Author Topic: GOLD FILCO MAJESTOUCH 2 Tactile (Cherry MX Blues)  (Read 4656 times)
Offline SonicRevolution
  • * Commercial Vendor
    • Qwerkywriter
« on: Fri, 15 November 2013, 12:26:26 »
Recently saw a FILCO "gold" edition but couldn't find one so I just painted my own.  FILCO's are pretty well made!
SonicRevolution
www.qwerkywriter.com
@qwerkywriter on Twitter
Offline jinxedx84
Re: GOLD FILCO MAJESTOUCH 2 Tactile (Cherry MX Blues)
« Reply #1 on: Fri, 15 November 2013, 12:47:55 »
good job
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline osi
« Reply #2 on: Fri, 15 November 2013, 13:05:22 »
Nice work
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #3 on: Fri, 15 November 2013, 13:06:38 »
Stay classy
« Reply #4 on: Fri, 15 November 2013, 16:27:09 »
Looks very nice. Was that blemish by the numberpad enter from painting or before? Also, I notice the media keys, was this a camo filco pre painting?
    • Qwerkywriter
« Reply #5 on: Fri, 15 November 2013, 20:19:44 »
Damn! GeekHack folks have eagle eyes!  Yeah it was a camo.  When I got it, Camo just didn't look cool as I thought it did.  So refinished it.
SonicRevolution
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #6 on: Fri, 15 November 2013, 21:02:43 »
Any issues with it rubbing off on your wrists? I've heard the metallic stuff is prone to it..
    • Qwerkywriter
« Reply #7 on: Fri, 15 November 2013, 21:27:59 »
It's got 2 coats of clear matt finish protective coat on it.  Yeah without it, it would rub off!  Also, that small chip, it's not there.  Not sure why there is a spec there.
Here's what I did and I am in no way a pro painting person.
1. sand it (i don't even know what grade - some random rough sand paper)
2. 2 coats of 2x primer
3. 3 coats of metallic paint (or like 2.5)
4. 2 coats of clear protective matt finish
One thing of note.  I do this outside quickly then bring it inside (the garage) to "dry"  It's getting cold where I live and too cold, hot or humid can do really bad things.  Also, if you leave it outside, bird poop and other crap gets on it.  I don't have a "clean" paint room so yeah.. :D  this is all from experience.
One time I was trying a keyboard and the sprinkler went off.  yes... I was... un .. happy... :D
SonicRevolution
Offline pieman
« Reply #8 on: Sat, 16 November 2013, 18:42:16 »
Very nice work.  I'm curious however, how did you manage to mask the filco sign on the top right so well?  It's not exactly a regular block shape.
Offline ComradeSniper
  • HHKB Pro
« Reply #9 on: Sat, 16 November 2013, 19:14:50 »
IIRC it can be removed.
    • Qwerkywriter
« Reply #10 on: Sun, 17 November 2013, 02:58:42 »
Yep!  The filco ID can be removed!
SonicRevolution
Offline terran5992
  • One With The Cup Rubber
« Reply #11 on: Sun, 17 November 2013, 03:03:28 »
~Sweeeeeet~
