Author Topic: I've made a thing - 32key Keypad  (Read 2430 times)
Offline regack
« on: Sat, 23 November 2013, 22:12:35 »
So, I made this thing... it's a 32-key gamepad?  Sure, that's what I'm going to be using it for anyway.  Unless it doesn't work out right.  We'll see.
This one should soon be replacing my old 'gamepad' which I made a few years ago, thanks to the work Dox originally did on the DoxKB.  There are some keys I just don't use, and the USB came out the wrong place (because of the Teensy) and I've learned a lot how I use it, and what I thought I might like to change/improve.
The old board
MOZ made the acrylic case in the picture there.   Yes, it's still powered by a Teensy (on a daughterboard) or an ATMEGA32U4 (also on a daughterboard) either way, the main board doesn't care :D.  The Teensy version can partially be seen at the top of the first pic... the non-Teensy version I haven't quite put together yet, but the boards can be seen at the top of this pic below.
Anyway, that's all I have for now, just ... sharing?
Re: I've made a thing - 32key Keypad
« Reply #1 on: Sat, 23 November 2013, 22:48:16 »
That looks awesome! Thanks for sharing, and thank you for the silkscreen mention also!
:thumb:
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #2 on: Sun, 24 November 2013, 06:26:37 »
thats awesome
« Reply #3 on: Sun, 24 November 2013, 06:36:47 »
Very nice work!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #4 on: Sun, 24 November 2013, 06:36:52 »
Wowza, just noticed my name in the silkscreen!.
As I mentioned in out little exchange, this is excellent, once this is complete, we should take it to the next level with an integrated joystick.
