Author Topic: Broken keyboard for switches  (Read 1963 times)
Offline BakaPhoenix
« on: Mon, 25 November 2013, 09:47:27 »
Hi, I found a not working TTeSport Meka G unit with cherry black for 20 euros + shipping.
Is it work buying if to take switches and resell them(i'll keep the keycaps since are italian layout and can be usefull for other iso keyboard since i'm italian)?
Edit: crap i was sure to be in the keyboard subforum, if a mod can mode it i'll be really gratefull <.<
« Last Edit: Mon, 25 November 2013, 09:50:41 by BakaPhoenix »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Broken keyboard for switches
« Reply #1 on: Mon, 25 November 2013, 10:02:08 »
What is wrong with it do you know? It could be a simple repair. I suppose you can probably make the 20EUR back selling the switches, and maybe some other parts could be useful to someone for projects or mod practicing.
Offline BakaPhoenix
« Reply #2 on: Mon, 25 November 2013, 10:10:08 »
The guy said that the pc have problems to recognize the keyboard, sometime It can work for an hour or two but after that it stop to work.
I asked him if changing the cable could fix the problem but looks like the space for the connector is enought only for the included cable. I might be able to mod a cable to let it fit, but if it doesn't work even with that i don't really know how to fix it
« Reply #3 on: Mon, 25 November 2013, 10:17:45 »
Could be bad solder joint, maybe easy to fix with reflow.
Offline BakaPhoenix
« Reply #4 on: Mon, 25 November 2013, 10:27:34 »
Well it doesn't matter anymore XD while i was here deciding another guy bought it XD
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5 on: Mon, 25 November 2013, 11:10:33 »
For that price I would have picked it up just because that many switches could very well cost more than that.
