Author Topic: Metal case for ducky?  (Read 10125 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Fri, 15 November 2013, 16:12:22 »
As the title states I am looking for a metal case for my shine 3. Where can I buy one for around $60? I have been looking for a few days now and I can't find anything.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Metal case for ducky?
« Reply #1 on: Fri, 15 November 2013, 16:16:32 »
The land of make believe.
Offline longweight
  • philanthropist
« Reply #2 on: Fri, 15 November 2013, 16:17:17 »
$60?! You will need to triple that budget!
Offline C5Allroad
« Reply #3 on: Fri, 15 November 2013, 16:17:32 »
Sniff Sniff :(
[Edit] I don't want  to create a new thread for this. But my backspace is squeaky....
I think it's the orings under it.
« Last Edit: Fri, 15 November 2013, 16:23:30 by HUNTERANGEL121 »
Offline Linkbane
« Reply #4 on: Fri, 15 November 2013, 16:19:37 »
You can get a TKL case for $156 from mechanicalkeyboards, and a 60% for slightly over $100. If you want a full-size, probably about $200.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #5 on: Fri, 15 November 2013, 16:22:43 »
doesn't work with duckies though.
Offline Linkbane
« Reply #6 on: Fri, 15 November 2013, 16:23:33 »
Extra keys on the ducky?
Offline C5Allroad
« Reply #7 on: Fri, 15 November 2013, 16:24:28 »
What about the upper case only? Where would I find one like the yots version?( If that exists)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #8 on: Fri, 15 November 2013, 16:41:04 »
Year of the Snake is as close as your are going to get, as of yet... :'( ...and, it only features an Aluminum top with plastic bottom. For me, close enough; but, for all you modders out there, a small consolation, I know... :-[
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #9 on: Fri, 15 November 2013, 16:50:24 »
No, the plate wouldn't work with the vortex case. It requires a curved plate like a filco..
Offline C5Allroad
« Reply #10 on: Fri, 15 November 2013, 17:03:11 »
I guess we will have to wait for the shine 4 YOTH edition lol.
Offline Leslieann
« Reply #11 on: Fri, 15 November 2013, 19:27:38 »
Actually, it MAY be possible to put a Ducky TKL into a Vortex Filco case but you have to jump through a few hoops first.
You need to measure the PCB length and width, we can check it against a Filco. It needs to be the same or smaller, also nothing near the front edge can hang below the pcb or it will ground out against the case. More than one person has had stuck keys because of how tight the space is there. I cover mine with foam and electrical tape as a precaution (and sound dampening).
Obviously you need the Vortex case and you need to get a Universal plate from a group buy. To install this, you will need to de-solder every switch. Not a fun job, but there are people who can do it for you for a price if you can't.
You will then need to adapt the Universal plate to the Vortex case. You can try to fabricate something, or have me print you a set of the ones I use. Having made several sets, while they aren't that complex, I can tell you that wedging a long strip of wood in there isn't going to work.
Lastly, you may need to move some LED's and mess with the cord a bit to get it to sit inside the case.
Can it work... very likely.
Keep in mind, an aluminum case, may not be all you think it is.
They are heavy and if dropped from a short distance (especially corner first) can damage or even break your desk (mine is glass!). A Vortex equipped Filco can weigh nearly 5 pounds. It's heavy enough, that if it falls on your foot, it could break your toe. Something to consider if you move it around a lot.
Then there is static electricity, I grounded mine after I watched a spark jump nearly 5 inches from my hand to the keyboard and illuminate the LED's. No damage, but it was a surprise. Later after some work I forgot to reconnect it and again watched a 3inch spark do it again. Electronics that have a metal case, are supposed to have a grounded case, for safety, these do not. If you live in a lightening or static prone area, you might want to consider grounding it. I connected mine to the USB ground.
On the plus side, my keyboard never slides around my desk, it stays where I put it (my custom feet help). Honestly, other than that, a little noise dampening and the looks, there isn't much difference. After I got my aluminum case, I actually began appreciating plastic ones a lot more. My little Vortex Race is nice because it's so lightweight, it can be tossed onto a shelf, into a bag, etc.  and not fear it breaking or damaging anything it lands on. Unlike my Filco, which could be used as a deadly weapon.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline tbc
« Reply #12 on: Sat, 16 November 2013, 00:19:14 »
how much work is required to ground something?
« Reply #13 on: Sat, 16 November 2013, 00:24:51 »
Am I the only one who sees this as an awesome feature?
Offline stancato9
« Reply #14 on: Sat, 16 November 2013, 00:31:24 »
Nope, you aren't alone on that one.
Poker 2 - MX Red
« Reply #15 on: Sat, 16 November 2013, 00:38:39 »
Actually it'd be an awesome gag....here use my keyboard.... zap.... sucker!
« Reply #16 on: Sat, 16 November 2013, 01:45:54 »
Actually kinda reminds me of this.
Offline mapple
« Reply #17 on: Mon, 18 November 2013, 03:18:16 »
did you found something? I would like to have one for shine 3 tkl....... maybe someone knows someone who can produce them some group buy?:)
In God We Trust
« Reply #18 on: Mon, 18 November 2013, 03:25:46 »
Actually I'm in two minds about metal cases.
I have two (three, actually, but that's another story) Apple Aluminium keyboards, and one of them used to zap me every time my hand went near it.
The other one - nothing.
Unless the first one had a short inside it or something.
