Author Topic: PBT 104/105 set ROUND 3 (COMPLETED)  (Read 710723 times)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: PBT 104/105 set ROUND 3 [The Pitch BLACK edition] NEW choices
« Reply #400 on: Mon, 06 January 2014, 11:33:56 »
so just to confirm this is imsto dyesub Thick PBT dyesub right?
Yes. Ivan is also working on an extension kit that will be GMK ABS.
Offline wilflare
« Reply #401 on: Mon, 06 January 2014, 11:38:10 »
if only there's a Thick PBT Doubleshot Black on Black!
ORDERED :D can't wait for these to come!
Offline j0hnny
« Reply #402 on: Mon, 06 January 2014, 16:08:11 »
SIGN UP PEOPLE! PLZZZ this needs to happen!
Offline n7
« Reply #403 on: Mon, 06 January 2014, 18:40:26 »
Signed up for a blank set. I am debating getting the black on black too, but I only have one TKL MX keyboard and getting two 104 sets would give me a lot of leftovers.
Offline CK Briefs
  • formerly calvins1
« Reply #404 on: Mon, 06 January 2014, 19:15:47 »
I ordered one too, but I was contemplating getting a black of black subdyed one. I didn't because I know I prob won't use both; I'd rather have pbt caps in another colour to mix and match.
The sets are fairly cheap as it is, so extra caps don't matter; but rather whether or not you'll even use the caps if they're both extremely similar. I wouldn't, unless it was a backup or a gift for someone.
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #405 on: Mon, 06 January 2014, 19:20:13 »
We have reached the 50% mark to MOQ!
  • Cherry Peasant
  • keycult.com
« Reply #406 on: Mon, 06 January 2014, 19:23:59 »
Now we just need a couple ~$7000 investments from vendors. Step up to the plate!
Offline noons
« Reply #407 on: Mon, 06 January 2014, 20:04:18 »
Nevermind, answered my question via search :P
« Last Edit: Mon, 06 January 2014, 20:08:01 by noons »
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
Offline wilflare
« Reply #408 on: Mon, 06 January 2014, 20:22:58 »
really hope this happens..
maybe i should order another blank to go along..
Offline Michael
  • Formerly Bro Caps
« Reply #409 on: Mon, 06 January 2014, 20:24:39 »
Have you hit up OTD/KBD/DT?
Offline noons
« Reply #410 on: Mon, 06 January 2014, 21:48:35 »
Actually I do have a question.. Seeing how the spacebar is not compatible with leopold, anyone have any idea how it would look with the oem spacebar? I have thin pbt key caps now that I like, but these thick cherry profiles do sound great. I  guess I am just concerned of the height that my spacebar would be vs these cherry height keys.
Offline Rhinofeed
  • Formerly nathaniel_h
    • Rhinofeed
« Reply #411 on: Mon, 06 January 2014, 21:57:14 »
So tempting. I'm very happy with my first set, but to have Black on Black Dyesubs... this is what I get for logging into Geekhack again.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #412 on: Tue, 07 January 2014, 17:01:01 »
I am using similar keys from GMK with the original spacebar from my FC660M. It matches up pretty well, maybe even too good. the space between the spacebar and the Alt is very narrow as the walls are pretty steep.
It might differ with yours though. And as for aesthetics, depends...
|||My other keyboards :
x
Offline acidtrip69
« Reply #413 on: Tue, 07 January 2014, 17:27:36 »
co can i still get in on a dark side order ? It looks so sweet. are they going to be thick ptb ?
  • Cherry Peasant
  • keycult.com
« Reply #414 on: Tue, 07 January 2014, 17:29:41 »
Yes, you can. And yes, they will be.
Offline bladegesnow
« Reply #415 on: Tue, 07 January 2014, 18:31:10 »
Just send a new form to replace the previous one. Order a black on black instead of blank!
Make this happen guys!
More and more and more...
Offline wilflare
« Reply #416 on: Tue, 07 January 2014, 21:01:13 »
really hoping this happens man!
gonna match this with the O-Ring mod on my Filco MJT1 Brown
Offline damorgue
    • Personal portfolio
« Reply #417 on: Wed, 08 January 2014, 00:32:44 »
So add on pack contents:
6x windowed top row key
windowed stepped and fulltouch caps lock
deepdish 'scoops' home keys
ISO enter
1.25 shift
1.75 shift
extra 2.25 shift for FC660M
4x 1.5 bottom row
2x extra bottom row 1x1
7x spacebar
Is this good? Or is there anything else that you all feel we need? Looking to finalize the add on pack contents so can get final price from GMK for this so can make it orderable.
Exactly... it's ANSI 104 PBT set and that is currently all that is available here.
There will be an optional add on for color matching BLANK ABS from GMK to make the ANSI 104 PBT set more adaptable for other keyboards. Most of the keys in the add on pack will be things that are simply not available from the PBT keycap factory. When the ABS add on becomes available I will of course try to make that as clear as possible.
So all the keys in the addon-pack will be in ABS? Do they have any colour/texture samples to compare the ABS and PBT?
Offline acidtrip69
« Reply #418 on: Wed, 08 January 2014, 01:41:11 »
i have a question who is making there keys ? also i think a black key set with silver dye subed lettering would look badass ^_^
Offline tbc
« Reply #419 on: Wed, 08 January 2014, 01:51:57 »
^you win CES2014
Offline asura
  • not a duck
« Reply #420 on: Wed, 08 January 2014, 04:58:16 »
The main set will be from a factory in China(?) via Imsto and the add-ons from GMK in Germany as the Chinese(?) manufacturer doesn't have the moulds for all the keys desired.
And... impossible - dye sublimation only works with a darker colour than the keycap material.  You could etch and in-fill, but "silver" plastics generally don't look like silver, just a sort of pale grey.  A "silver" cold enamel (that's an epoxy polymer based paint) would probably give you the best silver colour, they're usually chromium particles suspended in a pale grey.
« Last Edit: Wed, 08 January 2014, 05:01:23 by asura »
Offline acidtrip69
« Reply #421 on: Wed, 08 January 2014, 14:29:11 »
Thanks for the info. ^_^ but i do think that key set would look nice like that
« Reply #422 on: Wed, 08 January 2014, 15:04:11 »
Due to add on pack coming from different source, and made from different plastic than the full base set... I was planning on wait to receive the PBT, then match as best as possible that with GMK. It would make a small delay, but I think it would ensure the best result with the smallest possible color variance instead of going on color blindly.
So, now just waiting on quote for the ISO/1.5/etc add on pack... and EDox add on from GMK. I sent email for it again today so hopefully I will hear something back soon.
Offline noideawhatsgoing
« Reply #423 on: Wed, 08 January 2014, 23:25:35 »
That's awesome, thank you so much for all the work you are putting in.
Offline phoenixl1ght
« Reply #424 on: Thu, 09 January 2014, 00:33:48 »
Are they all cherry profile? I wanted OEM profile for the black blanks. I like the height :)
Offline yakitysax
« Reply #425 on: Thu, 09 January 2014, 03:08:37 »
I can't wait, thanks for putting together the group buy.
Offline geogga
  • gosh dang GH and their GBs
« Reply #426 on: Thu, 09 January 2014, 10:54:05 »
We hit 200!!!
Now we gotta try to get 300...if so may then will the factory choose to make the caps if deemed worthy
  • Cherry Peasant
  • keycult.com
« Reply #427 on: Thu, 09 January 2014, 11:04:12 »
Yes, all of the keys from this group buy will be Cherry profile.
Offline ynrozturk
« Reply #428 on: Thu, 09 January 2014, 11:09:01 »
I really hope this works out. I don't want those keys, I need those keys.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline strict
  • TKL Zealot
« Reply #429 on: Thu, 09 January 2014, 11:42:37 »
I want to echo everyones else statement and just say that you are a hero for organizing this. Im sure it is nothing if not tedious and frustrating most of the time.
Regarding the delay you mentioned, Would this delay be for all participants of the group buy or only the people who purchase the add-on pack?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #430 on: Thu, 09 January 2014, 12:08:14 »
I would buy two sets, but i'm scared I wont like Cherry profile... Not sure how big of a difference it truly makes. :/
« Reply #431 on: Thu, 09 January 2014, 12:44:03 »
All my groupbuy is Cherry profile, the only profile that matters!
Those that order only PBT 104 set would not be affected by GMK add on delay.
Today I also find out, there is chance we can make this with Plum factory instead. Plum factory also have 1.5, 1.75 sizes and windowed keycap in PBT. Just waiting to find out how their pricing and MOQ is like versus current.
Offline LechnerDE
« Reply #432 on: Thu, 09 January 2014, 14:46:12 »
Interesting!
Do we know anything about the quality of their keycaps (texture, thickness, etc.)?
Offline phillyd
« Reply #433 on: Thu, 09 January 2014, 15:06:51 »
Is this GB still open for orders?
« Reply #434 on: Thu, 09 January 2014, 15:26:33 »
Orders close 1/15, so yes.
« Reply #435 on: Thu, 09 January 2014, 15:26:46 »
Yes groupbuy is open for order, please use form link in the first post.
Plum factory make Cherry profile keys that is on Plum 96, Neo Zelia, Choc mini... I haven't had any of those, but from what I have seen they appear to be quite similar.
« Reply #436 on: Thu, 09 January 2014, 15:27:30 »
Yo Ivan, nice 7k posts
Offline LechnerDE
« Reply #437 on: Thu, 09 January 2014, 15:34:47 »
The PBT Caps on my Noppoo Choc Mini 2013 are actually pretty nice and thick. I'd be very happy with these in black :)
Offline phillyd
« Reply #438 on: Thu, 09 January 2014, 16:43:24 »
EDIT: I'm an idiot.
« Last Edit: Thu, 09 January 2014, 17:54:57 by phillyd »
Offline Jocelyn
  • 조셀린
« Reply #439 on: Thu, 09 January 2014, 16:57:09 »
Hey Ivan, I redid my order by going to the original editable page and resubmistted it. Are my two sets showing up? I wanted to make sure I did it right and thank in advance :)
« Reply #440 on: Thu, 09 January 2014, 19:34:45 »
Jocelyn, I show blank and US set for your order so I guess it's all good.  :thumb:
Offline Sai
« Reply #441 on: Thu, 09 January 2014, 19:38:29 »
Ivan, will the legends be as dark as the realforce/hhkb black set ?
« Reply #442 on: Thu, 09 January 2014, 19:49:21 »
Yes, the idea is for these set to be basically a near replica of black/black Topre sets but for Cherry.
Offline Sai
« Reply #443 on: Thu, 09 January 2014, 20:08:05 »
hmm. then please help me change my order to blank. i cant really see the legends on my hhkb set. >.>
« Reply #444 on: Thu, 09 January 2014, 20:34:53 »
OK, you're all set it's blank now.
« Reply #445 on: Thu, 09 January 2014, 23:19:48 »
I ordered a blank set, so I now have two different orders.  If you could add those two together so I don't have to pay shipping 2x that'd be awesome.  Thanks again for all the work you are putting in.
Offline tbc
« Reply #446 on: Fri, 10 January 2014, 02:18:16 »
you only have one active order.  your second order overwrote the first one unless you used different email etc.
you would want to make a completely new order ordering 2 sets
« Reply #447 on: Fri, 10 January 2014, 09:33:12 »
Do you have access to the spreadsheet or is this just an educated guess given past knowledge?
Offline strict
  • TKL Zealot
« Reply #448 on: Fri, 10 January 2014, 09:50:11 »
Ivan explained earlier in the thread that new orders overwrite old orders. If you placed Order A for one blank set and then later placed Order B for a printed set, the only active order for your name is Order B for the printed set.
Offline Jocelyn
  • 조셀린
« Reply #449 on: Fri, 10 January 2014, 09:51:46 »
It's more of a common knowledge thing about how it's worked in the past. Not an educated guess :)
