Author Topic: Dead mouse on my desk.  (Read 9415 times)
Offline Chau
  • .5 Korean, .25 Vietnamese, .25 Chinese, Oz accent
« on: Sun, 01 December 2013, 03:27:44 »
Its an old DA. Any way to try and find out whats wrong and try to fix it?
Cheers
Offline dragonxx21
Re: Dead mouse on my desk.
« Reply #1 on: Sun, 01 December 2013, 03:33:22 »
Cheers
Describe the problem? Is it just not working when you plug it in?
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #2 on: Sun, 01 December 2013, 03:41:51 »
Cheers
The weirdest thing happened when I installed a fresh version of Windows 7 x64 on one computer and when I tried to install the newest version of Etron USB 3.0 driver, all the USB devices just disappeared, vanished (keyboard and mouse). I'm not saying it's the same what's happened to you but the newer driver really stuffed me up BIG TIME.   I had to plug in an old PS2 mouse to download the older version for all the devices to re-appear again.
I knew why I keep on buying PS2 enabled motherboards - because they simply RULE  :thumb: .
« Last Edit: Sun, 01 December 2013, 03:43:30 by Elrick »
Offline vun
  • Just one more thing
« Reply #3 on: Sun, 01 December 2013, 03:52:18 »
Cheers
Open it up first, check for any loose wires of other visible defects.
My old Habu had the wire come loose inside, opened it up and seated the connector firmly back in place and that fixed it.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Sun, 01 December 2013, 04:27:24 »
Cheers
Had the same issue with a brand new xornet.
Offline Chau
« Reply #5 on: Sun, 01 December 2013, 04:45:14 »
Just doesnt work when plugged in. Have tried it on 2 pcs. When I have time will try opening it up. Any tips on opening it?
Offline davkol
« Reply #6 on: Sun, 01 December 2013, 04:54:03 »
What does "doesn't work" mean? I guess there should be something like `dmesg` and `lsusb` on MS Windows to check, whether it's a software, or hardware issue.
Offline vun
« Reply #7 on: Sun, 01 December 2013, 04:54:22 »
there shouldn't be any special tricks, there are screws under the feet and after those are gone it should pry open. Just be careful not to rip the top shell too far off, the LED is probably attached to that, so you risk tearing the cables out. If you do break it tho, no biggie, it works just fine without.
Offline damorgue
    • Personal portfolio
« Reply #8 on: Sun, 01 December 2013, 04:55:11 »
There are likely screws underneath, sometimes hidden under labels or the feet. If you stroke the labels you will notice if there is a hole underneath it so that you won't have to remove it beforehand. I would guess that it is simply the cable that needs to be reconnected inside or replaced.
I might have been interested in it for some parts had it been another mouse.
Edit: slow
Offline Elrick
  • Hype Master
« Reply #9 on: Sun, 01 December 2013, 05:37:46 »
Two screws (one) under each top L-shaped plastic feet which you peel off entirely.  The bottom center hole is hidden under their Razer sticker just above the bottom plastic foot.  I suppose they wanted to provide a way of forcing you to send the rodent back for RMA because you couldn't take the mouse apart without digging into their sticker, which would show everyone you had voided their so-called warranty (nice one Razer).
Offline Chau
« Reply #10 on: Sun, 01 December 2013, 07:10:23 »
I see all our resident mouse experts have chimed in, thanks guys. Ill check windows once more and then the DA will go under the knife.
Offline Chau
« Reply #11 on: Sun, 01 December 2013, 08:25:33 »
How do I check if the usb wire is ok?
Offline davkol
« Reply #12 on: Sun, 01 December 2013, 08:27:02 »
Is it plugged in inside the mouse? Otherwise, you'd probably have to play with a multimeter.
Offline Chau
« Reply #13 on: Sun, 01 December 2013, 08:33:26 »
Yeah it's plugged in, not like the mamba which is detachable. So looks like I'll have to open it up and check with a multimeter which I don't have.
Offline damorgue
« Reply #14 on: Sun, 01 December 2013, 11:33:18 »
The USB cable is only rarely soldered in place. If you open it up, you are likely to find a small molex-like connector to the PCB which makes them easy to replace.
Offline b3n
« Reply #15 on: Sun, 01 December 2013, 11:35:44 »
Thought I'd chime in as I also have a dead deathadder. I opened mine up and compared it to my working deathadder mouse and found no visible differences. What should I be measuring with the multimeter?
The problem I had with my mouse was it not being recognised by the computer. Driver error, giving a code 42
Offline damorgue
« Reply #16 on: Sun, 01 December 2013, 12:20:53 »
Without knowing the error codes, that doesn't give much. If a trace or circuit is broken somewhere and the controller doesn't get the data it should, it might output error 43 for instance. Since it outputs an error odds are that the software is OK and that it is a hardware issue. I don't think it is very common for their software to get corrupted.
I would check for obvious damage, burn marks, swollen capacitors, cables and joints. I would also check the cable. If they get bent around a lot the wires inside can cause intermittent connections. I had that in a device once and it measured OK in a multimeter but when bent back and forth it would occasional break the circuit.
Sidenote: Why do I keep coming across people with broken Razer mice? I am looking for some high quality scroll wheels. Why can't high quality mice break down for me to take some parts from them? Oh, right, nevermind... Contradiction in terms and whatnot
« Reply #17 on: Sun, 01 December 2013, 12:52:02 »
Am I the only one who thought, "awe, your cat brought you a gift"
Offline vun
« Reply #18 on: Sun, 01 December 2013, 12:59:23 »
Nope, my initial thoughts when seeing the thread title were along similar lines, although I was expecting either someone just putting a dead mouse on a mousepad or doing that thing where you stuff the inside of a dead mouse with the internals of a computer mouse.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #19 on: Sun, 01 December 2013, 13:04:15 »
Is this a razer mouse?  My hex randomly stopped working one day. I switched to a different mouse and removed all if the razer BS they made me install including the driver, then plugged it back in and rebooted. Now it works fine again. I'm on a Mac and it really did not like the razer bloat ware.
Not sure that's helpful, but it may not be hardware.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #20 on: Sun, 01 December 2013, 13:14:14 »
its probably the crystal. If it is the crystal, i doubt a multimeter will help you diagnose it. for 50 cents just replace it. Or if you cant buy a crystal locally, just buy a cheap $2 thumbdrive and harvest its crystal. btw, crystals look like this http://upload.wikimedia.org/wikipedia/commons/5/5d/Crystal_Packages.jpg
"Obviously, windows are central to Windows. But what is a window?"
Offline Chau
« Reply #21 on: Sun, 01 December 2013, 15:31:32 »
Thats just sick, who the f would do that. :eek:
Offline vun
« Reply #22 on: Sun, 01 December 2013, 15:40:52 »
It's an actual thing
Although not as cool as the guy who turned his cat into a quadrocopter
    • Force Project X
« Reply #23 on: Sun, 01 December 2013, 15:55:03 »
Oh my god. Sadly this is almost exactly what i had pictured when I saw the thread title.
Offline Chau
« Reply #24 on: Sun, 01 December 2013, 15:55:41 »
LoL
Offline Chau
« Reply #25 on: Sun, 01 December 2013, 16:02:19 »
Gonna get me a quadrocopter.
Offline Chau
« Reply #26 on: Mon, 02 December 2013, 04:19:03 »
I opened it but those screws were hard to unscrew. Lost one foot in the process, finally found it stuck on my sleeve. Saw the problem right away luckily, the usb connector was loose.
Thanks for all the advice. I'm quite chuffed. :thumb: just saved some $ but not really as I want to try the cm Spawn.
« Last Edit: Mon, 02 December 2013, 04:20:59 by Chau »
Offline Elrick
  • Hype Master
« Reply #27 on: Mon, 02 December 2013, 05:07:39 »
Why not get the CM Spawn as well?  Always have some mice in the draw as you never know when you'll need them.
Offline Chau
« Reply #28 on: Mon, 02 December 2013, 05:20:09 »
Will definitely get a spawn, want to try the shape. I've got a mamba and DA but I don't think they really suit my hand and grip style.
BTW, Perth looks really small on the map but has a pop. of 1.7 mil. Never had the chance to visit, it was just too bloody far.
wtf goat farm mt bike park.lol
« Last Edit: Mon, 02 December 2013, 05:21:46 by Chau »
Offline PointyFox
« Reply #29 on: Mon, 02 December 2013, 06:25:28 »
If you like the shape of the G5 type mice, you'll probably hate the shape of the Spawn.  I heard the Spawn was originally made for people with small hands or younger gamers.  It's short and wide compared to most mice.
Offline berserkfan
« Reply #30 on: Wed, 04 December 2013, 06:25:46 »
Actually, chau, sometimes the cable is poorly soldered and may have come loose. Did you hear any rattling from inside the mouse?
Of course, as a guy who does lousy soldering, I know this very well!
Offline Chau
« Reply #31 on: Wed, 04 December 2013, 06:49:15 »
The usb connector to the pcb was a bit loose, i just pushed it back into place.
Offline Nojo
« Reply #32 on: Thu, 05 December 2013, 05:21:05 »
I assume there's no way to fix broken sensor myself? The buttons work fine, just that the cursor won't move. I tried on multiple PC with different OS
Offline damorgue
« Reply #33 on: Thu, 05 December 2013, 12:37:47 »
I'd look for disconnected cables, traces which appear broken, swollen capacitors or some other physically faulty component. If nothing is obviously damaged, then it is far harder to fix. I would say that it is practically impossible to fix if there is a defect within the sensor or the controller since you don't really have access to either one. Replacing the entire sensor is likely more trouble and money than buying a new mouse of the same model.
Offline Nojo
« Reply #34 on: Thu, 05 December 2013, 19:39:25 »
Thanks for the advice, will try to open the RAT 7 and check for those  :thumb:
