NEW USERS, READ THIS!
0 Members and 15 Guests are viewing this topic.
This might be off-topic, but these keycaps seem rather tight for the Clear keys on my ErgoDox. I've already ripped out a couple of stems from while trying to pull off the keycap. Luckily, I was able to keep track of the spring, and re-assemble the key.Any recommendations on oil/grease/compound that I should apply (after carefully pulling off all the keycaps again)?
that happens a lot with clears as they have an extra little bump, i find sorta wiggling the cap as im removing it helps
Alright Penumbra scoops groupbuy, lets start one up. Otherwise I'll have this long enough to mail it to someone else.
Quote from: BunnyLake on Tue, 08 July 2014, 11:56:26that happens a lot with clears as they have an extra little bump, i find sorta wiggling the cap as im removing it helps Yeah, that's pretty much what I've been doing after the first couple that I ripped out. If that's all that's needed, I'll just continue with the wiggling.Thanks.
to be fairi was unaware of this, the set was meant to come with scoops, all the mockups that were sent indicated scoops in the same way we always would, and in the same way it was indicated for the numpadso no idea how one could happen and not the otherill try find out what the deal is
Quote from: BunnyLake on Tue, 08 July 2014, 10:30:43to be fairi was unaware of this, the set was meant to come with scoops, all the mockups that were sent indicated scoops in the same way we always would, and in the same way it was indicated for the numpadso no idea how one could happen and not the otherill try find out what the deal isHopefully it was an oversight on SP's part and they'll remedy the situation. However, I have no issues doing a separate GB for them if necessary. It would appear that others are of the same opinion.
I ordered a custom cable -- any ETA on when those will ship?
I'm still looking forward to receiving mine. Bunny any ETA on the shipment to Asia Pacific?
scoops are comingobviously they will take some time and i dont wanna hold the sets up, so we will work out a way to distribute them when they arrivebutscoops are coming
I couldn't help it (jump to 1:02)
yeah i didn't receive my cable either, so i guess raccoon has a backlog, you can send the scoops together with the cables (my guess is i am not the only one)
It's a good width! If it's half-width it's too narrow, and full-width is too wide.
Anyone in Aus get theirs? Not sure if I'm the unluckiest person ever or if Aus Post is just really slow at the moment but I have 3 packages MIA at the moment
Quote from: bueller on Thu, 10 July 2014, 05:02:28Anyone in Aus get theirs? Not sure if I'm the unluckiest person ever or if Aus Post is just really slow at the moment but I have 3 packages MIA at the moment aus orders are going out form the US, they only really started going out properly a week ago, ill follow up with raccoon on your order but id assume its fine sir
Quote from: BunnyLake on Thu, 10 July 2014, 05:06:00Quote from: bueller on Thu, 10 July 2014, 05:02:28Anyone in Aus get theirs? Not sure if I'm the unluckiest person ever or if Aus Post is just really slow at the moment but I have 3 packages MIA at the moment aus orders are going out form the US, they only really started going out properly a week ago, ill follow up with raccoon on your order but id assume its fine sirAll good man, so long as it's not disappeared I'm cool. Just a little worried stuff is going missing cos the other two are like a month delayed
Quote from: BunnyLake on Wed, 09 July 2014, 16:08:13scoops are comingobviously they will take some time and i dont wanna hold the sets up, so we will work out a way to distribute them when they arrivebutscoops are comingWow. Bunny. You are amazing. Let us give you something for the shipping.
Quote from: nomaded on Wed, 09 July 2014, 19:13:34Wow. Bunny. You are amazing. Let us give you something for the shipping.This. If you can't put the scoops in with another order to save shipping please let us cover it so you don't put out more on your end. Great news btw, thank you for all the updates!
Quote from: MythicalWagyu on Thu, 10 July 2014, 09:54:28Wow. Bunny. You are amazing. Let us give you something for the shipping.This. If you can't put the scoops in with another order to save shipping please let us cover it so you don't put out more on your end. Great news btw, thank you for all the updates!
Here's Penumbra on my Leopold FC660M. I had to modify the spacebar to fit the leopold stabilizer positions and the right shift is obviously from the numpad keycaps (and has a slight gap around it, though not the deal breaker visually that I feared it would be).
Quote from: fog on Sun, 15 June 2014, 22:59:38Here's Penumbra on my Leopold FC660M. I had to modify the spacebar to fit the leopold stabilizer positions and the right shift is obviously from the numpad keycaps (and has a slight gap around it, though not the deal breaker visually that I feared it would be).Do you have any picture of the spacebar mod? I tried doing it once and I just ruined a spacebar.
Quote from: chipchop on Thu, 10 July 2014, 19:28:06Quote from: fog on Sun, 15 June 2014, 22:59:38Here's Penumbra on my Leopold FC660M. I had to modify the spacebar to fit the leopold stabilizer positions and the right shift is obviously from the numpad keycaps (and has a slight gap around it, though not the deal breaker visually that I feared it would be).Do you have any picture of the spacebar mod? I tried doing it once and I just ruined a spacebar.Yep. Here you go: Full AlbumShow Image Show Image Show ImageDremel, superglue and some sacrificial keycaps is all you need. Unless you are some sort of dremel wizard you'll destroy the two stems in the spacebar that overlap the location of the new keycaps, so the sacrificial keycaps will be used just for the stems. I know some people use white-tack or similar gummy/sticky material instead of modding the spacebar like this. YMMV.There is some crazing on the blue spacebar from, if i remember correctly, superglue accelerant (just don't use it or test in a small spot first). It's not visible from the top in this case, so it's a non issue.
Got mine in AUS! (shipped from bunny via Germany) )Show ImageShow ImageShow ImageSuch a great set, very glad I got in on the action :D
Got mine in AUS! (shipped from bunny via Germany) )Such a great set, very glad I got in on the action
I got mine today. OMG I have never laid eyes on a more beautiful set of keycaps. These things are gorgeous. I have been so excited for these for months and they are every bit as good as I was hoping. Super happy right now. (Attachment Link)
Quote from: bueller on Thu, 10 July 2014, 05:02:28Anyone in Aus get theirs? Not sure if I'm the unluckiest person ever or if Aus Post is just really slow at the moment but I have 3 packages MIA at the moment Don't worry if BunnyLake is involved you will get your key-sets no matter what else happens in this world .I've got heaps more still not arrived but I'm not worried because I know they're still in transit making their way to my place here in Convict Town.
I got mine today. OMG I have never laid eyes on a more beautiful set of keycaps. These things are gorgeous. I have been so excited for these for months and they are every bit as good as I was hoping. Super happy right now.Still getting used to the profile. I am switching from IMSTO Cherry PBT, so I can't really think of a bigger transition than that. It will take a moment to get used to, but I will manage. I don't think it is possible to o-ring these caps (just looking at them anyway), so that is probably going to be the hardest thing for me to get used to.
elrick, i know for a fact yoru penumbra shipped, im pretty sure i sent you tracking but if i didnt get in touch and i will, ill check on yours bueller next time i speak with raccoon
Hey Bunny, I took over someone's order. Just hoping it didn't get lost in the shuffle, as I haven't heard anything yet.
Quote from: Crabby_b on Sat, 12 July 2014, 07:21:52Hey Bunny, I took over someone's order. Just hoping it didn't get lost in the shuffle, as I haven't heard anything yet.if you could send me the details of that, like order number or whos order etc ill look in to that for you
Quote from: BunnyLake on Sat, 12 July 2014, 12:04:43Quote from: Crabby_b on Sat, 12 July 2014, 07:21:52Hey Bunny, I took over someone's order. Just hoping it didn't get lost in the shuffle, as I haven't heard anything yet.if you could send me the details of that, like order number or whos order etc ill look in to that for youLooks like this person's order:http://geekhack.org/index.php?topic=51026.msg1328832#msg1328832
It's finally hereererereererereerererer~~~~~ and I LOVE IT!!! It looks, feels, and sounds so damn goooooooooooooood ~<3Today, it is raining cats and dogs outside with thunderstorms so my pictures are kind of dark. I'll definitely take some more photos when the sun is back up Show Image Show ImageShow Image Show ImageShow Image Show Image I have to say the wait was worth it! Only thing I'm kind of curious about now is standard SA profile. The alphabet letter rows feel slightly tall compared to the rows above and below it, and I feel like I probably would've preferred the lower and more dish shape of the standard SA profile, but this still feels absolutely amazing!Thank you everyone who worked on this. I love it, and I love you guys ~<3Show Image
great shots sir
