Author Topic: Alternative to BeagleBone Black?  (Read 5131 times)
Offline Pacifist
  • on hiatus
« on: Thu, 28 November 2013, 16:41:07 »
I want to get a small computer like the BeagleBone Black to use as a media computer and watch movies on it.
Is the beaglebone the best option or are there better, newer alternatives?
Re: Alternative to BeagleBone Black?
« Reply #1 on: Thu, 28 November 2013, 17:20:47 »
Raspberry pi?
Offline Pacifist
  • on hiatus
« Reply #2 on: Thu, 28 November 2013, 17:50:19 »
Raspberry pi?
beagleboard is more powerful than pi I think
Offline nuclearsandwich
« Reply #3 on: Thu, 28 November 2013, 18:17:30 »
Raspberry pi?
The BeagleBone Black is more powerful than a Raspberry Pi, but it also runs on an ARM processor whereas the Pi is Intel compatible. This doesn't mean a whole lot but if you're planning on running a specific Linux distro rather than the default distribution you should make sure that there's an ARM release channel and that the packages you want are part of it.
Offline Pacifist
  • on hiatus
« Reply #4 on: Thu, 28 November 2013, 18:21:19 »
Raspberry pi?
I'm just going to use it as a media PC and have it permanently next to my tv
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #5 on: Thu, 28 November 2013, 18:40:04 »
pcduino?
50 bucks on ebay
it uses an ARM 9 I think
2gb flash
and run linux
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Fri, 29 November 2013, 00:37:20 »
Why not go for a complete Arm net top for a little bit more. You have the Giada Q11 and CompuLab Trim-Slice or Utilite. I think Trim-Slice is best deal, Tegra2, 1GB ddr2, 32GB ssd, Gb ethernet, wifi N, bluetooth, hdmi, tv in, case for $120.
« Last Edit: Fri, 29 November 2013, 00:41:27 by IvanIvanovich »
Offline PointyFox
« Reply #7 on: Fri, 29 November 2013, 00:48:30 »
There's a ton of Android based minicomputers for connecting to TVs.  I have one that works pretty well.  They're like $35-$80.
« Reply #8 on: Fri, 29 November 2013, 01:22:43 »
True, there are lots of set top box type things...  Some of the Android ones like the new Geniatech ATV1800 might not be too bad. Boxee thing is bearable as well (it's an Atom based though), it's very much xbmc.
