Author Topic: Spacebar switches for each switch type?  (Read 2164 times)
Offline moonexe
« on: Sun, 29 December 2013, 10:39:49 »
So I recently ordered a set of brown switches to replace my black, but in my excitement I failed to realize that my space bar is actually a linear grey.
Would it feel weird if I put the same switch in the space bar as the rest of the keys?
What would be a better option? Brown stem with black spring?
And for curiosity's sake, what are the most common(or your favorite) spacebar switches for each type?
G80-3000, MX brown           -           Filco Majestouch 2 HAKUA TKL+TK, MX brown, JIS Layout
Offline MJ45
  • HHKB Pro
Re: Spacebar switches for each switch type?
« Reply #1 on: Sun, 29 December 2013, 10:56:36 »
It could be whatever your preference is, but some OEM like Ducky use the next stiffer same type or switch. For example blue with green sb, brown with clear sb, black with grey sb, etc. Others are uniform, I prefer a stiffer linear like black or grey for spacebars.
Offline yjfknt
« Reply #2 on: Sun, 29 December 2013, 11:02:07 »
Shouldn't be weird, all my board has the same switches for spacebar.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #3 on: Sun, 29 December 2013, 11:02:12 »
Try brown with black or clear spring, perhaps even using the darkgrey spring, test it...
The common combos are: Red/Black, Black/DarkGrey, Blue/Green, Clear/Grey, ErgoClear/Clear
A Ghost From The Past
Offline RESPRiT
  • HHKB = ❤
« Reply #4 on: Sun, 29 December 2013, 11:03:09 »
Lots of boards have the same switch all around, but you might find yourself hitting the spacebar a bit harder than before. Like what MJ45, when spacebars are a different switch, it's normally just the next most similar switch with a higher actuation force.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sun, 29 December 2013, 13:55:22 »
With Cherry keycap I definitely recommend using stiffer switch for spacebar. Cherry spacebar is thicker with much more material and heavier than those thin OEM found on most other keyboard. Light switch on Cherry space feels really too soft like it just collapses and I think it feels really bad. I generally roll with next heavy as TheSoulhunter listed out. I don't care for browns much, but if I did I would use clear for space. Grey is traditional but it is a LOT heavier than browns and a much bigger jump up in force. A black spring in a brown will do but browns feel even more linear with them.
Offline moonexe
« Reply #6 on: Sun, 29 December 2013, 16:39:28 »
I guess I'll try it out with a black spring and maybe get a single clear switch if I don't like it. :rolleyes:
« Reply #7 on: Sun, 29 December 2013, 18:18:10 »
Even Topre sometimes includes an extra spring under the space bar.
