Author Topic: 80's? cherry keyboard  (Read 6434 times)
Offline gojira54
« on: Tue, 19 November 2013, 11:11:52 »
Another day another basement ;)
says G80 at the start of the label, can't make out the rest.
This one is staying where it is, very much still in use...
44905-0
44907-1
Re: 80's? cherry keyboard
« Reply #1 on: Tue, 19 November 2013, 11:20:13 »
What is it hooked up to?? It looks really interesting.
Offline BlueBär
« Reply #2 on: Tue, 19 November 2013, 11:21:08 »
Somebody on GH bought one of these a few months ago, I also once found one on ebay. Even though they're G80s, they don't use MX switches.
Offline gojira54
« Reply #3 on: Tue, 19 November 2013, 11:43:17 »
All I can say is that it's staying government property. Nothing that interesting though!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 19 November 2013, 13:09:14 »
G80-0662, use M8 low profile switch. G80 was pretty much used on all mechanical Cherry models until ML was introduced.
Offline Mikey Mo
« Reply #5 on: Tue, 19 November 2013, 14:00:22 »
l like this keycaps.....
Offline gojira54
« Reply #6 on: Tue, 19 November 2013, 15:04:46 »
Thanks for the info on this board, interesting read over at DT...
I didn't like the sphericals much but it looked right in that ancient environment!
Offline gojira54
« Reply #7 on: Wed, 15 January 2014, 15:38:51 »
These two got chucked out...
51058-0
« Reply #8 on: Wed, 15 January 2014, 15:44:47 »
Top looks like domes, bottom looks like blue ALPS
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #9 on: Wed, 15 January 2014, 19:42:43 »
Top appears to be Key Tronic foam and foil.
Bottom looks like the bastard child of Acer and SMK. Need biggar picture. Plus a picture of the rear label for OEM/model information.
Bore Awards
« Reply #10 on: Wed, 15 January 2014, 20:18:34 »
Bottom looks like Monterey Blues to me.  Mine had that weird light blue, semi-transparent look to them.
Offline gojira54
« Reply #11 on: Thu, 16 January 2014, 15:45:14 »
more iffy pics...
the compaq feels nasty, the viglen is nice and clicky. both have crusty DS caps
51217-051219-1
  • RIP
    • Boring twaddle
« Reply #12 on: Thu, 16 January 2014, 15:54:44 »
Interesting ... the bottom one is a Datacomp. I can't quite make out the model number though.
The switch is basically this: http://deskthority.net/wiki/SMK_Alps_mount — SMK Alps mount, AKA "Monterey".
However, the upper shell is clearly different. Subtle, but not the same shape as other Monterey switches, nor any other SMK second generation variant I'm familiar with. How odd. Oops, no, it's one of those mounting holes with an angled-down flap; the switch is the normal shape.
« Last Edit: Mon, 05 May 2014, 09:26:03 by Daniel Beardsmore »
Bore Awards
« Reply #13 on: Thu, 16 January 2014, 16:00:15 »
The bottom is definitely Monterey Blues.  They're nice unless the board is a POS like the Chicony you can find with them.
Offline gojira54
« Reply #14 on: Thu, 16 January 2014, 16:09:07 »
model # DFK2020SUKF104
The switches feel pretty good. It's got a 5 pin DIN plug, any idea if it's possible to get this working via USB adaptor?
It's not in bad nick, needs retrobriting tho ;)
I'm going to bin the compaq board unless anyone wants it or its caps, PM me if you want it
datacomp you were right, this one is datestamped 1993 and has DS caps tho
http://demo.kcom.tw/ShowProducts.asp?id=239
« Last Edit: Thu, 16 January 2014, 16:49:05 by gojira54 »
  • RIP
    • Boring twaddle
« Reply #15 on: Thu, 16 January 2014, 17:13:15 »
That website also notes,"Key switches: Datacomp mechanical Key-switch"
I'll drop them a line about that. Mechanical Keyboards gave me a tip-off about Datacomp's new Alps clone switches ages ago, but they've never appeared anywhere and Datacomp never responded to me when I enquired. That website has a different e-mail address; fingers crossed I'll get more sense out of them that way.
Looks like you have a keyboard to add to the wiki, plus it would be nice to also have some shots (various angles) of those unusual SMK switches for the wiki.
Bore Awards
  • RIP
    • Boring twaddle
« Reply #16 on: Thu, 16 January 2014, 17:14:05 »
So long as it's an AT keyboard, yes, you need a passive AT to PS/2 adaptor, then a PS/2 to USB converter.
Bore Awards
Offline gojira54
« Reply #17 on: Fri, 17 January 2014, 11:26:21 »
cool cheers for the info :)
compaq keyboard is going in the bin!
Offline berserkfan
« Reply #18 on: Fri, 17 January 2014, 12:48:24 »
HA! From your response and your lack of photos of the computer it's hooked up to, sounds very James Bondish...
Offline gojira54
« Reply #19 on: Fri, 17 January 2014, 13:02:47 »
It was in a government building hooked up to some equipment which controlled the internal mail system air plant, not 007 at all :)
