Author Topic: Consolidated CES 2014 Thread  (Read 22704 times)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Consolidated CES 2014 Thread
« Reply #50 on: Tue, 07 January 2014, 08:44:21 »
I'm one of those people that feels awkward watching awkward things…
… I'm basically hiding in my hoodie right now…
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #51 on: Tue, 07 January 2014, 08:44:50 »
Steam Machines
http://www.tweaktown.com/news/34681/valve-shows-off-13-steam-machines-we-have-all-the-prices-and-specs/index.html
Ranging from $500 to $6k
Why anyone would spend $6k on a linux gaming computer is beyond me.
Offline kmiller8
« Reply #52 on: Tue, 07 January 2014, 09:38:41 »
« Reply #53 on: Tue, 07 January 2014, 09:57:35 »
Wasn't Matias supposed to release something new at CES this year?
  • Cherry Peasant
  • keycult.com
« Reply #54 on: Tue, 07 January 2014, 09:59:38 »
BS SSK, I think
« Reply #55 on: Tue, 07 January 2014, 10:00:22 »
BS SSK, I think
You  mean ALPS SSK?
  • Cherry Peasant
  • keycult.com
« Reply #56 on: Tue, 07 January 2014, 10:02:02 »
BS SSK, I think
You  mean ALPS SSK?
I mean what I said. I think Matias and SP are making a joint announcement when the countdown timer ends.
« Reply #57 on: Tue, 07 January 2014, 10:03:26 »
BS SSK, I think
You  mean ALPS SSK?
Oh yeah that, sure!
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #58 on: Tue, 07 January 2014, 10:06:00 »
BS SSK, I think
You  mean ALPS SSK?
I'll believe that when I see it, seems like a very odd partnership.
Offline bazh
Re: "Corsair's" Cherry MX RGB keys
« Reply #59 on: Tue, 07 January 2014, 10:29:54 »
I dont get why the switch cover is transparent . It not possible to see them unless you are going to be like demik, typing without keycaps
The idea is the clear case help spread the light from an SMD RGB led under the switch just like what Matias switch did, so I guess the main purpose is now we can have backlit keyboard without switches placed up-side-down and the light comes through all the keycap, not just a coner like before
HHKB Pro2 white
Newbie again
Offline kmiller8
« Reply #60 on: Tue, 07 January 2014, 10:56:28 »
Kailh will also release transparent versions of their switches very soon (which are low-quality Cherry MX copies) and you guys will see plenty of low-quality chinese mechanical keyboards with RGB this year  :))
Wrong, Kailh is releasing a normal body customized to fit a "normal" sized RGB LED
http://www.mechkb.com/blog/industry-developents/cherry-mx-rgb-tesoro-lobera/
Specifically
« Reply #61 on: Tue, 07 January 2014, 11:04:37 »
Specifically
The Kailh / Tesoro implementation is a more traditional LED per-switch implementation except using RGB LEDs. According to Carter from Coolermaster, the LEDs are custom built into the switches (we cannot confirm as our distributors won’t let us open ‘er up… yet ;) ). If you look closely, you can see that the LEDs are not the regular 3mm flangeless LEDs which we have come to know and love.
So coolermaster is selling the board with the Kailh switches with RGB LEDS??
Offline kmiller8
« Reply #62 on: Tue, 07 January 2014, 11:07:05 »
I think that was more referencing that Carter/Cooler Master had reverse engineered the Kailh switches and understood their implementation. not that they were going to use them.
At least that's how I read that.
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #63 on: Tue, 07 January 2014, 11:10:54 »
Was that bloody seizure flash in the video really necessary just to say the word "new"?
Offline Jixr
« Reply #64 on: Tue, 07 January 2014, 11:36:39 »
yeah, I nearly had a seisure half way through?
and i  hope to god the keyboard shown at the end is NOT the final product.
Offline missalaire
  • Great Finder of Great Finds
« Reply #65 on: Tue, 07 January 2014, 11:41:48 »
http://www.hardocp.com/news/2014/01/07/corsair_announces_ax1500i_worldrsquos_most_technologically_advanced_efficient_psu
Corsair®, the most awarded PC power supply brand in the world1, today announced the AX1500i Digital ATX power supply. The PSU’s digitally-controlled circuitry delivers 1500 watts of ultra-stable power with efficiency that goes beyond 80 PLUSTM Platinum, making the AX1500i the most technologically advanced, energy efficient, and customizable power supply available for extreme PC enthusiasts. The AX1500i’s groundbreaking efficiency meets the current draft for ATX 115 Volt 80 PLUS Titanium for consumer PSUs.
The AX1500i's second generation digital architecture enables the PSU to consistently deliver up to 1500 watts of power with class-leading Titanium energy efficiency levels of up to 94%. The DSP-controlled circuitry of the PSU allows it to consistently deliver exceptionally stable voltages along with amazingly low ripple and noise. Tremendous power reserves combined with a vast array of cabling options enables the AX1500i to power heavily overclocked PC systems with up to four graphics cards in NVIDIA® SLI™ or AMD CrossFireX™ configurations with headroom to spare. The AX1500’s leading performance is possible thanks to a streamlined component count and circuit-board layout made possible by the DSP-based design. The AX1500i’s high efficiency results in reduced heat, allowing the PSU to operate in silent Zero RPM Fan Mode until the load reaches 450 watts. A custom-designed fluid dynamic bearing 140mm fan, specifically designed for low-noise operation, allows the PSU to run quietly even when running at full 1500 watt power output.
Offline kmiller8
« Reply #66 on: Tue, 07 January 2014, 11:43:25 »
why would anyone spend $400 on a power supply, jebus corsair.
Offline missalaire
« Reply #67 on: Tue, 07 January 2014, 11:46:03 »
The kind of people who have like $5k lying around to build a computer with :P
Dem quad GPU set ups bro.
Offline kmiller8
« Reply #68 on: Tue, 07 January 2014, 12:07:16 »
http://www.guru3d.com/news_story/corsair_raptor_m45_mouse_and_k40_keyboard.html
Raptor K40 Gaming Keyboard with RGB Backlighting
The Corsair Raptor K40 gaming keyboard combines a comfortable membrane key feel, onboard macro storage, 100% anti-ghosting with full-key rollover on USB, and 16.8 million color customizable backlighting to create a precision gaming keyboard that can be customized for specific games, tactics, and playing styles. The keyboard features 6 programmable gaming keys and 18 programmable functions accessible from 3 separate banks that can be stored in the keyboard's internal memory. The Raptor K40 also has dedicated multimedia keys for convenient music and video playback.
The Raptor K40 gaming keyboard will be available in January at suggested list price of $79.99 and is backed by a 2 year warranty.
Price announced for rubberdome RGB board :))
Offline kmiller8
« Reply #69 on: Tue, 07 January 2014, 12:12:41 »
« Reply #70 on: Tue, 07 January 2014, 12:13:05 »
but it has a 2 yr warranty!!
Offline tormentor
Corsairs Colorful Keyboard from CES
« Reply #71 on: Tue, 07 January 2014, 13:31:16 »
Offline kmiller8
« Last Edit: Tue, 07 January 2014, 15:44:50 by kmiller8 »
Offline tormentor
Re: Corsairs Colorful Keyboard from CES
« Reply #73 on: Tue, 07 January 2014, 13:43:34 »
thanks kmiller
Offline kmiller8
Offline epzy
  • HHKB Fiend
  • ded
« Reply #75 on: Tue, 07 January 2014, 14:41:05 »
To those few podcast interviewees who thought they did a bad job, trust me, you didn't do Michael Bay bad :P
Oh wow, just wow... That has to haunt him for a long time.
Offline Alessandro
« Reply #76 on: Tue, 07 January 2014, 14:58:15 »
Razer's project Christie looks insane:
http://forums.bit-tech.net/showthread.php?p=3476818
Offline kmiller8
Offline McWilloughby
« Reply #78 on: Tue, 07 January 2014, 18:15:56 »
"A fully modular and easy to upgrade... ...gaming PC"
So a gaming PC then?
Sure some people aren't willing to take their computer apart but what they really need is to realise that it isn't dangerous and learn how to do it rather than blowing silly amounts of money on a (likely to be) proprietary hardware standard. Kinda hope this one doesn't get off the ground.
Offline Alessandro
« Reply #79 on: Tue, 07 January 2014, 18:20:44 »
I suppose it depends if they do make it open standard and plenty of other companies get behind it. It doesn't seem like a bad idea for people that aren't confident inside a computer, or if you just want something built. Even later down the line though, I can forsee too many variables that will just mean the project doesn't work.
« Reply #80 on: Tue, 07 January 2014, 18:42:31 »
yeah, wiping away the tears with all that cash.
« Reply #81 on: Tue, 07 January 2014, 22:46:03 »
i want that carbon fiber mouse. dont even care if it works, it just looks cool as hell.
Offline vivalarevolución
« Reply #82 on: Wed, 08 January 2014, 06:11:55 »
Apparently, Michael Bay has no sense of humor.  Good to know.
Offline kmiller8
« Reply #83 on: Wed, 08 January 2014, 07:59:05 »
Ars recap Day 1 in pictures
http://arstechnica.com/gadgets/2014/01/ces-opening-day-games-guns-and-3d-printers/
They have some pretty cool pics of pretty cool stuff in there.
Offline kmiller8
« Reply #84 on: Wed, 08 January 2014, 08:07:18 »
« Reply #85 on: Wed, 08 January 2014, 08:11:43 »
My take on it is that Michael Bay does not stand up to coming up with bull**** for promoting that TV.
« Last Edit: Wed, 08 January 2014, 08:19:39 by Findecanor »
Offline kmiller8
« Reply #86 on: Wed, 08 January 2014, 09:29:05 »
Finally some pictures of the board in the real world.
http://www.slashgear.com/corsair-cherry-mx-rgb-keyboard-hands-on-07311850/
Offline kmiller8
Offline stancato9
« Reply #88 on: Wed, 08 January 2014, 15:45:16 »
Poker 2 - MX Red
Offline kmiller8
« Reply #89 on: Wed, 08 January 2014, 15:47:14 »
Apparently this is 30hz and a TN panel. :( I don't see the use base if that's true.
It’s known as the P2815Q and it contains an IPS LED display
I wouldn't be surprised to see it's only 30hz tbh. None of the three companies have released anything I've seen saying whether it's 30hz or 60hz.
time shall tell..
EDIT:
They're probably 60hz, so you're wrong on both accounts :P
http://pcdiy.asus.com/2014/01/pb287q-4k-for-the-masses/
Here at CES 2014 the new PB287Q is being unveiled offering up 28 inches of 4K resolution, 1ms response time and native 60Hz operation.
« Last Edit: Wed, 08 January 2014, 15:51:37 by kmiller8 »
Offline stancato9
« Reply #90 on: Wed, 08 January 2014, 15:54:21 »
time shall tell..
EDIT:
I just saw that article but I have read from other sources that it will be TN and 30hz. The price seems too good to be 60 and IPS. That would make it go on sale for around $500. Seems too good to be true.
Poker 2 - MX Red
Offline kmiller8
« Reply #91 on: Wed, 08 January 2014, 16:07:10 »
Well, ASUS is reporting the 60hz on their site, and Dell is announcing the IPS on their site.
I'll eat a shoe if the ASUS, Dell, and Lenovo monitors aren't all sharing the same panel.
So I feel pretty safe saying these $600/$700 monitors are 4K, 60Hz, IPS, and DP/HDMI.
Offline stancato9
« Reply #92 on: Wed, 08 January 2014, 16:09:08 »
Hmm maybe, I only have a little while then to sell my U2713HM. But if it's not 60hz I'm going to be screwed.
Poker 2 - MX Red
Offline epzy
  • HHKB Fiend
  • ded
« Reply #93 on: Wed, 08 January 2014, 23:53:07 »
Isn't Ducky at CES this year or? Haven't seen anything from them.
Offline Sniping
« Reply #94 on: Thu, 09 January 2014, 01:33:28 »
4K korean panels imminent?
Offline bueller
  • MX baller
« Reply #95 on: Thu, 09 January 2014, 01:37:43 »
Yep, they use the cast-off's from the major manufacturers so we should start seeing them in coming months.
I'm more excited to see what this does to the 27" wqhd monitor prices on the second hand market, those prices are going to plummet.
Offline stancato9
« Reply #96 on: Thu, 09 January 2014, 01:39:14 »
They are going to have to. All monitor prices are going to be very low now. Hopefully I can sell mine in the next week or two.
Poker 2 - MX Red
Offline kmiller8
« Reply #97 on: Thu, 09 January 2014, 07:13:29 »
UPDATE: I now have confirmation of the P2815Q’s full specs, and have listed them below. Unfortunately, it tops out at 30Hz 3840 x 2160 and 60Hz for 1920 x 1080.
http://www.forbes.com/sites/jasonevangelho/2014/01/07/dell-wasnt-joking-about-that-28-inch-sub-1000-4k-monitor-its-only-699/
So no reason to sell your monitor just yet :P
Also
Panel tech: Anti-glare TN (not IPS which was previously rumored)
So yeah, this monitor just lost my purchase...
Offline kmiller8
« Reply #98 on: Thu, 09 January 2014, 07:39:10 »
Offline stancato9
« Reply #99 on: Thu, 09 January 2014, 13:12:51 »
Also
Yeah, I don't see the user base of this monitor. Who are they targeting? Not gamers because it is 30hz and not graphic designers because of the TN panel. Strange move on their part. They should have increased the cost slightly and made it 60hz and IPS.
Poker 2 - MX Red
