Author Topic: Filco Keyboard Wire Question  (Read 2180 times)
Offline excalaver
« on: Mon, 23 December 2013, 03:01:29 »
I have 2 Filco Majestouch 2 Camou edition. 1 in brown keys and the other in blue. the 1st keyboard i had, the power kept turning off on the keyboard whenever i moved it, i had to twist and turn the end of the cable connecting to the keyboard in order to get the board powered up again. I got frustrated and bought another to replace this. Now, my 2nd board is also experiencing this issue. I believe a connection is loose somewhere. anyone know how i can get this fixed?
Re: Filco Keyboard Wire Question
« Reply #1 on: Mon, 23 December 2013, 03:23:38 »
You could open the case and see if the connector is still connected.  However this will void your warranty.
« Reply #2 on: Mon, 23 December 2013, 08:15:20 »
Do you move your keyboards a lot?
Offline yasuo
  • spanengan puyeng newbie
« Reply #3 on: Mon, 23 December 2013, 08:23:18 »
Same case in my country just camo of all series filco majestouch  have problem,and same, error with the cable :)
but it 2years ago 2010-2012,i think filco already repair :)
Logitech MK220 Colemak DH
« Reply #4 on: Mon, 23 December 2013, 09:12:57 »
I had the same problem with my camo.
Open up the board and re-plug the cable. Doesn't fix it completely, but it definitely makes it a lot easier.
If that doesn't work, buy a new cable for it. Should run you about $15.
Offline laffindude
« Reply #5 on: Mon, 23 December 2013, 09:15:59 »
Do you guys wrap the cable around the board when you stow it away?
Offline Photoelectric
« Reply #6 on: Mon, 23 December 2013, 09:16:23 »
Interesting--I had a Camo TKL for a while, from ~2011, I think, and it was fine.  I used the Camo cable in another Filco later, and also no problems.  Good to know for reference.
P.S.: I always coil my unused cables into a loop, plus Filco cables have pretty handy velcro wraps on them for that.  Bending in sharp angles is not very good for cables in the long run.
« Last Edit: Mon, 23 December 2013, 09:20:14 by Photoelectric »
« Reply #7 on: Mon, 23 December 2013, 09:17:19 »
I put it away the same way it came out of the box. Wrap the cable on itself, then put it in that handy container space in the box.
