Author Topic: GMK and costar stabilizers  (Read 4635 times)
Offline muad
« on: Thu, 26 December 2013, 00:55:53 »
I recently bought a set of dolch keycaps from gmk and can't seem to get the spacebar to work smoothly. It is noisier than with the stock keycaps and seems to have more of a rattle. I have seen a few people using filcos and quickfires with the gmk sets and am wondering if you guys have any ideas.
thanks
Offline domoaligato
Re: GMK and costar stabilizers
« Reply #1 on: Thu, 26 December 2013, 01:07:08 »
do not have the little white plastic stabilizers all the way in the holes? I would really make sure.
Offline MKULTRA
  • telling it how it is
« Reply #2 on: Thu, 26 December 2013, 02:38:38 »
thanks
Try putting some seran wrap or a plastic bag in the stab so they fit better in the keycaps.
« Reply #3 on: Thu, 26 December 2013, 03:30:33 »
Have you got Costar or Cherry stabilisers?
If Coster, make sure the stabiliser inserts are inserted all the way, and I'd use a small square of plastic ziplock sandwich bag if they are loose.
If Cherry, just make sure that the space bar is not warped, and that it is pressed on all the way.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Thu, 26 December 2013, 06:53:59 »
Yep you really dont want a warped spacebar
« Reply #5 on: Thu, 26 December 2013, 09:21:42 »
I have the same problem with my Olivetti set on my Filco.
Oddly enough, flipping the spacebar mostly fixed the problem.
Make sure your white inserts are full inserted first, too. If they're loose, the spacebar can get really noisy.
Offline Danule
« Reply #6 on: Thu, 26 December 2013, 14:44:54 »
thanks
make sure the stabs are in the correct direction, i have 3 filco's with 3 different cherry profile sets and have had 0 trouble with any of them, other than the stab insterts being loose, just used some plastic on them to make them a tighter fit.
45g Brown Brown Blue
Offline gh_pp
« Reply #7 on: Thu, 26 December 2013, 19:37:47 »
Hi,
Are there any pictures of videos showing how this mod is done? ziplock bags seem to be way too huge for the keycaps...
I asked the same question not long ago
http://geekhack.org/index.php?topic=52342.msg1159587#msg1159587
the suggestion worked somewhat for me but not entirely fixed my problem and the tape fell off easily.
Thanks
« Last Edit: Thu, 26 December 2013, 23:18:05 by gh_pp »
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
« Reply #8 on: Thu, 26 December 2013, 19:46:00 »
Hi,
Are they any pictures of videos showing how this mod is done? ziplock bags seem to be way too huge for the keycaps...
Thanks
You just cut a small piece out to fit over stabilizer insert.
« Reply #9 on: Thu, 26 December 2013, 20:02:02 »
Hi,
Thanks
I cut about 1cm square of ziplock sandwich bag.  Fits neatly without obstructing anything, easily removed, doesn't tear (as paper would) when you insert the stabiliser thingies.
