Author Topic: Looking for green alps..  (Read 3746 times)
Offline frowni
  • i love typing!
« on: Sun, 01 December 2013, 19:24:33 »
Hey there,
I was looking for a keyboard with green alps..i found that Ducky had them, but now it says discontinued. Guess they are not making them anymore.
Does anyone know any other brand than Ducky which makes keyboards with green alps?
Offline hasu
  • @tmk
Re: Looking for green alps..
« Reply #1 on: Mon, 02 December 2013, 18:47:34 »
Are you sure about green Alps? If you use wrong word you cannot get right answer.
This post and the thread may help you.
http://geekhack.org/index.php?topic=49616.msg1135246#msg1135246
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #2 on: Tue, 03 December 2013, 18:47:58 »
Ducky used reduced-force Xiang Min KSB-C (clicky, green) and KSB-N (linear, black) in their "XM" 1000-series keyboards. Xiang Min KSB series switches are Alps clones, i.e. they're not made by Alps or for Alps, but they're fully interchangeable with genuine Alps switches.
Alps switches have not been made since early 2012, when the Forward Electronics switch production line closed. (Strictly speaking, Alps's involvement stopped several years before that when Forward lost their licence to the Alps branding, but Forward Electronics continued production for a few more years with unbranded switches, as you find in the Matias Tactile Pro 2 and 3.)
You can buy Xiang Min KSB-C and KSB-N switches (not sure if Ducky spec) from Mechanical Keyboards, though if you want clicky switches you're better off buying Matias switches. Note that Xiang Min were never consistent with the colours — the Tactile Pro 3 uses KSB-LE switches that are also green, and my sample KSB-C switches are ivory. Their colours are a bit random — stick to the product codes.
"Green Alps" specifically refers to Alps SKCL Green, a highly-regarded linear switch from Alps Electric that was discontinued by 1994.
In terms of keyboards with the same or comparable switches, your choices are very slim, and the Matias Tactile Pro (and related products) is the only one I'd be comfortable recommending. Hopefully as time passes, more products will take on the Matias switches. There's also the AZiO Levetron Clicker series (and various other rebrands) — no idea on reliability. That uses a similar Alps clone series.
« Last Edit: Tue, 03 December 2013, 18:53:24 by Daniel Beardsmore »
Bore Awards
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Tue, 03 December 2013, 18:53:31 »
Stay away from alps.
« Reply #4 on: Tue, 03 December 2013, 19:08:52 »
Alps are wonderful, with a few caveats, but I have never used the green ones.
- Franklin Roosevelt 1933
« Reply #5 on: Tue, 03 December 2013, 19:14:48 »
I have an old electronic typewriter with green Alps, and it is what prompted me to try a keyboard with MX reds.  I eventually decided that reds are too soft for my liking, and returned to MX blacks, and then MX greens.
« Reply #6 on: Tue, 03 December 2013, 20:27:54 »
Only if you don't want to catch the fever.  Alps are addicting.
Offline AKIMbO
  • HHKBro
« Reply #7 on: Tue, 03 December 2013, 21:31:17 »
Yes...ALPs are horrible.  Everyone give me all of your ALPs boards and I will properly dispose of them!
| KBD75 (box reds)
Offline phoenix1234
« Reply #8 on: Tue, 03 December 2013, 22:23:47 »
Blue alps kingsaver, salmon alps kingsaver, extra kingsaver pcb/plate, extra wang keys.
I like linear switches
Offline Pacifist
  • on hiatus
« Reply #9 on: Tue, 03 December 2013, 22:35:47 »
where does akimbro get his alps caps?
Offline AKIMbO
  • HHKBro
« Reply #10 on: Tue, 03 December 2013, 23:12:59 »
From responsible citizens who send them to me for proper disposal.
| KBD75 (box reds)
Offline Linkbane
« Reply #11 on: Tue, 03 December 2013, 23:19:50 »
Yes, feel the power of the Greens flow through you!
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
