Author Topic: New Bluetooth 4.0 mice from Mad Catz (makers of RAT series)  (Read 5413 times)
Offline daerid
    • Rossipedia
« on: Thu, 12 December 2013, 11:25:15 »
MOUS 9 (full size)
http://www.cyborggaming.com/prod/maus9.htm
RAT M (mini)
http://www.cyborggaming.com/prod/ratm.htm
Very intriguing. I've still got my old RAT 7 (1st gen, can't use it cuz it has the bad sensor), and I love the design. But I find it odd that the MOUS 9 is stuck at 990dpi, of all things.
Re: New Bluetooth 4.0 mice from Mad Catz (makers of RAT series)
« Reply #1 on: Thu, 12 December 2013, 11:28:04 »
Ok so I'm actually considering this thing....they had me at bluetooth and 10 buttons....
Wait you sure these are new?
« Last Edit: Thu, 12 December 2013, 11:35:22 by SpAmRaY »
Offline daerid
    • Rossipedia
« Reply #2 on: Thu, 12 December 2013, 11:41:54 »
Not so sure about new, but I hadn't seen them before, and I try to stay current on mice developments. These may have slipped through the cracks.
Offline vun
  • Just one more thing
« Reply #3 on: Thu, 12 December 2013, 11:51:40 »
MOUS 9 (full size)
RAT M (mini)
Dunno how much you can do with software, but from the specs it seems like it's locked at low dpi and polling rate to save on power, but idk why they locked it. Maybe because it's easier and cheaper to make? Anyway, if I used my laptop more I'd probably consider getting one of them, but I already have a RAT7 that works just fine for desktop use.
« Reply #4 on: Thu, 12 December 2013, 11:54:49 »
I just noticed reviews from like April and June...so I dunno...
Offline daerid
    • Rossipedia
« Reply #5 on: Fri, 13 December 2013, 01:14:42 »
Yeah looks like they're fairly old then. Must not be anything special if they've stayed under the radar this long.
Offline HipsterPunks
  • Gangnamember
« Reply #6 on: Sat, 14 December 2013, 23:28:22 »
ill be glad to give a review of the RatM and Naga 2014 (gotta see what they mean when they say mechanical buttons) after the holidays, both are sitting under my xmas tree right now. currenty in love with my Rat7 and had no other reason to pick up another mouse except i travel with my gaming laptop alot so i figured i could just keep this little dude in my backpack. :thumb:
sell ass and eat out
Offline Ghetto Caps
  • i make ghetto caps.
« Reply #7 on: Sun, 15 December 2013, 11:28:44 »
The sensors are low end. No good.
Visit the Typing Test and try![/sigpic]
Offline Oobly
« Reply #8 on: Mon, 16 December 2013, 05:01:03 »
The MOUS9 has a 990DPI (?!?) single laser sensor, the RatM has a Philips Twin Eye (same as RAT7).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Leslieann
« Reply #9 on: Mon, 16 December 2013, 19:02:37 »
It's not a low end sensor in the M.o.u.s.9, it's an ultra high efficiency sensor, designed to work on glass. That mouse runs on a single AA battery for up to a year (good luck with that).
Also, glossy mouse? No.
Dust and fingerprint magnet (you won't buy a DAS for that reason but a mouse is okay?), but even more importantly, the gloss means less grip.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline vun
« Reply #10 on: Mon, 16 December 2013, 19:40:40 »
I've found that gloss and grip all depends on your skin. With clean hands, gloss is a nightmare, but with slightly damp/sweaty palms, gloss can stick like glue. It's nice on mice like the DA or the Naga2012 with wide grip, since you can lift the mouse without really having to squeeze on it.
Not really a fan of gloss though, but it does have its uses, even if said uses is a bit unreliable since your skin needs to be in a certain condition for it to work.
Offline daerid
    • Rossipedia
« Reply #11 on: Thu, 19 December 2013, 15:48:08 »
Hate glossy finishes on mice, blech...
Still want to get a MMO7 in white though.
Offline Oobly
« Reply #12 on: Fri, 20 December 2013, 02:47:13 »
I have an older RAT3 and a new glossy white one. I actually prefer the feeling of the gloss one. Grip isn't an issue for me, I find I have similar grip levels with clean hands. The shape makes it easy move it and lift it (the thumb buttons on the left and pinkie grip on the right). The old one actually feels "dirty" (just the rougher texture) compare to the new.
I'm quite interested in the M, but I fear it will be too heavy for my taste (I like them as light as possible). Not sure what to think of the PTE sensor, but it's also a bit of a turn-off, would prefer the optical from the newer RAT3.
