Author Topic: Backlit TKL with Costar Stabilizers?  (Read 3496 times)
Offline Keytrun
« on: Tue, 19 November 2013, 09:19:28 »
Does it exist outside of custom?
Re: Backlit TKL with Costar Stabilizers?
« Reply #1 on: Tue, 19 November 2013, 09:21:39 »
Most of the customs I've seen use Cherry stabilizers. Is there a reason you have to have Costar stabilizers?
« Reply #2 on: Tue, 19 November 2013, 09:22:59 »
you should post questions like this in Simple Questions, Simple Answers in the future..
and yes, the wasd code. there may be more too, i just can't think of any off the top of my head.
and cpt is right, i don't believe there is a single korean custom that supports costar stabilisers. they all use pcb mounted cherry stabilisers.
Offline Keytrun
« Reply #3 on: Tue, 19 November 2013, 09:30:33 »
I didn't even know that thread existed! I'll try that from now on.
I've never even used cherry stabilizers. Just from what I've read on this forum costar are much better, right?
« Reply #4 on: Tue, 19 November 2013, 09:36:42 »
It's all opinion really, I hate costar personally, mainly because of the inserts. The cherry stabilizers on my ducky feel great.
« Reply #5 on: Tue, 19 November 2013, 09:39:42 »
Not at all. I do personally prefer costar stabilisers to STOCK cherry stabilisers. However, a simple mod makes cherry stabilisers feel MUCH better. I think modded cherry stabilisers feel far nicer than costar.
See the mod here, you just need to clip off part of the stem of the stabiliser. : http://geekhack.org/index.php?topic=34759.0
Offline Keytrun
« Reply #6 on: Tue, 19 November 2013, 09:43:49 »
The WASD code looks pretty amazing. Can you tell me what the difference between the CODE and the standard WASD are besides the backlight? I'm always trying to figure out the differences between certain keyboards. Before buying my filco I actually really wanted the WASD barebones (since I was replacing keycaps anyway) but it, as well as the standard wasd TKL in blue / brown, were out of stock. The code is also out of stock for the next 4-6 months, according to the site. I actually didn't think I'd even be able to see a backlight behind my thick PBT caps, but it actually looks really nice on my blackwidow. The caps block out all light, but you can see a nice glimmer between them.
As far as stabilizers go, for whatever reason this forum has made me scared of the cherrys. Otherwise, I would have bought a ducky 3 TKL two weeks ago. I understand its a matter of preference for some people, but for whatever reason it seemed like the majority of prominent members (I could be wrong) preferred costar and praised Filco / Coolermaster because of it. I have a friend who has a ducky and I was planning on checking out his cherry stabilizers, but when I decided I wanted thick pbt caps I assumed backlighting would be irrelevant and I ordered the Filco.
« Reply #7 on: Tue, 19 November 2013, 09:46:45 »
Stock cherries feel kinda mushy. Costars feel more crisp. The mod I posted makes cherries feel crisp.
The differences between code and normal wasd as far as I can tell are:
-LEDs
-LED ready keycaps
-MX Clears
probably some other small differences too..
« Reply #8 on: Tue, 19 November 2013, 09:48:07 »
Pretty sure the shine 3's have clipped cherry stabilizers stock.
http://geekhack.org/index.php?topic=49717.msg1077797#msg1077797
« Last Edit: Tue, 19 November 2013, 09:50:00 by SpAmRaY »
Offline Keytrun
« Reply #9 on: Tue, 19 November 2013, 09:54:27 »
Yea the impression I get from reading even that mod forum is that costar are just "safer" and that the cherrys feel "mushy". I'm not sure what mushy means there, but I've seen it a lot. I also already had costar on my current board and when buying a new board I wanted to make sure I'd like it. Costar just seemed safe. I'll try my friend's ducky and see how it is.
Clipping those cherry stabilizers won't hurt the PCB? People question that in the thread linked.
« Reply #10 on: Tue, 19 November 2013, 09:55:32 »
No, it won't.
Offline Linkbane
« Reply #11 on: Tue, 19 November 2013, 11:23:17 »
Ducky Shine 3 and all the new Zeros all have their improved Cherry stabilizers, which according to review are just as crisp as Costar. They're not really any better, it's just preference. Also, Coolermaster doesn't use Costar stabilizers, despite having their boards built by them, they use Cherry.
The Cherry hate from a few concentrated people is honestly ridiculous.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #12 on: Tue, 19 November 2013, 11:26:16 »
my coolermaster XT has costar stabilizers???
Offline Linkbane
« Reply #13 on: Tue, 19 November 2013, 12:50:26 »
wat
My TK has Cherry stabilizers..
« Reply #14 on: Tue, 19 November 2013, 12:51:40 »
wat
Because it is backlit, it is one of the few coolermaster boards that does, if not the only one.
Offline Linkbane
« Reply #15 on: Tue, 19 November 2013, 13:12:24 »
I suppose the Trigger uses it also, as the only other?
Offline Keytrun
« Reply #16 on: Tue, 19 November 2013, 13:14:16 »
I wish I had known that about the shine 3 TKL. I may have bought that instead of the filco. I'm sure the filco will be great though.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #17 on: Tue, 19 November 2013, 20:32:22 »
I know that Maxkeyboard has costar stabs. On their nighthawks. :p
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #18 on: Wed, 20 November 2013, 10:15:30 »
Not all Cherry stabilizers suck (but some really do), as far as I know it seems Ducky does some really nice cherry stabs on the backlit keyboards such as Shine III.
Another keyboard that has Cherry stabs and those are actually VERY nice is the Tt eSports Meka G-Unit, though I wouldn't recommend that keyboard to anyone due to another reasons (internal build, awful keycaps, way too damn big).
Anyways, all backlit CM Storm keyboards use Cherry stabs and all non-backlit use Costar stabilizers. The CM Storm Trigger paticurarly uses some of the worst Cherry stabs I've ever seen and even Carter admits those stabs are bad.
« Last Edit: Wed, 20 November 2013, 10:17:41 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
