Author Topic: Cherry MX Clears with O Rings  (Read 6115 times)
Offline takethree
« on: Sat, 07 December 2013, 01:34:56 »
Has anybody tried O Rings with Cherry MX Clears? Any idea how it feels?
Thanks.
Offline BlackWidowMan777
Re: Cherry MX Clears with O Rings
« Reply #1 on: Sat, 07 December 2013, 02:16:30 »
Well, it feels fantastic on my leopold FC660m - all that cushiony goodness can't be beat! Actually, with clears you don't bottom out so much over time anyway because the pressure mounts after actuation but still I prefer o-rings or soft-landing pads for maximum quietness for late night poundage  ;D
edit: Oh and welcome to Geekhack! Is this going to be your first mechanical keyboard?
« Last Edit: Sat, 07 December 2013, 02:51:29 by BlackWidowMan777 »
« Reply #2 on: Sat, 07 December 2013, 05:00:12 »
It feels a bit mushy, but when you type fast enough you don't notice as much as on other switches.
BTW, with the bottoming-out noise removed, the noise on the rebound becomes very apparent.
Offline ahmadmzak
« Reply #3 on: Sat, 07 December 2013, 05:24:45 »
I was thinking from where this rebound noise comes from. Can't we add another cushion somewhere to eliminate this?
Offline takethree
« Reply #4 on: Sat, 07 December 2013, 07:34:43 »
Thank you for the welcome!
This is like my 5th mechanical keyboard. Btw I have the exact same model. A Leopold FC660M in white with Cherry MX Clears. I try not to bottom out on these as they are quite stiff. It is also one of the harder keys to type on entry but you know what, I like the way it types. Very different from the other Cherry MX switches. I'm just wondering how much the O Rings will soften the impact when I do bottom out.
Offline takethree
« Reply #5 on: Sat, 07 December 2013, 07:36:37 »
How apparent is very apparent? Is it very loud like Cherry MX Blues? Currently the noise from the Clears are very minimal. I like it a lot. Great tactility and minimal noise.
« Reply #6 on: Sat, 07 December 2013, 07:46:05 »
woah in white sure you're not talking the Leopold FC700R (tenkeyless)? Anyway, didn't know 660M came in white...
I think he meant the sound when the key automatically pops back up (plastic rubbing on plastic, I think) which you would have heard or not on your own board.
It's a bit late here in Oz...so I crack it out tomorrow and give you as accurate a description as I can as to the sound with o-rings  :)
edit: I just saw the white FC660M with clears at qtan's store.... :)
« Last Edit: Sat, 07 December 2013, 08:08:36 by BlackWidowMan777 »
« Reply #7 on: Sat, 07 December 2013, 20:15:45 »
Hi I recorded the sound of my FC660M with black soft-landing pads installed:
0.00 Bottoming-out alpha keys as hard as possible
0.17 Bottoming-out space bar
0.23 Bottoming-out out backspace
0.32 Releasing alpha keys (rebound noise)
0.42 Releasing space bar (rebound noise)
0.46 Releasing backspace (rebound noise)
https://soundcloud.com/bwmnosh/fc660m-cherry-mx-clear-with-soft-landing-pads
edit: sorry, when I removed a keycap I found that I had the black soft-landing pads installed NOT o-rings  :-[
« Last Edit: Sat, 07 December 2013, 22:36:38 by BlackWidowMan777 »
Offline takethree
« Reply #8 on: Sun, 08 December 2013, 03:33:45 »
Hey thanks for these. The backspace one reminds me of a topre.
« Reply #9 on: Sun, 08 December 2013, 03:45:53 »
no problems at all  :)
