Author Topic: PCB mounted  (Read 4480 times)
Offline midnight2903
PCB mounted
« on: Thu, 21 November 2013, 09:34:16 »
Hello,
can anyone give me a list of PCB mounted keyboards?
I wanna get one XD
Re: PCB mounted
« Reply #1 on: Thu, 21 November 2013, 09:35:28 »
Pretty much all the Cherry G80 series
KBT Pure/Race/Poker (except poker ii)
NEO KB-87
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: PCB mounted
« Reply #2 on: Thu, 21 November 2013, 10:45:27 »
Sadly there are not as many as I think there should be. In addition to the above I discovered recently Dah Yang K-156.
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: PCB mounted
« Reply #3 on: Thu, 21 November 2013, 10:46:40 »
I stand corrected XD
« Last Edit: Thu, 21 November 2013, 10:48:12 by lcs »
Re: PCB mounted
« Reply #4 on: Thu, 21 November 2013, 10:47:23 »
GON.
I thought all of Gon's either had a plate or the case was the plate??
Offline lcs
  • はやく
Re: PCB mounted
« Reply #5 on: Thu, 21 November 2013, 10:47:47 »
GON.
That makes much more sense :P
Re: PCB mounted
« Reply #6 on: Thu, 21 November 2013, 11:49:15 »
IKR...
Whats that K-156?
Re: PCB mounted
« Reply #7 on: Thu, 21 November 2013, 12:00:34 »
K-156, and there is also this K-159... they really aren't particularly nice and have pretty low build quality. Unless you find one for extremely cheap I really wouldn't go for one of them honestly. Cherry G80 are much nicer and can often be found for under $40 used and $70 new.
Offline Oobly
Re: PCB mounted
« Reply #8 on: Fri, 22 November 2013, 08:47:05 »
Wasn't the first Poker also PCB mounted? (no plate)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: PCB mounted
« Reply #9 on: Fri, 22 November 2013, 08:54:08 »
Yes, see second post :P ;)
Re: PCB mounted
« Reply #10 on: Fri, 22 November 2013, 10:42:18 »
KMAC2 can be PCB mount
Re: PCB mounted
« Reply #11 on: Fri, 22 November 2013, 10:58:59 »
Also GH60 I believe.
Re: PCB mounted
« Reply #12 on: Fri, 22 November 2013, 11:05:16 »
Many of the customs can be PCB mount.
Sprit, most likely Duck's lightsaver as well. etc.
I would recommend a G80, though their case construction isn't as sturdy as some, it's usually good enough for a keyboard.
For non cherry MX switches,
There are also some hall effect keyboards and reed switch keyboards that are PCB mounted.
« Last Edit: Fri, 22 November 2013, 15:36:01 by dorkvader »
Re: PCB mounted
« Reply #13 on: Fri, 22 November 2013, 11:08:15 »
Sprit, phantom, most likely Duck's lightsaver as well. etc.
phantom can not be PCB only it requires a plate since it does not have holes for PCB switches to anchor in.
Re: PCB mounted
« Reply #14 on: Fri, 22 November 2013, 11:57:31 »
Korean customs are expensive as HELL!!
Any particular place to get the Poker 1?
But that thing is so small >.<
Offline Human
Re: PCB mounted
« Reply #15 on: Sun, 24 November 2013, 00:09:14 »
PLUM96 wireless version is PCB mounted.
Though, the one and only flaw to it is the spacebar incompatibility.
Offline Oobly
Re: PCB mounted
« Reply #16 on: Sun, 24 November 2013, 03:59:13 »
Why do you want a PCB mounted board? If it's so you can open the switches easily, a few plate mounted boards allow for that by having extra spaces in the switch holes.
Offline Beca
  • what am i doing with my life
Re: PCB mounted
« Reply #17 on: Sun, 24 November 2013, 04:27:55 »
Really? That would be so convenient. Are there any common boards out there that come with this default plate, or is that just for custom keyboards?
Offline terran5992
  • One With The Cup Rubber
Re: PCB mounted
« Reply #18 on: Sun, 24 November 2013, 04:48:09 »
Either PCB mounted switches or keyboards with the phantom plate
Re: PCB mounted
« Reply #19 on: Sun, 24 November 2013, 06:24:56 »
Yeah I want it for the easy switch replacement.
But are there really plate mounted keyboards with that function?
Re: PCB mounted
« Reply #20 on: Sun, 24 November 2013, 06:40:40 »
Yes the phantom plates, GH60 plates, sprit's current group buy plates, and some of the other custom plates
Re: PCB mounted
« Reply #21 on: Sun, 24 November 2013, 06:56:40 »
I see, but most of those nids assembly right...
I dunno how to solder QAQ
Offline absyrd
  • CPT HYPE PADAWAN
Re: PCB mounted
« Reply #22 on: Sun, 24 November 2013, 07:08:01 »
You can find them on classifieds assembled once in a while. Or you can source the parts and have it assembled for you. Not going to be cheap, though.
If you are on a strict budget and/or need a board sooner than later, you'll probably want to go with one of the boards mentioned earlier in the thread.
Re: PCB mounted
« Reply #23 on: Sun, 24 November 2013, 08:16:36 »
The ErgoDox can be PCB-mounted, in the standard layout.
The recent Cherry G80-3850 ("MX-Board 3.0") is one exception.
« Last Edit: Sun, 24 November 2013, 08:19:03 by Findecanor »
Re: PCB mounted
« Reply #24 on: Sun, 24 November 2013, 11:29:14 »
Oooo how did I forget about the Plum 96?
