Author Topic: G81-8000HPBUS-2  (Read 3383 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
G81-8000HPBUS-2
« on: Sun, 08 December 2013, 20:16:40 »
Good cheap nearly full (bottom row is incompatible with MX) set of white/black doubleshots. $29.99+shipping
Offline Photoelectric
Re: G81-8000HPBUS-2
« Reply #1 on: Sun, 08 December 2013, 20:18:25 »
I'm curious why the bottom row is incompatible with MX--for future reference.
Re: G81-8000HPBUS-2
« Reply #2 on: Sun, 08 December 2013, 20:23:04 »
Because this
MY 1.25 mod in beige
and don't ask me why Cherry decide to mount the switch in position that required new keycap mold with off center for NO ****ING REASON.
« Last Edit: Sun, 08 December 2013, 20:25:10 by IvanIvanovich »
Re: G81-8000HPBUS-2
« Reply #3 on: Sun, 08 December 2013, 20:25:19 »
Good to know--thank you!
Offline laden3
Re: G81-8000HPBUS-2
« Reply #4 on: Mon, 09 December 2013, 10:09:54 »
If I am not mistaken, only the POM ones are incompatible. The ABS keys do not have off center stems but of course, the menu and windows keys should be pad printed.
I rrrove brrracks.
Re: G81-8000HPBUS-2
« Reply #5 on: Mon, 09 December 2013, 10:17:03 »
ALL 1.25 bottom row G81 use the same keycap design with offset, none of them are any good with MX keyboard. It doesn't matter which plastic at all, all same.
Offline dante
Re: G81-8000HPBUS-2
« Reply #6 on: Thu, 12 December 2013, 10:03:29 »
still one left!
Offline xmagusx
  • QWERTY is hateful.
    • The Ergonomic Zone
Re: G81-8000HPBUS-2
« Reply #7 on: Thu, 12 December 2013, 10:21:11 »
What type of switch does it feature?
Re: G81-8000HPBUS-2
« Reply #8 on: Thu, 12 December 2013, 11:13:19 »
G81 have MY switch. It's not very nice feeling switch, these are mostly good for getting doubleshots only to put on MX keyboard.
Offline xmagusx
Re: G81-8000HPBUS-2
« Reply #9 on: Thu, 12 December 2013, 12:40:59 »
Okay, but which switches are YOUR switches?
...kidding, thanks for the answer. :D
Re: G81-8000HPBUS-2
« Reply #10 on: Thu, 12 December 2013, 15:48:11 »
I have got one G81-8008, and the Space Bar was actually MX-compatible. I had not expected that. YMMV.
Offline korrelate
  • iubeo stultum esse libenter
Re: G81-8000HPBUS-2
« Reply #11 on: Sat, 14 December 2013, 23:11:14 »
One of the WoB sets I have came with this crap. Totally crushed my hopes when I finally figured out why this wasn't fitting on my board. Total WTF moment there...
Topre REALFORCE
Offline dante
Re: G81-8000HPBUS-2
« Reply #12 on: Sun, 15 December 2013, 12:37:31 »
I bought the last set.  The seller put it on sale with $3 off :)
