Author Topic: Has anyone used this layout?  (Read 3093 times)
Offline DrinkTea
« on: Fri, 20 December 2013, 23:23:01 »
Yes, I know it's not mechanical, but the idea seems interesting.
http://matias.ca/optimizer/
Has anyone tried it?
Re: Has anyone used this layout?
« Reply #1 on: Fri, 20 December 2013, 23:40:07 »
I suppose if someone had one of the full size boards with an aftermarket programmable controller they could emulate that....
Seems like it'd take a while to learn though.
« Reply #2 on: Sat, 21 December 2013, 01:39:09 »
And would tie you down to just that keyboard, then any time you used a different keyboard you would need to unlearn and lose time.
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Sat, 21 December 2013, 02:31:04 »
ewww alps
Offline eddie
« Reply #4 on: Sat, 21 December 2013, 03:49:24 »
ewww alps
Sorry if I'm wrong but I'm pretty sure they're "High-Quality Dome Switches" aka rubber dome.
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #5 on: Sat, 21 December 2013, 05:33:17 »
I do prefer this one.
I think it's the same idea, in one small space.
It's a shame it's absurdly expensive!!!
Offline terran5992
« Reply #6 on: Sat, 21 December 2013, 07:28:25 »
Im sorry i always associate matias with alps
Offline DrinkTea
« Reply #7 on: Sat, 21 December 2013, 10:19:53 »
I think it costs that much because people with disabilities usually buy it which means they're billing it to insurance. So naturally, prices get inflated. Other people's money, eh?
Also, couldn't the same be said about most custom layouts or features tying you down to using those types of keyboards only?
Offline Tony
« Reply #8 on: Sat, 21 December 2013, 11:06:06 »
Try to be observant and count how many times do you press Copy, Cut, Paste for a day. You will realize you press Backspace and stare mindlessly at the screen most of the time.
Offline tbc
« Reply #9 on: Sun, 22 December 2013, 01:30:04 »
i guess you're not a programmer?
Offline Tony
« Reply #10 on: Tue, 24 December 2013, 00:56:58 »
I used to be one 15 years ago. To be objective, you can use any key counter program to check for a whole day. You will be surprised with the results.
« Last Edit: Tue, 24 December 2013, 01:02:18 by Tony »
Offline Tony
« Reply #11 on: Tue, 24 December 2013, 00:59:49 »
double post, deleted
« Last Edit: Tue, 24 December 2013, 01:02:01 by Tony »
Offline agodinhost
    • Dr Ian O Xaman
« Reply #12 on: Thu, 26 December 2013, 07:31:04 »
It make sense ...
Offline daerid
    • Rossipedia
« Reply #13 on: Thu, 26 December 2013, 11:28:15 »
Made me curious. Got a key counter you'd recommend?
Offline Tony
« Reply #14 on: Fri, 27 December 2013, 01:07:31 »
Here is the KeyCounter software I used
http://download.cnet.com/KeyCounter/3000-2094_4-75373358.html
