Author Topic: Help with my Korean Board  (Read 2390 times)
Offline terran5992
  • One With The Cup Rubber
« on: Fri, 15 November 2013, 02:54:13 »
I have just bought a custom made korean board .  It uses a ps2avr PCB. When i plug it in, the led will flash for a split second then it would turn off. And sometimes when you press a key, it would light up the whole board. And pressing on the keys dosent register.
Anyone know what is going on?
« Last Edit: Fri, 15 November 2013, 04:15:43 by terran5992 »
Offline WhiteFireDragon
    • youtube
Re: Help with my Korean Board
« Reply #1 on: Fri, 15 November 2013, 05:09:39 »
It's a PS2 board, meaning not native plug-n-play USB. You need to have the cable already plugged in, then turn the computer on.
Offline Tony
« Reply #2 on: Fri, 15 November 2013, 05:16:43 »
Please restart the computer each time, no alternatives.
« Reply #3 on: Fri, 15 November 2013, 06:36:11 »
If that's an A87 PS2AVR, you can try holding down "U" as you plug it in for default USB mode.
Offline terran5992
« Reply #4 on: Fri, 15 November 2013, 07:05:55 »
Restarted with the keyboard plugged in.
Works like a charm now
Offline berserkfan
« Reply #5 on: Fri, 15 November 2013, 07:20:32 »
DUH, you don't know that ps2 devices need the computer to be restarted?
No offence, but are you under 12? Only people born in the 21st century will be so unfamiliar with ps2 devices!
« Reply #6 on: Fri, 15 November 2013, 07:24:58 »
You should go easy on him. I had the same 'issue' when I first joined GH, but with an Access-IS keyboard. We all have a lot to learn.
Offline terran5992
« Reply #7 on: Fri, 15 November 2013, 07:28:28 »
I had no idea that that need to be done, the first keyboard i ever used was USB . Forgive me as i have sinned.
Offline Danule
« Reply #8 on: Fri, 15 November 2013, 08:38:48 »
REPENT, you have shamed the keyboard GODS!!!!
45g Brown Brown Blue
« Reply #9 on: Fri, 15 November 2013, 08:58:39 »
Any time someone says "no offense, but" you can bet they intend offend.  The spelling correction is free, jerkwad.
« Reply #10 on: Fri, 15 November 2013, 09:04:30 »
No offence, but there's nothing wrong with using the British spelling of words.
Let's keep this on topic please. If you have a bone to pick with another user, please PM them about it.
Offline spiceBar
    • ChessTiger.com
« Reply #11 on: Fri, 15 November 2013, 10:59:09 »
Rude and undeserved. Either you are under 12 yourself and/or you are just a jerk.
And for your information, with some computers/keyboards, you can hotplug a PS/2 keyboard and there is no problem at all.
Offline meiosis
  • Time
« Reply #12 on: Fri, 15 November 2013, 11:04:00 »
What's wrong with being 12?
Keyboards:
Aripeko TKL
Offline zenuty
« Reply #13 on: Fri, 15 November 2013, 11:04:48 »
Please use to ps2 conect.
It seems to be need a ps2 to usb converter or ps2aver usb extender.
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline spiceBar
    • ChessTiger.com
« Reply #14 on: Fri, 15 November 2013, 11:23:30 »
Nothing wrong. That would have been his only excuse for his rude post.
« Reply #15 on: Fri, 15 November 2013, 17:22:43 »
Yup.  Some people haven't used PS/2 anything in a while either.  I haven't actively used PS/2 is something like 10 or 15 years, so it's not something I'd hold onto memory wise either.
