Author Topic: Ps2AVR-EXT  (Read 3448 times)
Offline terran5992
  • One With The Cup Rubber
Ps2AVR-EXT
« on: Sat, 04 January 2014, 06:55:52 »
Where can i buy/build it?
Re: Ps2AVR-EXT
« Reply #1 on: Sat, 04 January 2014, 07:46:34 »
sprit is using a ps2avr pcb in his groupbuy.
I think the design is from winkeyless.kr
I forget the exact model number, but he has an option for a 110%
I usually build my kb's at my desk, but a kitchen table should work too.
Re: Ps2AVR-EXT
« Reply #2 on: Sat, 04 January 2014, 12:05:08 »
Build it on any nonconductive surface, same way you'd build a PC.
Re: Ps2AVR-EXT
« Reply #3 on: Sat, 04 January 2014, 12:07:39 »
He's talking about the PS2AVR-EXT.. This thing :
Re: Ps2AVR-EXT
« Reply #4 on: Sat, 04 January 2014, 12:10:21 »
What does it do?
Re: Ps2AVR-EXT
« Reply #5 on: Sat, 04 January 2014, 12:50:25 »
Program keyboards iirc
Offline daerid
    • Rossipedia
Re: Ps2AVR-EXT
« Reply #6 on: Sat, 04 January 2014, 13:35:01 »
Is there any more information on this? Links or anything? I keep hearing about it but haven't seen any definitive sources of information.
Re: Ps2AVR-EXT
« Reply #7 on: Sat, 04 January 2014, 13:37:00 »
http://winkeyless.kr/3
http://winkeyless.kr/11
Offline Photoelectric
Re: Ps2AVR-EXT
« Reply #8 on: Sat, 04 January 2014, 13:37:14 »
Offline terran5992
Re: Ps2AVR-EXT
« Reply #9 on: Sat, 04 January 2014, 19:05:57 »
So how do i go about building it?
Offline hasu
  • @tmk
Re: Ps2AVR-EXT
« Reply #10 on: Sun, 05 January 2014, 19:51:06 »
Get PCB and componets, then solder it.
Learn ps2avrU and V-USB if you need.
https://github.com/showjean/ps2avrU
http://www.obdev.at/products/vusb/index.html
Re: Ps2AVR-EXT
« Reply #11 on: Sun, 05 January 2014, 19:59:51 »
Oh ok, thanks for the correction.
For what it's worth, the /3 link appears to be outdated from the actual PCBs I see in later posts.
Re: Ps2AVR-EXT
« Reply #12 on: Sun, 05 January 2014, 20:33:41 »
Ah. It has surface-mounted components also, that are hard to solder by hand.
You could look if there is a "hacker space"/"maker space" in your area that would have a "reflow oven".
I have also seen that bpiphany modified a toaster to use as a reflow oven.
Offline hasu
  • @tmk
Re: Ps2AVR-EXT
« Reply #13 on: Sun, 05 January 2014, 21:09:47 »
As long as I can tell, it is an adapter which adds V-USB circuitry to PS2AVR keyboard and converts PS/2 keyboard into USB one. From picture it looks simple and is comprised of  three resistors, two zeners and one 0 ohm resistor for jumper. You will need to flash new PS2AVRU firmware with ICSP pins.
But I don't why this dapter has USB receptacle on keyboard side, I think it is natural that it is PS/2 connector.
I'm totally ignorant on Korean keyboard scene and may be missing something.
Yes, SMD hand soldering is not easy, but still possible with proper tools. Or you can find equivalent through hole parts easily.
