17:06:57 »
Great, will order at least three just for the windowed caps
Offline epzy
  • HHKB Fiend
  • ded
« Reply #644 on: Fri, 07 February 2014, 17:08:43 »
Only 14 GMK sets ordered so far? Gosh... C'mon people!
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #645 on: Fri, 07 February 2014, 17:11:26 »
Please forgive my complete ignorance here but what do these GMK addon packs consist of?  Would like to see what they look like because I can then decide on which keyboards to possibly install them on.
Sorry but I'm just a simple goon that needs pictures in explaining anything.  I still like reading Dr. Seuss  :p .
Offline n7
« Reply #646 on: Fri, 07 February 2014, 18:37:19 »
added the standard addon pack to my order
« Reply #647 on: Sat, 08 February 2014, 08:16:17 »
Add on standard offers you:
Windowed caps/num/scroll lock keys
ISO
Cherry deepdish home keys
1.5 mods and 7x spacebar for vintage/customs
1.75 shift for 75%/Pure/1800
extra 2.25 shift for FC660M
Offline fuus
« Reply #648 on: Sat, 08 February 2014, 17:03:56 »
Thanks for the update Ivan :)
Filco - Browns
Offline Elrick
  • Hype Master
« Reply #649 on: Sat, 08 February 2014, 18:42:34 »
ISO
Just added these to my original order, please let me know if you can add these latest ones to the others already picked.  Thanks Ivan  ;D .
If there are problems I can re-order everything again but you'll need to scrap the OLD orders first.
