Author Topic: Silenced my HHKB Pro 2!  (Read 22370 times)
« on: Sat, 23 November 2013, 20:06:45 »
Hey everybody! I was going to originally post in the HHKB Topic but I ended up taking too many Photos! :)
It took me 3 hours total including taking photos and doing everything to how I want it done in the end. Enjoy!
3/16" Medium Neon Dental Bands. Seperated the Orange and Yellow for Candy Corn! and Pink and Purple because they rock!
2018 Update: Use a Krytox lube. Techkeys sells Tribosys 3204 (a Krytox™ GPL 204 grade 0 lube) at the moment. Thanks to Michael BRO, he stated that you can best achieve lubing by applying it like so:
In the case slider housing slots. Evenly and not over doing it. A qtip or the applicator stick from techkeys would work great.
Also instead of dental bands you can use kbdfans silence x stickers or the sliders and foam discs from a type s hhkb or silent variable Realforce.
Removed all of the keycaps
Removed the 3 phillips screws
Unplugged wire harness, Removed 17 I believe, smaller phillips screws
Popped the Plungers out by gently pressing the opposite end of my small screwdriver into them (it is a small ps3 screwdriver)
First 3 rows I did orange and yellow, plungers are the same direction on each hole not like stock they were random
Did pink and purple for the bottom 2 rows
The stabilizer plunger just pops out the same direction and push forward towards you
Used EK MechLube 2 to lube the stabilizers
Be careful, the springs and rubber fall off in certain areas of the circuit board
Re assemble, make sure plungers are facing down when re screwing circuit board screws
Finished product, sorry couldnt get the right lighting tonight..
Mod Price factor 10/10
Mod Satisfaction 10/10
Actuation presses are just a tad shorter but the sound is way more soothing, the Thock is beautiful and no high pitch rattle anymore. Love it!
It is like rain drops dropping everytime I type and it feels very smooth to type on.
Now I have a silenced HHKB Pro 2 in Black and had enough money leftover to spend on a CC instead of the special plungers :)
Mod is definitely worth the time and obviously the price!
Quick video I shot on my iPhone 5. You can view in HD on Youtube.
HHKB Pro 2 45g 3/16" Medium Dental Bands and Leopold FC210TP MX Browns w/ Red O-Rings
« Last Edit: Sun, 30 December 2018, 06:05:53 by dustinhxc »
Re: Silenced and Lubed my HHKB Pro 2!
« Reply #1 on: Sat, 23 November 2013, 20:08:26 »
Too bad you can't see the colors of the bands.
Offline Michael
  • Formerly Bro Caps
« Reply #2 on: Sat, 23 November 2013, 20:09:43 »
Very nice... but you didn't lube the sliders, only the stabilizers? :O
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #3 on: Sat, 23 November 2013, 20:11:47 »
How this is the O- ring band?   Nice Job !   :thumb:
« Reply #4 on: Sat, 23 November 2013, 20:16:10 »
Thank You, dang it Im a noob to all of this, Im not sure what you mean? :o
« Reply #5 on: Sat, 23 November 2013, 20:20:03 »
I didn't realize anyone actually used the lube from ek :P
« Reply #6 on: Sat, 23 November 2013, 20:22:36 »
haha I dont know any better, what kind do you like :D ?
Offline Michael
  • Formerly Bro Caps
« Reply #7 on: Sat, 23 November 2013, 20:25:10 »
You lube the slider groves on the faceplate of the HHKB that guide the sliders up and down. In these groves:
Use a mixture of Krytox 205 grease and 103GPL Krytox oil.
« Reply #8 on: Sat, 23 November 2013, 20:27:40 »
Thank You! :) I appreciate it! I was searching as you posted that and only found MX info. Thanks!
« Last Edit: Sat, 23 November 2013, 20:29:14 by dustinhxc »
Offline Sniping
« Reply #9 on: Sat, 23 November 2013, 22:50:20 »
I'm still interested in this mod, seems like a way to make Topre even smoother than stock. Will kawa's Thick Krytox Lube Kit work fine as a substitute for the 205 and 103GPL mix?
OP: Great mod! Can you post a short video clip if you can? I just like having more videos of these silencing mods so you can compare between silencing methods and get a better sense of what it sounds like irl
« Reply #10 on: Sat, 23 November 2013, 22:57:21 »
Dental Bands! Skinnier then the o-rings. Thank You :) It sounds amazing!
Yeah, it is cool knowing they are underneath but it would be neat if you could see them with the keycaps off. I want to swap my plungers with the purple ones even though youd only see them with the keycaps off as well. All about that customization!  :p
Sure I can film a clip soon, thank you!
« Last Edit: Sat, 23 November 2013, 22:59:51 by dustinhxc »
Offline kelske
  • The North Borders
Re: Silenced my HHKB Pro 2!
« Reply #11 on: Sun, 24 November 2013, 00:32:53 »
Those BlueLounge Kicks! ;D
« Reply #12 on: Sun, 24 November 2013, 00:33:42 »
haha Yeah! I love them :) Thanks to CPTBadAss for showing me the link!
Offline jinxedx84
« Reply #13 on: Sun, 24 November 2013, 00:39:23 »
looks good I envy your HHKB
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
« Reply #14 on: Sun, 24 November 2013, 00:40:53 »
Thank You! Awe, yeah it is everything I imagined it would be and now it sounds amazing too. Now I need to get the different RealForce Key blanks. Orange, Green, maybe another color too...  :)
« Reply #15 on: Sun, 24 November 2013, 01:03:45 »
I made a quick video for you, the ten key is browns w/ red o-rings. The HHKB is the stock 45g and 3/16" Medium Dental Bands.
Offline Sniping
« Reply #16 on: Sun, 24 November 2013, 01:04:19 »
Awesome, thanks!
« Reply #17 on: Sun, 24 November 2013, 01:05:01 »
« Reply #18 on: Sun, 24 November 2013, 01:13:38 »
i'll be honest, maybe it's the mic but... i heard no difference between your hhkb and mine. completely stock here.
but i have tried to train myself not to bottom out so maybe it's that?
« Reply #19 on: Sun, 24 November 2013, 01:17:00 »
It is just a phone video but that is full hard presses so it could be just you not bottoming out, i definetly notice a difference though since I bottom out. It used to have a rattle high pitch click like an mx switch when i released the key from coming back up. Now I only hear the thock.
« Reply #20 on: Sun, 24 November 2013, 01:22:26 »
i need to try the mod to see if i notice a difference.
but i need to go 55g first, i've caught myself spamming letters when i rest my hands on the board :(
Offline Michael
  • Formerly Bro Caps
« Reply #21 on: Sun, 24 November 2013, 01:23:51 »
The 55g is a truly beautiful switch. Especially for heavy typists. And especially good for heavy keycaps ;)
« Reply #22 on: Sun, 24 November 2013, 01:24:54 »
indeed ;) now that EK has 55g in stock i need to get a board.. or find one used and find somebody to mod it for me >.<
« Reply #23 on: Sun, 24 November 2013, 01:26:27 »
Yeah mine only took a while because I was taking photos and color coordinating when it obviously doesnt matter lol But give it a try and see if you can tell a difference! :)
Id really like to try 55g as well, this 45 is pretty nice. The release is snappy but I bet 55 would be epic to type on.  :thumb:
Offline MJ45
  • HHKB Pro
« Reply #24 on: Sun, 24 November 2013, 06:58:20 »
Nice mod good job, I will do a silence mod on mine when I find a suitable material for the dampers. There are other mods that use a very thin rubber punched out to make rings. My only reservation about dental bands is the reduction of the plunger stroke due to the band thickness. The HHKB type S uses a very thin damper ring with minimal stroke reduction.
« Reply #25 on: Sun, 24 November 2013, 07:09:42 »
Topre is much easier to mod than MX!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #26 on: Sun, 24 November 2013, 07:16:46 »
Thanks for the detailed guide, dustin. For a self-proclaimed "noob to all this", nice to see you jump right in and do some modding.
Offline Sniping
« Reply #27 on: Sun, 24 November 2013, 10:33:57 »
It's hard because you don't have the regular unsilenced switch for reference. Here's a clip comparing the two, this is the real Type-S but the sound should be very similar, the only difference that I see between a dental band modded HHKB and a Type-S is the key travel
« Reply #28 on: Sun, 24 November 2013, 13:52:49 »
Haha yeah I like to just jump into things, modded most of my video game stuff and my macbook pros. As soon as I get them I open them up and upgrade everything! :)
I know MX you have to solder the switches in correct? But Topre do you just swap springs or domes?
Thanks! Yeah if I had the time and a bit more money I wouldve used the silcenced plungers and foam from the realforce the purple! or punched out the rubber discs of a sheet of rubber.
Thanks for posting this video! This is the exact difference! :D Hear that high pitch at the top? I never intended to take a video or I wouldve left a plunger with no dental band.
Thanks!  :thumb:
Offline Caaaarrrt
« Reply #29 on: Mon, 25 November 2013, 01:14:21 »
Looks good mate.
I'm enjoying mine too and my friend came around and tried it, now he has left me his HHKB to do the mod to as well.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
« Reply #30 on: Mon, 25 November 2013, 01:18:51 »
Looks good mate.
Thank You, hehe thats awesome :)  :thumb:
Offline theMANtonio
  • Go Hawks
« Reply #31 on: Mon, 25 November 2013, 13:14:30 »
Nice write up! I did the same thing, but just using bands that were "lighter" (2.5oz) -- not sure what that means in orthodontics.
I actually did not use any extra lube anywhere (not for stabilizers, not for the slider grooves), and I feel like the the keyboard feels a lot smoother. Maybe just a placebo effect, but the dental band mod is definitely worth it!
« Reply #32 on: Mon, 25 November 2013, 13:19:26 »
Yeah the lube isnt necessary till they get worked in a bit but I did it just since the case was open! Awesome man!  :cool:
Offline Plater
« Reply #33 on: Wed, 25 December 2013, 00:22:39 »
Very nice! Planning on getting this for my self later on this year. But may I ask, which o-rings did you get?
Offline eth0s
  • Peace & Love
« Reply #34 on: Wed, 25 December 2013, 00:43:16 »
 Congrats on the mod!  Nice job.  I remember when you first mentioned this to me, I told you to PM Bro Caps to get his input, since he is the resident GH expert on Topre mods.  (Hmm, I hope he didn't blow you off.  heh.)  Oh well, it worked out.  Also, now you know about Krytox grease.  I guess I could have mentioned that too.  Oh well.  But I didn't know that you didn't know about Krytox.
Anyway, great job!   :thumb:
« Reply #35 on: Thu, 26 December 2013, 17:39:45 »
Thanks! 3/16" Medium Neon Dental Bands
Thanks man! :D
Offline HipsterPunks
  • Gangnamember
« Reply #36 on: Thu, 26 December 2013, 22:35:58 »
Saw your post on reddit and it steered me away from the type-s, very informative and I appreciate the pics. I am not very good at modding
sell ass and eat out
« Reply #37 on: Thu, 26 December 2013, 22:43:23 »
Thanks man! Yeah if they had a Black Type S I may have did it but I just had to have the black. (Dark Gray)  :thumb:
Offline yjfknt
« Reply #38 on: Fri, 27 December 2013, 18:31:54 »
Don't these rubber bands make bottoming out really smushy?
Offline Sniping
« Reply #39 on: Fri, 27 December 2013, 18:49:57 »
No, I don't think you understand the mod. The dental band doesn't do anything when you press the key down because the dental band goes on top of the plunger, so the rubber band doesn't come into contact with anything when you bottom out. The only reason it's there is to dampen the upstroke when you let go of the key.
Actually, this makes it sound even more confusing...
Offline yjfknt
« Reply #40 on: Fri, 27 December 2013, 19:06:46 »
Oh the reason I asked is because I'm doing this on a MX keyboard and it feels kind of mushy and I'm debating whether or not I should get real O-Rings and see if they will be more consistent.
Offline Sniping
« Reply #41 on: Fri, 27 December 2013, 20:12:42 »
Yeah, I felt the squishiness on MX as well, but that's because the dental bands serve different purposes for the two types of switches.
« Reply #42 on: Fri, 27 December 2013, 23:39:05 »
Still feels very stiff. Just a tad shorter travel. Never used them on MX but I have used red orings and those arent mushy either to me.
  • Gangnamember
« Reply #43 on: Sat, 28 December 2013, 00:35:10 »
Dustin topre newb question, I have a set of blanks coming in the mail. I want to change the modifiers and space bar. My question is I'm having to pull really hard to remove the numrow keycaps (scary it feels like I'm gonna damage the caps) are the stabilizers connected to the keycaps at all? Is this something I need to be weary of before just yanking these keys out? Thanks
« Reply #44 on: Sat, 28 December 2013, 01:10:33 »
Nope all you can see under the key is the plunger. just pull hard and itll pop off. But with the spacebar I use 2 wire pullers. One on each end.
Offline Beca
  • what am i doing with my life
« Reply #45 on: Sat, 28 December 2013, 01:12:01 »
that sounds really nice :o nice tats too!
« Reply #46 on: Sat, 28 December 2013, 01:17:32 »
Thank You! :) I have more pictures in the Post your tattoos thread.
