Author Topic: Consolidated CES 2014 Thread  (Read 22703 times)
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Consolidated CES 2014 Thread
« Reply #100 on: Thu, 09 January 2014, 13:15:43 »
Yeah, I don't see the user base of this monitor. Who are they targeting? Not gamers because it is 30hz and not graphic designers because of the TN panel. Strange move on their part. They should have increased the cost slightly and made it 60hz and IPS.
even just 60Hz OR IPS would have been nice.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #101 on: Thu, 09 January 2014, 13:21:05 »
UPDATE: I now have confirmation of the P2815Q’s full specs, and have listed them below. Unfortunately, it tops out at 30Hz 3840 x 2160 and 60Hz for 1920 x 1080.
http://www.forbes.com/sites/jasonevangelho/2014/01/07/dell-wasnt-joking-about-that-28-inch-sub-1000-4k-monitor-its-only-699/
So no reason to sell your monitor just yet :P
Also
Panel tech: Anti-glare TN (not IPS which was previously rumored)
So yeah, this monitor just lost my purchase...
They're pretty attractive to me, i wish they were 16:10 but it's not a deal breaker at 4K resolution. 90% of the time I'm in Chrome or Eclipse so I don't need 60hz, most IT people are probably in the same boat.
Offline stancato9
« Reply #102 on: Thu, 09 January 2014, 13:42:00 »
Also
Yeah, this monitor's only use is to have a large workspace.
Poker 2 - MX Red
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #103 on: Thu, 09 January 2014, 14:33:22 »
I said long ago that it's not really much trouble to put 4 leg RGB led inside an MX switch... just a matter of bending the legs so they would fit through the holes for both the led and diode in the bottom and having led traces on the PCB for this. I will guess that is essentially what Kailh did.
Offline daerid
    • Rossipedia
« Reply #104 on: Thu, 09 January 2014, 17:25:42 »
A 4K monitor's only practical use for the masses is as a "retina" resolution display (1080p logical resolution).
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #105 on: Thu, 09 January 2014, 22:24:39 »
AMD's Nano PC (prototypes only :( )
http://www.techspot.com/news/55262-amds-super-thin-nano-pc-prototype-debuts-at-ces.html
I just wish they started released actual units, would be nice to buy something as thin as a small book or credit card and use bugger all electricity.
Would be the ideal 24/7 hardware connected to some online hard drives.  Just goes to show AMD isn't dead just yet  :thumb: .
« Reply #106 on: Fri, 10 January 2014, 05:00:02 »
That mineral oil thing is not going to happen any time soon..
I mean... it's just NOT BETTER than AIR cooling, OR Water cooling..
Linus is the biggest BSer ever,  quiet?  that's also not possible.. they haven't invented a quiet pump yet..  and the oil can NEVER cool the pc without a radiator, so you're back to fans...
« Reply #107 on: Fri, 10 January 2014, 16:06:16 »
It certainly wouldn't hurt AMD to roll something like that out to compete with intel NUC.
The biggest problem I see with that Razer concept pc isn't the submersion cooling but the fact that if it did come to production you would have the most horrible vendor lock in possible. Also they may promise modularity into the future, but we all know they would release maybe 1 gen of hardware with that at best then change the interface for everything to cause one to purchase the whole system over again. If I had a desire to get something that is horribly proprietary I would rather buy the Apple Pro trashcan. At least Apple has a pretty good build quality overall and a good support system compared to Razer.
I don't get all the hype over 4K displays either. It's too early for them to take full advantage of. It will be awhile before HD content catches up and they are not good for gaming unless you can afford tri SLI Titans. Until those things change I couldn't give a **** about 4K.
Offline Elrick
  • Hype Master
« Reply #108 on: Fri, 10 January 2014, 16:28:26 »
I actually love the Apple Pro Trashcan, so cool to look at and it simply lets everyone know that you've got the most expensive trashcan in the office, sitting on your desk  ;D
Offline kmiller8
« Reply #109 on: Fri, 10 January 2014, 16:29:31 »
The biggest problem I have with the trashcan is there is 0 internal expandability. If you want more storage, you're going to buy thunderbolt devices, which use a $50 cable ffs.
« Reply #110 on: Fri, 10 January 2014, 19:04:44 »
u can get cheaper cables... the problem is the apple can is way too expensive for the bottom barrel performance..
it's essentially a final cut pro machine.. that's it...  if you don't use final cut pro, you can spend less money and get 2x the performance elsewhere.
Offline Ghetto Caps
  • i make ghetto caps.
« Reply #111 on: Sun, 12 January 2014, 00:10:44 »
Visit the Typing Test and try![/sigpic]
Offline Ghetto Caps
Offline kmiller8
« Reply #114 on: Sun, 12 January 2014, 11:35:15 »
yeah ive seen that, but i mean Cooler master is releasing a TKL version in 5 mounths or so
Cooler Master posted that thread. That is the coolermaster TKL you're thinking of.
Offline missalaire
  • Great Finder of Great Finds
« Reply #116 on: Sun, 12 January 2014, 18:02:16 »
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #117 on: Tue, 14 January 2014, 14:58:42 »
6:00
Unannounced mechanical switches?  Does this mean Cherry RGBs? (Supposedly exclusive to Corsair?) or maybe Alps?
(sorry if this was already posted, I haven't seen anything about this yet)
Offline kmiller8
« Reply #118 on: Tue, 14 January 2014, 15:04:59 »
6:00
It very well could be those Kailh RGB switches also.
http://www.mechkb.com/blog/industry-developents/cherry-mx-rgb-tesoro-lobera/
Especially if the Corsair/Cherry partnership is truly exclusive for a whole year, I don't see why other companies wouldn't go and find alternatives to be competitive.
Offline jwaz
  • * based mod
« Reply #119 on: Tue, 14 January 2014, 15:23:12 »
I bet you're right about the Kailh switches. Sounds like Cherry is sort of shooting themselves in the foot on this one.
Offline bazh
« Reply #120 on: Fri, 17 January 2014, 05:42:08 »
wow, so Rosewill have Buu in their team...
and oh, isn't that red backlit keyboard just a MaxKeyboard Nighthawk rebrand ?
« Last Edit: Fri, 17 January 2014, 05:49:28 by bazh »
HHKB Pro2 white
Newbie again
Offline missalaire
« Reply #121 on: Fri, 17 January 2014, 09:55:38 »
http://www.xtremerigs.net/2014/01/10/swiftech-ces-2014-suite/
Swiftech's new AIO H220X cooling system looks interesting. Hopefully they sell it at a reasonable price.
