Author Topic: Who should I go to get these made?  (Read 4315 times)
Offline nerVzzz
« on: Wed, 27 November 2013, 12:57:33 »
I have some designs for keys but don't know who to contact to make them. I've contacted 4-5 companies but none of them gave me a quote nor even replied to my emails.
A very low quality image of the keys I want can be found here http://imgur.com/NZjBiSp
Thanks in advance,
Jon
Re: Who should I go to get these made?
« Reply #1 on: Wed, 27 November 2013, 13:09:48 »
WASD keyboards can make them but they won't be colored.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Wed, 27 November 2013, 13:11:11 »
In any case you will be looking at probably having at least 20 of each made to make it remotely cost effective. What row, key size and base color do you want to do them? Assuming you need the legends in those or close to those colors...
You could do them as dye sublimation with imsto (who is a member here with Chinese manufacturing contacts). Key base must be lighter color than legend, you will probably be more or less limited to white keys.
You could do them as doubleshots with Signature Plastics. Most designs should be doable, you would definitely need to rework the hand to simplify it a little bit.
You could do them as infilled keys with QWERkeys.
If you just need the legend, and the color isn't important you can do them as lasered one off with WASD keyboards.
Or... you could go with DIY ghetto approach and use waterslide decal with clear coating. Or you could print out inserts for relegendable keycaps.
Offline nerVzzz
« Reply #3 on: Wed, 27 November 2013, 18:00:07 »
Thanks for the helpful replies.
I couldn't find an explanation on the net for infilled keys, do you mind explaining what that is?
Since it won't be very cost effective to get coloured keys I think for now I will get a one off set from WASD. Should I desperately need colour I suppose I could contact imsto although he hasn't replied to my pm from last month. Is there some secret way I don't know about to get in contact with him?
« Reply #4 on: Wed, 27 November 2013, 18:10:15 »
http://www.qwerkeys.co.uk/keycap-info/legend-processes/
Offline terran5992
  • One With The Cup Rubber
« Reply #5 on: Thu, 28 November 2013, 07:57:03 »
Your best bet would be via pm or email
Offline berserkfan
« Reply #6 on: Sun, 01 December 2013, 10:28:00 »
talk to Imsto. He quoted me $3 per custom color dyesub, although I'm not clear what the MOQ is. But I suppose if you could do an interest check, you might wind up meeting MOQ.
Offline justnits
« Reply #7 on: Sun, 01 December 2013, 19:11:21 »
Thanks in advance,
Jon
that looks like quake's weapon/ammo icon
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #8 on: Sun, 01 December 2013, 19:13:07 »
If you're thinking of making a Quake set--I would totally be down for that.  Multiples of that :o
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline Mikey Mo
« Reply #9 on: Sun, 01 December 2013, 21:52:24 »
wasd keyboard?
« Reply #10 on: Mon, 02 December 2013, 03:32:15 »
Sounds like that might be an excuse for a GB!
Offline divito
« Reply #11 on: Fri, 06 December 2013, 22:53:29 »
Yes, interest check would be a good next step.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline jlaw904
« Reply #12 on: Sat, 07 December 2013, 04:27:44 »
I'm looking for a Q3 set too. Mainly the Q3 logo.
« Reply #13 on: Mon, 09 December 2013, 03:22:36 »
Just upload an image on the website custom key page and order the color keys you want :) They will make it.
Offline keeman
« Reply #14 on: Mon, 09 December 2013, 10:47:20 »
wasd keyboard does uv printing, so that means it supports colored images to be printed on the keycap,
« Reply #15 on: Mon, 09 December 2013, 13:34:10 »
They only laser or engrave, i tried to get colors they only laser (burn) into the cap.
Offline bigx333
« Reply #16 on: Wed, 11 December 2013, 02:50:46 »
I would be so up for a GB of quake set  :eek:
2TU | LZ-GH
Offline Wildcard
  • When caffeine isn't enough
« Reply #17 on: Sat, 21 December 2013, 16:00:58 »
You could also check with IMSTO, he should be able to get these made for you using dyesub on PBT, not sure if an MOQ will be required.
